Install Help Upper Control Arm Bushings 98 S10 2.2l
The upper control arm bushings are shot on my 98 S10, 2.2l. On the drivers side, there is one that is completely blown out. The front end shakes badly at slow speeds.
I need to install new control arms this weekend, and the drivers side really concerns me. It looks like there is a lot of stuff in the way of the two bolts and 18mm nuts that hold the control arm to the frame. Looks like the steering column may need to be pulled, and there is a bunch of stuff in the way of even pulling that. It also looks like there are brake lines in the way. I'm looking for any install tips that might help make the job a little easier. Thanks in advance. |
Re: Install Help Upper Control Arm Bushings 98 S10 2.2l
Thanks again to everyone for all the advise. lol
No longer a pizza tech.
theres an 11mm nut on the steering shaft under the little plastic cover at the gear box, you should be able to undo that and knock the shaft back and pull it up.
S10 Frame Swapper
Get a complete control arm assembly, like Dorman 520-137 and 520-138. I tried pressing the bushings out after a week of soaking in PB blaster and heat and STILL ended up bending the arms enough that I couldn't re-use them. I should have just spent the money up front instead of wasting my time. I still have the ball joints and upper bushing for the other control arms if anyone needs em.
I have lower back issues from time to time, so I decided to pay a local mechanic to do it. I though $75 was more than reasonable. He undid the manifold pipe and pulled it down a bit so he could access the nuts. Then he backed the nuts out most of the way and got something on them and tapped the bolts out of the frame so he had room to pull the control arm up and off. The flex pipe on the exaust has been leaking a bit the past few months, and it is worse now after he unfastened it from the manifold and put it back up. But I figure it was going to need to be replaced anyway. It still needs a Center Link, and one of the outer tie rod ends needs replaced, so I ordered the whole set of four, and the center link. Man, I am just about sick and tired of this front end. I just want it done, aligned, and to stop shaking all overr the road. |
Slowly but eventually
Hmm, I just had to take the steering shaft loose from the steering box to get mine out, but if what he did made it easier then ok.
| Sponsored Links | |
Advertisement | |
