idler arm keeps going bad, please help!! - S-10 Forum
post #1 of 13 Old 09-16-2012, 03:53 PM Thread Starter
User is: jonmax999 is offline
Question idler arm keeps going bad, please help!!
I just changed my idler arm and its bad again. (pretty much instantly)Its flexing just like the old one. Before i go changing this one, does anyone know a reason why idler arms would repeatedly go bad? I have a 4wd 02 Sonoma with 17 inch wheels. Goodyear recently put on 245-45-17 new tires and dropped the front a couple inches with the torsion bars.They also did an alignment. there must be another problem i'm missing because what are the chances that my new part was defective, it was a pro-line, $20 at pep boys. the rest of the steering linkage seems fine. can anyone please help?
post #2 of 13 Old 09-16-2012, 04:00 PM
B4U Task Force
Rhotpursuit's Avatar
Re: idler arm keeps going bad, please help!!
Spend the money and get a quality part, Moog, Trw, NAPA brand. Not everyone will agree with the choices, but they're probably better than Pep Boys.
U.S.C.G. "So others may live"
Apple Red 96 SS
post #3 of 13 Old 09-16-2012, 04:02 PM
Gen210's Avatar
User is: Gen210 is offline
I am sure the part is partially at fault, is there any way possible that you can get your hands on a MOOG part?
'96 s10, C6s, 8.8, Envoy bumper, Jimmy grille, Ls1/C5 brakes,4L80E, 5.3, N2O......
'81 Malibu, could not resist the deal. Ls to come
'93 TA, plenty haul ass parts
Gen210 is offline
post #4 of 13 Old 09-16-2012, 04:02 PM Thread Starter
So its probable, that it could be just a crappy part?
post #5 of 13 Old 09-16-2012, 04:15 PM
B4U Task Force
There's no doubt it's a crappy part...
Apple Red 96 SS
post #6 of 13 Old 09-16-2012, 04:25 PM
Gen210's Avatar
You get what you pay for a lot of the time.... take a look at RockAuto I am sure they sell an idler arm for your application and when it arrives you can bring the bad part back to the 3 stooges
Gen210 is offline
post #7 of 13 Old 09-16-2012, 04:45 PM
Registered Hoosier
Hoosier Rick's Avatar
My daughter kept wearing out the lower grade ozone lifetime brake pads. They let her upgrade to the premium for like 7 bucks.
Maybe the peppy boys will let you upgrade to a premium part for the price difference.
2002 rcsb, 2.2 at, 267,000 miles
1967 C10
post #8 of 13 Old 09-16-2012, 04:46 PM
B4U Task Force
That's where I got mine for the Blazer2
Apple Red 96 SS
post #9 of 13 Old 09-16-2012, 05:23 PM Thread Starter
i will have to order the MOOG. The guy at autozone said if the pitman arm is bad it will make the idler arm fail right away. Is this true? My pitman seems fine, no play in it...is there a way to really test a pitman arm? thanx for the replies!
post #10 of 13 Old 09-16-2012, 05:39 PM
B4U Task Force
Moog $40...Raybestos $46 minus 5% discount at Rockauto. I bought the Raybestos...good stuff.
Apple Red 96 SS
post #11 of 13 Old 09-16-2012, 11:00 PM
Flak7's Avatar
User is: Flak7 is offline
2nd that on the Raybestos. For what its worth, check for slop in your steering box. I had the original center link in my truck forever with no problems until I switched to a ZQ8 steering gear- it was used and started leaking when I put it in, and I took it apart to replace the input shaft seal. In doing so, I did not completely drain the steering gearbox and ended up setting the backlash incorrectly. I noticed a small amount of play in it when I reinstalled it and thought it was just the old rag joint, but I really didn't recall having that much play with the old box. A week later, I had LOTS of slop-the ball stud in the center link connected to the pitman arm was shot. May have been a coincidence, but I'm guessing maybe not.
Flak7 is offline
post #12 of 13 Old 09-21-2012, 11:28 AM
I Prefer Payne
payne4life's Avatar
User is: payne4life is offline
Yes a bad pitman arm can cause your idler arm to fail sooner so i would make sure that the pitman arm is good too. i bought the moog part for my truck and havent had and issue with it since.
2000 SAAB 9-3 2.0t hatchback 5-speed. 145k miles - CURRENTLY ON JACK STANDS
2000 s10 LS X-cab 2.2 flex fuel auto. 170k miles
MODS: 56mm TB, Ebay CAI with K&N filter, E-fan, ZQ8 sway bars, GC steering box, steering shaft u-joint
http://www.cardomain.com/id/brandomonium12
post #13 of 13 Old 09-21-2012, 08:47 PM
User is: bg's is offline
I use only Spicer [Now Raybestos] Professional Series front end parts
because they work, they last and last a long time. >
It's about 50 bucks + from Rock Auto.
http://www.rockauto.com/catalog/x,ca...,parttype,7328
bg's is offline
