idler arm bad?? - S-10 Forum
post #1 of 25 Old 06-19-2008, 04:52 PM Thread Starter
umm yea
JoPre's Avatar
User is: JoPre is offline
Send a message via AIM to JoPre
idler arm bad??
how do you tell if your idler arm is bad?
i jacked up the front and grabed ahold of everything, and it all seems nice and tite, except the idler moves just BAAAREELLYY. replace it or no?
. ________
/___/__\\___
[_________]
'94 S-10 Blazer 4.3 4L60E 5/3 drop lightly modded
JoPre is offline
post #2 of 25 Old 06-19-2008, 05:12 PM
Overhead Console Expert
Raven's Avatar
User is: Raven is offline
Send a message via AIM to Raven
Re: idler arm bad??
yea...ive been wondering about this too
1999 S10 4.3L Zr2
Overhead Console Dude
Raven is offline
post #3 of 25 Old 06-19-2008, 07:22 PM
User is: PimpingA1997Jimmy is offline
Re: idler arm bad??
if the left wheel is loose or wiggling and it looks like its up there at the arm then it needs to be replaced atleast that is how i figured out that mine is bad and i need to replace it
dont go with the cheap brands that are like 20 and 30 dollars unless you plan on getting ride of the truck soon they only last like a year if not less i go with TRW or MOOGE
post #4 of 25 Old 06-19-2008, 07:37 PM Thread Starter
umm yea
JoPre's Avatar
Re: idler arm bad??
i already have one it says mooge on the wrapping its in i got it from autozone.
and both my wheels are a little wobbly just a little though, i am goin to replace the bearings and see if that helps.
. ________
/___/__\\___
[_________]
JoPre is offline
post #5 of 25 Old 06-19-2008, 11:51 PM
Re: idler arm bad??
mooge at autozone wow
post #6 of 25 Old 06-20-2008, 12:57 AM Thread Starter
umm yea
JoPre's Avatar
Re: idler arm bad??
i know i was surprised too
. ________
/___/__\\___
[_________]
JoPre is offline
post #7 of 25 Old 06-20-2008, 07:57 PM
The Eye is watching you!!
kamesama980's Avatar
User is: kamesama980 is offline
Send a message via AIM to kamesama980 Send a message via Yahoo to kamesama980
Re: idler arm bad??
jack both front wheels up, shake them one by one watching the idler and with 1 hand on the tie rod end to feel for movement there. if the wheel moves without moving the hub: bearings. if you can see the idler move up/down, it's bad. if you can see/feel the tie rod end moving, it's bad.
-Russell
1990 Toyota Cressida 7MGE 3l I6/5-speed manual
1987 S10 2.5 not even power brakes it's so base model
"You don't get to judge me for how I fix what you broke."
read this and obey or face my wrath
post #8 of 25 Old 06-20-2008, 08:03 PM
Bagged1984S10's Avatar
User is: Bagged1984S10 is offline
Send a message via AIM to Bagged1984S10
Re: idler arm bad??
These seem to go bad pretty often. If it has any play in it I would replace it.
Xbox Live Gamertag: My Tango Sucka
post #9 of 25 Old 06-24-2008, 04:08 PM
Re: idler arm bad??
correct. the 2 most common chassis-suspension problems I've seen on S10 pickups and blazers is the idler arm and on 2wd the front wheel bearings.
-Russell
post #10 of 25 Old 06-24-2008, 05:39 PM Thread Starter
umm yea
JoPre's Avatar
Re: idler arm bad??
well they are both being replaced this week/weekend.
. ________
/___/__\\___
[_________]
JoPre is offline
post #11 of 25 Old 06-24-2008, 07:50 PM
Re: idler arm bad??
i gota take the 4wd jimmy in next week for the idler arm
the one thing i dont understand is i can get a mooge from advanced for 59 with a lifetime warranty or i can go to summitt and get the mooge for 47 with a 1 year how come it seems like eveyrhting summit sells has a 1 year on it
post #12 of 25 Old 06-24-2008, 08:14 PM
User is: flanders20 is offline
Re: idler arm bad??
the spec for replacing is 1/4" movement up and down
Thats whats seen when I fly by ya!!!!!
post #13 of 25 Old 06-25-2008, 09:21 AM Thread Starter
umm yea
JoPre's Avatar
Re: idler arm bad??
thanks flanders
. ________
/___/__\\___
[_________]
JoPre is offline
post #14 of 25 Old 06-25-2008, 03:21 PM
Re: idler arm bad??
i dont know what my specs are but i know that i hear a poping noise when i turn to the right going forward with the wheel cut all the way to the right and the only thing it could be is the idler arm
do you have to do a wheel alighment when you replace the idler arm ?
like i just replaced the ball joints and right front axle and i didnt need a wheel alighment but do i need to get the alighment for the idler arm ? or should i be cool with that since it doesnt seem to pull to mouch ?
post #15 of 25 Old 06-26-2008, 12:02 AM Thread Starter
umm yea
JoPre's Avatar
Re: idler arm bad??
x2 ^^
. ________
/___/__\\___
[_________]
JoPre is offline
post #16 of 25 Old 06-26-2008, 08:58 AM
Re: idler arm bad??
x2 ?
post #17 of 25 Old 06-26-2008, 02:41 PM Thread Starter
umm yea
JoPre's Avatar
Re: idler arm bad??
yes x2 , you know like times two, meaning i would like to know aswell.
. ________
/___/__\\___
[_________]
JoPre is offline
post #18 of 25 Old 06-27-2008, 10:36 PM
Re: idler arm bad??
i guess no one wants to answer for iether of us LOL
post #19 of 25 Old 06-28-2008, 01:06 PM
Registered (Ab) User
Yogi's Avatar
User is: Yogi is offline
Re: idler arm bad??
Yes, you will need an alignment. It can change your "toe" adjustment.
2008 Saturn Sky Red Line Roadster
2.0L LNF Turbocharged Motor
5 Speed Manual Trans.
Custom made Blazer CAI (Click Here)
Yogi is offline
post #20 of 25 Old 07-05-2008, 12:58 AM
Re: idler arm bad??
you don't NEED an alignment unless the holes are elongated and the idler mounting bracket can move on the frame. that being said, it certainly doens't hurt to get one at all.
-Russell
post #21 of 25 Old 07-05-2008, 09:50 AM
Re: idler arm bad??
it didnt need an alighment i will get one in a week when i have more money to spend but feels the same not pulling or anyting
post #22 of 25 Old 07-07-2008, 11:21 AM
bling bling like WHOA
xtreme03blzr's Avatar
User is: xtreme03blzr is offline
Re: idler arm bad??
Wow.. I didn't know Federal Mogul changed the name to mooge from MOOG
2003 XBlazer 4.3L - E-fan - K&N Intake - W4M tune - March pullies - 2/2 drop w/zq8
post #23 of 25 Old 07-07-2008, 01:15 PM Thread Starter
umm yea
JoPre's Avatar
Re: idler arm bad??
haha well w/e it is!
. ________
/___/__\\___
[_________]
JoPre is offline
post #24 of 25 Old 07-07-2008, 04:03 PM
User is: MikeInCtown is offline
Re: idler arm bad??
Just because it isn't pulling doesn't mean it doesn't need an alignment. I replaced ALL the steering stuff on my truck this weekend and it drives perfectly straight right now. I guarantee that it still needs an alignment though.
post #25 of 25 Old 07-08-2008, 12:13 AM Thread Starter
umm yea
JoPre's Avatar
Re: idler arm bad??
werd, my truck did use to drive fine when i first got it but it ran the edge of the front tires bald in 1000 miles.
. ________
/___/__\\___
[_________]
JoPre is offline
