Front popping noise
Old 11-07-2009, 03:11 AM   #1
ZQ8 Blazer
ZQ8 Blazer's Avatar
Front popping noise
Looking into buying another Blazer but this one is a 4wd w/ a 4" Trail Master lift. The owner said it had a popping noise coming from the front and he thought it was the cv axles. The shop that tore the front end down said the cv's were fine and now that the front driveshaft is out it's not popping anymore and he's just driving it like that. What do you guys think it could be?
Old 11-07-2009, 02:47 PM   #2
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: Front popping noise
Anyone? Could it be the transfer case?
Old 11-07-2009, 07:33 PM   #3
Right now mine is doing the same thing. When I figure it out I will let you know.
Old 11-07-2009, 08:57 PM   #4
ZQ8 Blazer
ZQ8 Blazer's Avatar
ok, well hury up haha
Old 11-08-2009, 03:21 PM   #5
You need to have someone you trust, look at the front end from all direction while you drive the truck real slow. Watch the movement of the shocks and the control arms.
Try jacking the truck up and spinning the wheels and listen for the popping sound.
Mine turned out to be the brand new CV axel. It was binding up, causing a vibration and popping sound.
Old 11-08-2009, 08:40 PM   #6
ZQ8 Blazer
ZQ8 Blazer's Avatar
What if the drive shaft is out and it's in 2wd would the cv(s) still pop?
Old 11-08-2009, 08:57 PM   #7
whore turned lurker
dimerunner88's Avatar
yeah, the cv's will turn whenever the truck is moving,i would check the front driveshaft for loose u-joints since it stopped popping when you removed it. also check to see if they changed the rear end ratio but not the front.
Old 11-08-2009, 10:58 PM   #8
ZQ8 Blazer
ZQ8 Blazer's Avatar
I know the rear end is ratio is the same. I'm going to buy it if the guy will come down to the price I want so I'll let you guys know what the deal is or if I need more help.
Old 11-09-2009, 10:16 AM   #9
Registered loser
FoolThrottle's Avatar
pics?
Old 11-09-2009, 05:33 PM   #10
ZQ8 Blazer
ZQ8 Blazer's Avatar
Of what, the Blazer?
Old 11-14-2009, 02:18 PM   #11
Registered loser
Yeah man.
Old 11-14-2009, 10:50 PM   #12
ZQ8 Blazer
ZQ8 Blazer's Avatar
ok I'm lost do you want pics of the Blazer or some of the 4wd components? Here's a pic of the Blazer. It has brand new 31's on it now(those are 33's)
I'm going to drive it tomorrow and see how I like it. If I do then I'll be picking it up.
Page generated in 0.57665 seconds with 31 queries
[Output: 75.23 Kb. compressed to 70.04 Kb. by saving 5.20 Kb. (6.91%)]
