Front end poping, when backing up & turning.... Control arm bushings? - S-10 Forum
post #1 of 27 Old 07-17-2007, 06:26 PM Thread Starter
Unregistered User
j894's Avatar
User is: j894 is offline
I've noticed this over the past month or 2.
I've been hearing the front end pop while backing up & turning the wheel right.
In February I had new balljoints & a new idler arm put in. I check them the other day & they dont seem to have any play in them. The Calipers & everything else seemed tight as well. I've been having poor "directional stability", & Memory steer mainly to the drivers side. When driving it, it seems like its all over the road, despite getting new tires & a few alignments
Does this sound like bad control arm bushings? From what I can find, thats what its leading up to? I think Im going to take it to a garage next week to be sure, but does anyone else have opinions on this matter?
Also, if it is indeed the control arm bushings, does anyone have a rough idea what it would cost to have them replaced? Labor wise I mean?
Are the ES polyurethane bushings a worthwild replacement if they are going to be replaced? I've heard poly bushings make for a crapy ride
http://store.summitracing.com/partde...w=1&N=700+150+
Thanks for any help
'01 Blazer, 5sp, 4x4
Retired: 1993 Chevy S-10 Blazer - 4x4,4.3L,CPI, auto
-Cardomain-
j894 is offline
post #2 of 27 Old 07-17-2007, 06:36 PM
Molon Labe
BudRacing's Avatar
User is: BudRacing is offline
Send a message via AIM to BudRacing
Re: Front end poping, when backing up & turning.... Control arm bushings?
Poly bushings in some applications such as body mounts give a harsh ride... on control arm bushings, its more of a control type thing. Replacing them at a shop may run you $400-500. Taking the control arms off and having a machine shop press the old ones out and new ones in may only cost you parts and the $75 fee a machine shop may charge. (That's Napa's price; local shops may be much cheaper). The only real battle I've had with the poly bushings is keeping the uppers lubed, cause they squeak like a bitch. A zerk fitting on the upper bushing caps would do wonders... but I need to get around to that.
post #3 of 27 Old 07-17-2007, 11:56 PM
I AM CANADIAN
tt85_GM's Avatar
User is: tt85_GM is offline
seems like me and everyone else are having this popping noise all at once, lol.
I've done some research and found that people say the black energy suspension bushings don't squeak as much as the red, so I bought them and they cost me $120 CND.
I just need some time to install them and see if my popping goes away because every other part seems to be ok, and people say control arm bushings can cause a popping or rattling noise.
And you mention directional stability..mine is allover the road as well, I had it aligned and the tires balanced, still allover the road, could be because I have wide tires 245 50's I donno, maybe someone knows.
-'02 Jimmy 2dr 4x4, 2" lift & 31's
-'08 Altima coupe
-2000 Sonoma, 4.3L, polished ZQ8's- SOLD
Polishing ZQ8's thread:
http://www.s10forum.com/forum/f14/po...roject-366831/
Leather Seat Swap: http://www.s10forum.com/forum/f26/leather-seat-swap-346677/
tt85_GM is offline
post #4 of 27 Old 07-18-2007, 02:06 AM Thread Starter
Unregistered User
j894's Avatar
I have stock size. 235/70r15s
I didnt have this problem months ago
-Cardomain-
j894 is offline
post #5 of 27 Old 07-19-2007, 09:05 PM
SlammedSonoma96
SlammedSonoma96's Avatar
User is: SlammedSonoma96 is offline
Is the problem only happening when turning, or does it happen when the wheels are straight?
96 GMC Sonoma: Bagged SD 5 link, Slam RE7 front RE8 rear. 20" ADR Propulsion Wheels, Fully shaved,
AVS cowl induction hood, Blazer front end swap, SS Bumper, being prepped for paint.
Soon to have a 5.3/4L60E
post #6 of 27 Old 07-19-2007, 11:23 PM Thread Starter
Unregistered User
j894's Avatar
Well Sometimes it seems to happen when going straight, but its at random.
Most of the time, I can replicate it while backing up & making fairly quick turn.
I was looking at the uppers earlier. They look dry rotted, as normal for a truck with 115k on it... but I dont see any chunks missing.
I coudln't really get a good look at the lowers.
Part of the "directional instability" is sometimes the truck wants to pull right, sometimes left depending on the bumps in the road. When driving it the steering wheel seems to have play in the drivers side but not in the passengers. But the tie rod seems ok? But this only seems like it would be a piece of the puzzle, because if theres to big of a bump in the road it will want to throw the vehicle in the direction of the bump.
-Cardomain-
j894 is offline
post #7 of 27 Old 07-20-2007, 12:01 AM
bling bling like WHOA
xtreme03blzr's Avatar
User is: xtreme03blzr is offline
idler arm ?
post #8 of 27 Old 07-20-2007, 12:17 AM Thread Starter
Unregistered User
j894's Avatar
idler arm is only a few months old
-Cardomain-
j894 is offline
post #9 of 27 Old 07-20-2007, 12:25 AM
User is: AZ2001dime is offline
it sounds just like mine before i replaced the control arm bushings...first passenger side then driver....its not to difficult to DIY b/c im no mechanic by far....but you will probaly have to get a allingment after replacing them...
2001 4.3 Auto X-Cab
K&N Intake, Hypertech Tuned, 3/4 Belltech drop, Tinted Tails, 2 Fosgate P2 / 12's and P600 amp
post #10 of 27 Old 07-20-2007, 12:44 AM
perfect 10's Avatar
User is: perfect 10 is offline
Send a message via AIM to perfect 10
The black ones squeek like crazy to. I thought the same thing and went with the blacks on my 1st gen. Lubed the heck out of them before and after install and still squeeked. I took them out after a year and went back to stock bushings..much better..imo. If your gonna go with the polys drill a hole in the a-arm and add a zerk fitting so you can get even more grease in them.
2003 zq8 S-10
1988 S-10
05 Colorado Xtreme
post #11 of 27 Old 07-20-2007, 07:55 AM
User is: Lt_Dusty is offline
I had a similar issue. I retorqued the the bushing bolts and the pop went away. I know now that bushings are the problem, but I atleast isolated the problem. Also had a tie rod adjuster bolt that would hit the lower control arm on a turn and make a pop.
Lt_Dusty is offline
post #12 of 27 Old 07-20-2007, 03:48 PM
I turn.
rentedmule's Avatar
User is: rentedmule is online now
I have the popping problem too and my truck only has about 30k miles on it - nothing to add on that really but when i put my 245/50's on i noticed it was all over the road as well. the same thing happened on 4wd's i've had when i put fat tires on them (10.5-12.5" wide), they'll just pick up a crack or a dip in the road and follow it.
Auto-X mule: EC 2wd 4.3 auto, XTREME80 tune, bolt ons, UBM UCAs, Spohn LCAs, tall BJs, QA1 coilovers and shocks, Torsen LSD, C5 brakes, race seats, Toyo R888's.
Winter daily: '94 Jimmy 4dr 4wd. Exceptionally stock.
Summer daily / auto-X: '95 Firebird Formula Ram Air, LT1/T56, Koni/Strano/BMR suspension
post #13 of 27 Old 07-20-2007, 05:51 PM
I AM CANADIAN
tt85_GM's Avatar
your right, I think wider tires up front are bad for directional stability, but they look good.
-'08 Altima coupe
tt85_GM is offline
post #14 of 27 Old 07-21-2007, 01:21 AM Thread Starter
Unregistered User
j894's Avatar
I was looking at the tie rod. I dont see any contact makes on the control arm, or the tie rod itself.
I dont think the tires are a problem, they are the stock 235s as i mentioned above. Even so, i've had the tires before this problem started.
The amount of memory steer on the drivers side is ridiculous. If I turn the wheel hard left & let go it will stay there & I will go in circles
-Cardomain-
j894 is offline
post #15 of 27 Old 07-21-2007, 01:30 AM
Molon Labe
BudRacing's Avatar
alignment perhaps?
post #16 of 27 Old 07-21-2007, 01:43 AM Thread Starter
Unregistered User
j894's Avatar
I was just looking at some more diagnostic tables/charts in the service manual I have. Under the Leads/ pulls diagnostics, I just read this part that says
"Inspect steering gear valve for an unbalance
If this is the cause, steering effort will be very light in the direction of the lead, and effort will be very heavy in the opposite direction with the vehicle parked on a smooth level surface."
This sounds exactly like one of the steering issues I was/am having now. But I while driving down the road.... I haven't tried feeling for it while it was parked, & also have the popping noise.
The next set for this condition is to: "Replace the steering gear valve. Refer to Steering Gear valve replacement - Off vehicle in Power steering System." It then goes into detail about taking apart the steering box for this valve. Im going to assume the steering box is bad since my warranty will cover it. I just have to get a garage to make sense of it first, because it has to come from their mouth, not mine.
Could the memory steer possibly be caused by the alignment or toe not being setup right? (in combination with a bad bushing?)
-Cardomain-
j894 is offline
post #17 of 27 Old 07-21-2007, 01:44 AM Thread Starter
Unregistered User
j894's Avatar
Originally Posted by BudRacing View Post
alignment perhaps?
If it were only that simple. heh
i've had 3 alignments in the past 2 months.
-Cardomain-
j894 is offline
post #18 of 27 Old 07-21-2007, 01:52 AM
Molon Labe
BudRacing's Avatar
Ok then, maybe not. Just mentioned it because after installing my drop spindles yesterday my alignment is way off ( \......../) and I was having similar problems during a test drive.
post #19 of 27 Old 08-07-2007, 02:14 AM Thread Starter
Unregistered User
j894's Avatar
Didnt get a chance to update this.
After looking at it again, I took it to a garage. They said the bushings we're fine, & the front end was tight. They couldn't find anything, other than it being out of alignment....Again.. I don't go off roading or & try not to hit any abnormal size potholes, somehow it keeps coming out of alignment. This is the 3rd time in 3 months.. 1 time each month since may its been way out.
also, I've also been hearing this random banging... think metal plate hitting metal sound, when my truck was moving slowly.... I had thought the trans mount had broke... today i went to sit in the drivers seat & go somewhere, when I sat down I heard the clank. Defiantly not the trans mount. Im guessing is related to the popping noise I hear when backing up & turning? Do the torsion bar mounts go bad often on these trucks?
*scratches head*
-Cardomain-
j894 is offline
post #20 of 27 Old 08-07-2007, 05:04 AM
Work in Progress
User is: frankie413 is offline
I've had the same type of problem.. in a way. when i turn the wheel all the way to either side it kind of pops and it sounds like something is leaking out.. I also have a oil leak. my transmission fluid leeks out. I also got the idler arm replaced not long ago and when I took it to get it aligned the guy said he won't align it until my steering gear box is fixed? so apparently this may be my problem? does anyone know if i need to buy a brand new steering gear box or something smaller than that? I know I can probably find one for under $400 but I want to make sure that it's the only thing that could be wrong? has anybody else had a problem with the steering gear box? this is what the guy at the chevy dealership said, but i'm not sure. I also have a pretty rough ride. when i first got the truck it rode rough, so I bought brand new shocks.. still rides rough? could it be possible that there is any connection? doubt it but i wish it was that easy. If anyone can let me know anything extra that'd be great
post #21 of 27 Old 08-07-2007, 05:06 AM
Work in Progress
then somebody also said that the roughness may be because of the leaf springs? is this true? it's a 98 with 158K so could that also be a factor?
post #22 of 27 Old 08-07-2007, 06:09 AM
Huge Ideas, Tiny Wallet
sockjock's Avatar
User is: sockjock is offline
Well I've got the popping issue myself. I bought the Blazer with 90k on it and it popped from jump. I just assumed that I needed new control arm bushings. It also pulls to the right. I put new brakes and rotors on it right after I got it and that didn't change the noise or the pulling. I've been wanting to rebuild the whole front suspension but money seems to be an obstacle. So I've been driving it and hoping nothing lets go. 108k on it now. Hopefully I'll be able to rebuild the suspension soon. I did manage to replace the shocks and sagging torsion bars and added a leaf in the rear. It's got a pretty stiff ride.
Chris
  • '95 Blazer 4dr 4WD 2" BL, 1.5" tbar tweak, homemade AAL, 1.5" lift shackles, 31x10.50/15s, 1.5"wheel spacers in rear, K&N FIPK, underdrive pulleys, FL60 efan, cat delete, O2sim, 2.5"dynomax catback ex., transgo shiftkit, corvette servo, 3.73gears and G80rear
  • '97 Blazer 4dr 4WD WRECKED: Needs BCM, drivers' side fender, valance & possibly a few other parts
sockjock is offline
post #23 of 27 Old 08-07-2007, 06:22 PM
4 Eyes
droppedblacks10's Avatar
User is: droppedblacks10 is offline
*scratches head*
have them check the bolts that go into the ear of the frame, its where the shims are placed for the alignment. They are supposed to be pressed kinda into the frame, they have splines and if the splines have been stripped they can come loose and throw the alignment off. Just something else to check, but it does sound like that may be it though to me.
post #24 of 27 Old 08-09-2007, 09:27 PM
Never Finished
Xtreme03's Avatar
User is: Xtreme03 is offline
Try lubing your steering stops. When I had stock LCAs, I had to lube mine occasionally, or they'd pop at full lock.
2009 Scion xB
2003 Xtreme - Indigo Blue, 4.3, 5-spd, stepside, bags, 18s, suede interior, etc...SOLD
1991 S10 - Daily Driver Project - primer, 4.3, auto, leftover Xtreme parts...SOLD
Xtreme03 is offline
post #25 of 27 Old 05-26-2015, 10:06 AM
missileman's Avatar
User is: missileman is offline
What do you mean lube the steering stops.How long would lube stay on this stop or is there a special type.I get a click/clunk at times when backing up hard left or right ,but not all the time.I have had someone turn wheels are right to hard left,didn't see any movement or clunking that look abnormal.A guy at the dealer said to check the cross member bushings,the get cracked and worn and could be the problem with the noise traveling up the frame.The noise seems to be around the control arm area. But the bushings don't appear to be the issue.
post #26 of 27 Old 05-26-2015, 09:24 PM
User is: SmokinDan is offline
Last post was 8 years ago, man. If you have a problem, make your own thread and explain your problem and we'll help you out.
post #27 of 27 Old 05-27-2015, 07:42 AM
missileman's Avatar
Sorry I didn't think of looking at the date when it was posted.
