clunking noise when turning on zr2
I've notived that when i make a hard turn or turn really fast i hear a clunking noise on my 2000 s10 zr2. i'm thinking it maybe is an outer tie rod end. have any of you other guys noticed this.
i have 115,000 miles on it. any answers would be appreciated. thanks! steve |
'Stevie Joe'
Re: clunking noise when turning on zr2
im gunna say CV joint
tastes like burning
i'm thinkin ball joint or tie rod end. put the front end up with a jack under the control arm and wiggle the wheel side to side and up and down. you might feel some play in there. try to figure out which side it makes noise on.
could be torsion bar ramming into the frame, turning really fast puts more flex on a certain side of the truck and causes the sway bar to swing into the frame rail.
chopz33
ball joints
U CaN c Me CoMiNg!
my trucks been doing that but not at fast jus wen like backing up sounds like something mite be rubbing,,,but then at like 70 my truck vibrates alotttt to,,,?
My truck did the same thing. I tried forever to find out what it was. It would only happen when I turned on a hard right. It was in the shop several times and mechanics replaced ball joints, shocks etc. It ended up being the torsion bar mounts. They spilt and cause the torsion bar flex and hit the underside of the truck. They are very cheap to replace.
I'm starting to think those torsion bar mounts are what is making the sound. my tie rods, cv shaft, and ball joints seem fine, but i'm noticing the sound is coming from under my feet. I bet your right. Thanks everyone!
steve |
Big Block's are Bad Ass!!
if it makes a clicking noise when turning it's more than likely a cv joint. If it's a heavier clunking noise it's probobly something else.
| Sponsored Links | |
Advertisement | |
