Camaro rear sway bar position help
Old 09-23-2008, 11:57 AM   #1
1stGen4.3 is on a distinguished road
I recently put a 3rd gen Camaro rear sway bar on my 1st gen S10. I ended up drilling the holes a bit to far back and rotated the sway bar to where it's not quite parallel with the axle. It sits a bit back instead of being directly on top. What I'm curious about is with a sway bar mounted like this (just direct end links mounted to the frame) an I going to run into issues with there being 2 centers of rotation? Also I've been wondering if it's bad to have the bar moved back a bit like that, shold it be parallel with the alxe?
Old 09-24-2008, 12:05 AM   #2
Chevhead89 is on a distinguished road
Re: Camaro rear sway bar position help
could ya get a pic?
Old 09-24-2008, 12:20 AM   #3
bellcranks no more
greencactus3's Avatar
if im picturing what you are saying correctly,
as long as your mounts are stiff enough there should be very little difference.
but a pic will help
Old 09-24-2008, 12:36 AM   #4
The Eye is watching you!!
kamesama980's Avatar
kamesama980 is on a distinguished road
as long as it's parallel to the axle, where it is in relation to the axle doesn't matter. the only reason to put it directly above the axle is that then however you mount it to the axle is only dealing with compression/tension forces rather than trying to keep from twisting around the axle. in other words, if you have to rotate the mounts a little back to make it all work, it's fine.
Page generated in 0.08419 seconds with 12 queries
