All over the place
Old 05-05-2008, 06:42 PM   #1
blakONblaknoma is on a distinguished road
All over the place
every time i drive my truck, i have to chase it all over the road because the steering wheel (from centered) has about 2 inches of play to the left and the right..... What the hell is this???
Old 05-06-2008, 01:30 AM   #2
Got Train Horns?
PSYKO_Inc's Avatar
PSYKO_Inc is on a distinguished road
Re: All over the place
Could be any number of things. Idler arm, center link, tie rod ends, steering box, rag joint, etc. Get under there and check all the components for play.
Old 05-06-2008, 11:30 PM   #3
it has new (by new i mean less than 4 months) upper and lower ball joints both sides inner and outer tie rods center link and idler arm!!
Old 05-06-2008, 11:33 PM   #4
The Eye is watching you!!
kamesama980's Avatar
kamesama980 is on a distinguished road
well you better take it back and have them take a look at it if there's still a problem.
Old 05-06-2008, 11:36 PM   #5
jtrjason's Avatar
jtrjason is on a distinguished road
Do you have power steering or manual? Mine is manual and replacing the gear box cleared all my play right up. if you pitman arm has been on the box long you may want to get a new one, i had to take it to a family friend who had a huge press to get it off.
Old 05-07-2008, 10:15 AM   #6
its power steering, and is there anything before the steering box that might be the problem? some thing in the steering wheel, or shaft or something like that??
Old 05-07-2008, 11:58 AM   #7
jtrjason's Avatar
Just grab the shaft right before it attaches to the gear box and turn it, if it turns, and if it turns the steering wheel then it's probably the steering gear. but you may want to check you p/s fluid levels, if it's low then their might be play.
Old 05-10-2008, 02:16 PM   #8
get off the computer, go outside, jack the front of the truck up, and start grabbing things and shaking them rather than asking us what's wrong when we don't have access to your truck. should find the culprit in under 5 minutes.
Old 05-11-2008, 02:49 AM   #9
She was a Slutty Bitch
TokoDragon's Avatar
TokoDragon is on a distinguished road
if you just replaced a lot of componets up there it could be a defective part or installed wrong, or something came loose. My mom's van had some play in the steering wheel, not to bad, the tie rods had some play so we changed them and it tracks great now.
Old 05-11-2008, 05:46 PM   #10
bagg_n_draggit is on a distinguished road
if the steering gearbox is worn out, you can try to adjust it. there is a t35 torx head with a 16mm jam nut. on the top of the box. center the tires or steering wheel and turn the clockwise about 1/4 turn at a time and keep test driving it. what it does is bring the worm gear in closer and takes some of the slack out of the box.
Old 05-13-2008, 03:22 AM   #11
Got Train Horns?
PSYKO_Inc's Avatar
Also check the rag joint at the steering box and tulip joint at the firewall for excessive play. I'd be almost willing to bet your rag joint may be torn.
Old 05-13-2008, 03:26 PM   #12
orgasmic
dimerunner88's Avatar
dimerunner88 will become famous soon enough
doing that also cause it to wear out faster,its set from the factory. if the box is the problem, replace it. at the least go to the junk yard and get one, maybe even a zq8 box
Old 05-17-2008, 09:57 PM   #13
S15vortecpwr's Avatar
S15vortecpwr is on a distinguished road
that adjusment works great if you are in a bind and do not have the money to buy a new/used box. I tightened my box up on my 78 camaro and it is still great. I just tightened it up about 1/8 of a turn.
I would guess you have a bad rag joint or shaft.
Copyright © 2001-2007 Evil Twins Media, Inc. All Rights Reserved.
Search Engine Optimization by vBSEO 3.1.0
Powered by: vBulletin
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Page generated in 0.12322 seconds with 13 queries
