2wd to sfa - S-10 Forum
2wd to sfa
Old 08-15-2005, 12:51 AM   #1
isenegger's Avatar
2wd to sfa
i was throwing the idea around for puting a cherokee axle under my blazer...it only being 2wd and will never be 4wd....how hard is it to put under there and make the steering work...what all needs to be fabbed up?...
Old 08-15-2005, 07:53 AM   #2
Nice Jorb
cavymeister's Avatar
Re: 2wd to sfa
Why do you want to add a SFA if you're only going to stay 2wd?
Old 08-15-2005, 12:32 PM   #3
isenegger's Avatar
Re: 2wd to sfa
just for the lift.. no need to go offroad
Old 08-15-2005, 05:34 PM   #4
eugenen's Avatar
Re: 2wd to sfa
The biggest problem you will run into is the frame crossmember is right where the axle needs to be. You need like 1 foot of lift just to clear the axle then add more for flex. If your just wanting lift and not 4x4 then look at spindle lifts, long travel control arms, etc.
Old 08-16-2005, 12:15 AM   #5
Re: 2wd to sfa
sfa for the lift sounds like a bad idea no matter the clearance issues with the problems of geting custom leafs or sourcing a pair is a pain, not to mention if you wanted to 4 link.
hell i wouldn't do it because of embarassment and funny looks
edit: i just saw in your sig you already have 8'' of lift, seeing this i think that you should do sfa with watever lift it takes swap a transfercase make it happen and make it all work. it would be a great project and you get some respect from the 4x guys. but please dont put an axle in w/out it hooked up.
Old 08-16-2005, 12:59 AM   #6
isenegger's Avatar
Re: 2wd to sfa
funny looks from 4x4s...haha...half of the z71s and other 4x4 dont even have a front drive shaft....now thats an embarrasment....4 wheel drive and not even a driveshaft...haha...but really how hard is it to weld on some hangers....go with yj springs and a cherokee axle....steering may be hard to do but the ifs guys do it....thanks anyway
