2 wheel to 4 wheel drive. - S-10 Forum
post #1 of 9 Old 05-17-2005, 04:37 PM Thread Starter
Big Block's are Bad Ass!!
Bad Rat 414's Avatar
User is: Bad Rat 414 is offline
I have a'98 S10 and was toying around with the idea of converting it to 4 wheel drive. Is the frame the same on a 2 wheel drive as a 4 wheel drive truck? If I was to find a used axle and spring set up, would it bolt up to my frame. I relize I might have to change the idler and pitman arm also. The trans. or gear box can come later. I'm a diesel truck mechanic so I'm not new to suspension issues. I'm Just wondering if anyone has done this before.
post #2 of 9 Old 05-17-2005, 05:19 PM
Phoenix
BravadaAWD's Avatar
User is: BravadaAWD is offline
Re: 2 wheel to 4 wheel drive.
Way more work than it is worth, find a 4x4 frame if that is what you want.
The 2x is a compleatly different front suspension, mounting points, mounts for the front diff. type of front springs ( yours are coil, 4x is torsion ) actually the frame from the cowl forward is compleatly different.
92 Bravada 4.3 tbi, I should have a V8
Some learn by example, Some learn by being the example
post #3 of 9 Old 05-17-2005, 05:19 PM
Master Shake
85S10Eric's Avatar
User is: 85S10Eric is offline
Well, the "easiest" way to make a 2wd S-10 into a 4wd using other 4wd S-10 parts is gonna be to swap frames. See, the whole front half of the frame for a 4wd S-10 is totally different; suspension mounting points, crossmember design, etc. So simply getting a 4wd S-10 T-case and front diff isn't gonna work without tons of fabbing work.
If you could find a 4wd chassis and running gear of the same body configuration, it would work and you'd just have to swap over the front clip, cab, box, etc from your truck.
Otherwise, your only other option is a solid axle swap. And there's been plenty of people who've done that, there's a section in the "Liftin It" forum for SFA (solid front axle) conversions here: http://www.s10forum.com/forum/f221/solid-axle-thread-68267/
post #4 of 9 Old 05-17-2005, 05:32 PM Thread Starter
Thanks for the info. I had a feeling the frame was differant but I just didn't know. A frame swap is out of the question. This truck is just in too good shape for all that.
post #5 of 9 Old 05-18-2005, 03:12 PM
Surf Naked
DanMan2k06's Avatar
User is: DanMan2k06 is offline
Yea definately not worth the cash. Once you factor in the frame, front and rear axles, driveshafts, transfer case, steering components, new leafs and coils, shocks, it adds up to more than a 4x4 s-10 would be complete. Just be content or find another truck
post #6 of 9 Old 05-19-2005, 08:19 AM
Insane Network Engineer
rlith's Avatar
User is: rlith is offline
Send a message via AIM to rlith
Actually 4x4's dont use coils, they use torsion bars.. But I agree with what yer saying. Also the ECM would need changed as well as the engine harness, the body harness would have to be changed, and all the tiny parts that have to be added with the big parts. The only way to do it at a reasonable cost would to buy a wreck and hope the frame is ok..
See my ride at
http://www.pghconsulting.net/teal
and www.s10planet.com
Support Sattelite Radio! Goto www.siriusbackstage.com
rlith is offline
post #7 of 9 Old 06-03-2005, 07:38 AM
User is: 99s10lt1 is offline
I have a 99 2 door blazer LT1 that i want to convert to 2 wheel drive, if anyone has a 2 wheel drive frame from a 2 door i would be willing to swap. Full rolling frame W/axels + suspension.
99s10lt1 is offline
post #8 of 9 Old 06-08-2005, 10:04 PM
One Piece At A Time
sic ones's Avatar
User is: sic ones is offline
Send a message via AIM to sic ones Send a message via MSN to sic ones Send a message via Yahoo to sic ones
I just got done putting my S-10 4x2 on a 4x4 frame about 6 months ago. Really no issues with that swap other than having to cut a hole in the floor for a shifter, which if you got a later model 4x4 frame(which you would prolly have to), you would prolly have electronic 4WD. The frame harness bolted right up to my distribution block with no issues. Theres only a few wires here and there that were out of place, but were easy to hook up.
One Piece At A Time -1989 Single cab short-bed 4x4
305 V8. Undergoing SM465/NP208 and solid axle swap.
Hell Hound-1992 Blazer Tahoe 2-door 4x2 4.3L Vortec V6/4L60-E. The new fixxxer-upper.
sic ones is offline
post #9 of 9 Old 06-09-2005, 08:33 PM
F u c k Wyotech
nigels_world's Avatar
User is: nigels_world is offline
Send a message via Yahoo to nigels_world
sfa on coils would be the way to go..........
poop
