ZQ8 shocks the best? - S-10 Forum
post #1 of 20 Old 05-30-2009, 01:28 PM Thread Starter
Registered Pimp
x98zq8x's Avatar
User is: x98zq8x is offline
I was wondering if ZQ8 bilstein shocks are pretty much the best you can get or some aftermarkets are better. I get all GM parts half off, but even with that i think its still about $330 all around for the bilsteins.
x98zq8x is offline
post #2 of 20 Old 05-30-2009, 01:33 PM
User is: 616 of 933 is offline
Re: ZQ8 shocks the best?
Bilstein had a sale going buy 3 get one free.
post #3 of 20 Old 05-30-2009, 03:54 PM
User is: beedle4 is offline
Get the part numbers most bilsteins run 60 each at auto zone.
beedle4 is offline
post #4 of 20 Old 05-31-2009, 01:14 AM Thread Starter
Registered Pimp
x98zq8x's Avatar
thanks
x98zq8x is offline
post #5 of 20 Old 06-11-2009, 10:59 AM
User is: MySSS10 is offline
Send a message via Yahoo to MySSS10
I installed Monroe reflex shocks on my S10 and they work just fine. I think Blistenes are over rated. There are a pair of 90 deg S curves near my apartment and I take them at between 55 and 60 mph all the time. I could probably go faster the 60 thru them but I need new tires before I try that. I'm a retired GM technican and also test drove cars at Milford Proving Grounds GM has one of the best drivers training programs around, Burt I'd still like to go to Bondarant just to drive a Z08 Vette that's one GM car I never got to drive.
MySSS10 is offline
post #6 of 20 Old 06-12-2009, 08:42 PM Thread Starter
Registered Pimp
x98zq8x's Avatar
Cool, thanks!
x98zq8x is offline
post #7 of 20 Old 06-19-2009, 10:32 AM
I've been trying to find the rear axle damper for my S10 but the dealers don't have them because they are out of production. But I'm thinking I might have brackets welded to the left rear axle and frame and have two steel rods with hyme joints to keep the read end from torqueing forward. What you think?
MySSS10 is offline
post #8 of 20 Old 06-19-2009, 08:12 PM
Registered Un-dependent
Mechnix's Avatar
User is: Mechnix is offline
every hyme joint I have ever seen is worn out way before it should be.
Try the S-10 Warehouse (find him on Ebay) might have a good used one?
Mechnix is offline
post #9 of 20 Old 06-20-2009, 11:56 AM
Yes I know they wear out it's either the yhme joints or probably poly bushings. I was thinking I could adjust the load side to side to control the rear axle rotation to reduce wheel hop. BTW has anyone run the Caltrak bars on an SS with the swaybars inplace?
MySSS10 is offline
post #10 of 20 Old 06-20-2009, 12:23 PM
Caltracs should not get in the way. Also they just prevent axle wrap
post #11 of 20 Old 06-22-2009, 10:10 AM
Hey man thanks for to info I get some real axle wrap with the damper and would like a bit more control without effecting the handling in the curves.
MySSS10 is offline
post #12 of 20 Old 07-02-2009, 03:11 PM
Thanks For Your Support
terryl's Avatar
User is: terryl is offline
http://www.s10forum.com/forum/f178/n...tory-d-166926/
See post #3
02 Black S-10 Xtreme ext. cab 4.3, additional 2/2.5 drop and a bunch of other stuff
terryl is offline
post #13 of 20 Old 07-04-2009, 12:42 PM
burnt rubber's Avatar
User is: burnt rubber is offline
I bought all bilstein shocks including hop shock from bilstein canada in B.C. Also have head office in San Diego. Best shock in my opinion.
Front B46-1307
Rear B46-1681
Hop shock 15998533
ZZ4 motor, TH350 with shift kit,78 camaro 8.5 housing narrowed with strange (torq-line) diff , bear street-strip axles and c-clip eliminators and richmond 3:42 gears. Complete zq8 suspension, including hop-shock & bilstein shocks.
post #14 of 20 Old 07-11-2009, 07:36 PM
User is: blackzq8 is offline
When you look up that part#, and it gives you a price...Is that for one, or two shocks?
Another dumb question...What is a "hop" shock and where is it located/whats it do?
03' ZQ8 s10
3.5" total drop
Steel roll pan
tinted windows,smoked tails
!badges
blackzq8 is offline
post #15 of 20 Old 08-14-2009, 11:13 AM
User is: mrkilldee is offline
I need the Monroe parts numbers, my funds are tapped and I need shocks, my part stores are staffed with morons who will sell you anything. No ZQ-8 parts category in the shocks listings.
post #16 of 20 Old 08-15-2009, 11:23 AM
tigmaned's Avatar
User is: tigmaned is offline
i installed some Gabriel over load shocks on the front of my Xtreme. $80 sold by the PAIR. they have a small coil spring rapped around the shock, the ride is alot better then what i had and great price at AutoZone. military discount too.
tigmaned is offline
post #17 of 20 Old 08-15-2009, 09:21 PM
Did they have the right listing for your extreme, most stores Ive been to dont show a listing for ZQ8 trucks?
post #18 of 20 Old 08-18-2009, 07:46 AM
tigmaned's Avatar
just asked me if it had sport suspension?
the way GM lowered the xtreme i don't think it matters, and they where the same length as the ones i took out. raised my front end just a little. the ride is alot better over most bumps in the road, not so hard.
didn't get the same type for the rear, with no weight in the back i want a better ride empty.
tigmaned is offline
post #19 of 20 Old 10-18-2009, 09:32 AM
vstone420's Avatar
User is: vstone420 is offline
I run Belltech all the way around they work pretty good run between $40 - $60 each depending on which ones you get.
post #20 of 20 Old 10-22-2009, 10:51 AM
iroc2nv's Avatar
User is: iroc2nv is offline
I have a set on my blazer, i guess the guy before me wanted them on there. Great guy !
iroc2nv is offline
