What does the ZQ8 suspension consist of? - S-10 Forum
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > Xtreme / ZQ8
Old 03-24-2002, 01:46 PM   #1
What components make up the ZQ8 suspension?
Spindles
Springs
Shocks
Etc....
I would like to lower mine a little more but am in fear if I buy 2" spindles I will already match what I have and be at the same height because there might already be 2" spindles on it. I think you know what i'm getting at.
Old 03-24-2002, 01:55 PM   #2
Resident Wetback
suicidal's Avatar
On the ZQ8 suspension, the springs are 2" shorter, the spindles are like any other S10. If you get 2" spindles, you'll have a 4" total drop up front.
Old 03-24-2002, 02:17 PM   #3
What method is used for the rear?
Old 03-24-2002, 02:21 PM   #4
Resident Wetback
suicidal's Avatar
lowered leafs in the back. you could get away with installing blocks to lower the back.
Old 03-24-2002, 03:14 PM   #5
Ok so I could just pick up a set of 2" spindles and 3" blocks and have a total of 4/5 drop? Would I have to change my shocks or get rid of the bump stops?
Old 03-24-2002, 03:38 PM   #6
Deadbeat
CynicX's Avatar
ya but it would be more like a 3.5/4.5 drop.....if you use spindles and blocks u will not have to do anything with the shocks....the mounting distances will stay the same...you might want to get stiffer shocks if you haul a lil somethin something every now and then but the zq8 shocks are actually real good drop shocks.....with a 3" blocks on top of the zq8 leafs you'll probably want to cut the bump stops off in the back....to the frame....becuase i would bottom out into the bumps over just about every bump...when i cut them off the ride quality increased a 100% easy.....here is step for step how to cut the bumps off from 98 ss on nos..... http://www.s10forum.com/forum/showth...ight=bumpstops
