How do I drain radiator? - S-10 Forum
post #1 of 7 Old 12-19-2002, 05:26 PM Thread Starter
User is: 2000X is offline
I am going to install a 180 thermostat in my 2000X. How do I drain the radiator? Is there a valve somewhere that lets it drain or do I have to remove one of the hoses? Do I even need to drain the radiator?
Jeff
2000X is offline
post #2 of 7 Old 12-19-2002, 06:05 PM
chuy611's Avatar
User is: chuy611 is offline
Send a message via AIM to chuy611 Send a message via Yahoo to chuy611
they way I drain the radiator, not sure if its the right way, is pull the lower hose
97 ext cab v6
Envoy front end
Shaved Attenna, washers, tailgate handle, molded rollpan.
Dropped 3,4
chuy611 is offline
post #3 of 7 Old 12-19-2002, 10:31 PM
I BURN THINGS
Flamed 98's Avatar
User is: Flamed 98 is offline
Send a message via AIM to Flamed 98 Send a message via Yahoo to Flamed 98
On the bottom of the passenger side radiator there is a green valve. Thats the easy way to drain it.
post #4 of 7 Old 12-26-2002, 10:55 PM
lower than you
addiction's Avatar
User is: addiction is offline
bottom passanger side has a drain and a drain hose.
the impossibly possible.
post #5 of 7 Old 12-27-2002, 12:25 AM
y2kblkxtreme's Avatar
User is: y2kblkxtreme is offline
Send a message via AIM to y2kblkxtreme Send a message via Yahoo to y2kblkxtreme
dont be a pvssy, just undo the two bolts, pull out the old thermostat, put in the new one, and bolt it back on, you'll lose like a cup of fluid, then just wipe up the fluid, dont drain the whole thing for crying out loud, you kids and your damn way of making everything difficult
05 silverado z71-9" lift and 37's
00 s10 - under construction
95 Mustang Cobra Drift Car
95 cbr 600 stunt bike
post #6 of 7 Old 12-31-2002, 02:00 PM
Un-Blown Fake ZQ8
s10rz350's Avatar
User is: s10rz350 is offline
Personally I dont like something that eats away paint and rubber when it leaks on my engine. Draining half a litre of coolant out the of the radiator clears up the hose above the stat itself. Squeeze the hose above the stat that will push any left over coolant passed the stat so you dont drip coolant everywhere when you take it off.
Truck is gone...
s10rz350 is offline
post #7 of 7 Old 12-31-2002, 02:06 PM
NCHEVYHEVN
Guest
Posts: n/a
User is:
If you do decide to drain the whole radiator go ahead and flush the motor as well since the thermostat is off.
