Eliminating the double cardan drive shaft - S-10 Forum
 1Likes
  • 1 Post By burnt rubber
post #1 of 41 Old 02-21-2012, 12:06 AM Thread Starter
ineedabeeah's Avatar
User is: ineedabeeah is offline
I'm changing the rear double cardan drive shaft to a 1 piece rear shaft from the center bearing mount back to the pumpkin...for those who have done this...Is it a one or two man job and how long should I dedicate for the install.
Thanks again
post #2 of 41 Old 02-21-2012, 12:23 AM
whitelowereddime's Avatar
User is: whitelowereddime is offline
Re: Eliminating the double cardan drive shaft
in so i can read later
post #3 of 41 Old 02-21-2012, 12:35 AM
Hillbilly sold the mini
billybob88's Avatar
User is: billybob88 is offline
always better to have help if you can get it..and dont worry about how long you should take..just do it right the first time.
1984 Silverado 3/4 ton- 454
2000 Red xtreme- SOLD
2003 GMC Sierra HD
post #4 of 41 Old 02-22-2012, 12:36 AM Thread Starter
I plan on having an assistant, my concern is when I start I need to know approximately how long I can expect for the install to take, because I would have to have it done by mid day to go off to work. Am I wishful thinking?
post #5 of 41 Old 02-22-2012, 03:27 AM
thebiggulp's Avatar
User is: thebiggulp is offline
I am replacing my double shaft tomorrow with a 1 piece aluminum, tomorrow. And doing it by myself. I will let you know
2002 Sonoma
4.3 V6
Automatic
Belltec 2" Lowering Spindles
Custom 2" Lowering Blocks
rear disk brake and differential
1 piece aluminum drive-shaft
post #6 of 41 Old 02-22-2012, 03:30 PM
thebiggulp's Avatar
took me 30 mins from jacking to lowering to install shaft
4 - 5/8 bolts
2 - 11/16 bolts
but I do have a rub from the bed support
2002 Sonoma
4.3 V6
Automatic
post #7 of 41 Old 02-22-2012, 03:36 PM
SMURF
ridinlow's Avatar
User is: ridinlow is offline
4 - 5/8 bolts
2 - 11/16 bolts
Pics????
ridinlow is offline
post #8 of 41 Old 02-22-2012, 04:04 PM
thebiggulp's Avatar
2002 Sonoma
4.3 V6
Automatic
post #9 of 41 Old 02-22-2012, 07:38 PM
Banned
User is: OrangyX is offline
Hmmmm
OrangyX is offline
post #10 of 41 Old 02-23-2012, 12:29 AM Thread Starter
Thank you....sure does help me making a decision on when to start the replacement....btw, looks good, congratulations...
post #11 of 41 Old 02-23-2012, 12:56 PM
Banned
Rubbing is not good,watcha gonna do ??
OrangyX is offline
post #12 of 41 Old 02-24-2012, 01:57 AM
thebiggulp's Avatar
well, it is finally finished. The one man job turned into a two man job and lift, hammer, sawzall
Once we cut the support out so the drive shaft could turn freely, it than would hit under acceleration on the trans hump, so we had to beat that up about 3/4 of an inch and now I just need to get the shims, so that under HARD WIDE OPEN THROTTLE it does not rub. My shaft is about running even from trans to rear-end and that is not good
So I am getting 2 degree shims or maybe 3 degree, and that will cure the problem
2002 Sonoma
4.3 V6
Automatic
post #13 of 41 Old 02-24-2012, 02:41 AM
User is: blacksonoma is offline
I swapped my double cardan shaft with a ref 2 piece shaft and had to change the part on the rear end the shaft bolts to cause the pattern was diff but ended up putting the double cardan shaft back in cause it is noticably smoother at highway speeds
post #14 of 41 Old 02-24-2012, 02:44 AM
thebiggulp's Avatar
This is aluminum, so I am hoping the freeway rpm's it is smooth compare to a steel one piece. Aluminum should absorb some vibration
Will give an update tomorrow
2002 Sonoma
4.3 V6
Automatic
post #15 of 41 Old 02-24-2012, 12:11 PM
Banned
Thanx I would get my $ back if it was me.....
OrangyX is offline
post #16 of 41 Old 02-24-2012, 08:23 PM
Big Huckin' Chicken
User is: Slick_Nick is offline
What's the benefit of changing to a one piece? Sorry for the n00b question...
post #17 of 41 Old 02-24-2012, 08:42 PM
LSxtremin FoLyfe
02dime's Avatar
User is: 02dime is offline
http://www.s10forum.com/forum/f13/al...-piece-198565/
1999 4dr 2wd Jimmy ,3" DJM drop coils/blocks & ND2 shocks, 2nd gen ZQ8s, LS swap coming soon
02dime is offline
post #18 of 41 Old 02-25-2012, 12:20 AM
Maybe later.
tytotheler92's Avatar
Part of me has a real problem with this even though its an interesting idea because of the fact that this is a truck. I mean, don't you use the bed for hauling stuff at times? Doesn't anyone realize that when you haul something with some weight the pinion angle will change and you will have at best rubbing, and possibly a broken drive shaft and a bent up undercarriage?
Maybe I'm misunderstanding something here, but the risks WAY outweigh the benefits as I see it.
2016 Toyota Tacoma TRD Sport 6 speed
1985 S10 Blazer 4WD
post #19 of 41 Old 02-25-2012, 12:29 AM
DaGuse5853Z's Avatar
User is: DaGuse5853Z is offline
I'm so glad that my ext cab doesnt have the double cardan driveshaft. Does anyone swap over to the 2 piece driveshaft? 3 u-joints and a carrier bearing is better than worrying about stuff rubbing if it's a daily driver
SS wannabe '96 Ext Cab 4.3L, 5 Speed, '98 Trans Am G80 diff swapped into an originally equipped 2.2L slush box.
post #20 of 41 Old 02-25-2012, 01:06 AM
Maybe later.
sooooo, wait. A stock height S-10 has no carrier bearing, but an xtreme does? That makes alot of sense actually.
1985 S10 Blazer 4WD
post #21 of 41 Old 02-25-2012, 01:42 AM
thebiggulp's Avatar
No EXTENDED CAB has bearing, EXTREME/ZQ8 has CV JOINT Driveshaft
Regular Cab, has straight driveshaft
2002 Sonoma
4.3 V6
Automatic
post #22 of 41 Old 02-25-2012, 01:53 AM
Maybe later.
Isn't this the carrier bearing?
If so, my extended cab def has one.....
Sorry for the random picture, I just googled for one.
1985 S10 Blazer 4WD
post #23 of 41 Old 02-25-2012, 02:13 AM
thebiggulp's Avatar
If you are EXTENDED CAB, you defintley have one. They do not come any other way from factory. You have 2 drive shafts, connected in the middle with a Carrier/Center Supoort Bearing
2002 Sonoma
4.3 V6
Automatic
post #24 of 41 Old 02-25-2012, 02:14 AM
LSxtremin FoLyfe
02dime's Avatar
^^ my zq8 has the carrier bearing as pictured above
02dime is offline
post #25 of 41 Old 02-25-2012, 02:16 AM
thebiggulp's Avatar
Why is everyone confused
2002 Sonoma
4.3 V6
Automatic
post #26 of 41 Old 02-25-2012, 03:47 PM Thread Starter
Ok, just finished my install...went smooth, done in about an hour....no more double cardan shaft...runs real smooth. I had installed the JTR alignment kit last week and the vibration all but disappeared, but with the shaft changed out the noise (rattle) and minimal vibration disappeared....time for another beer...
post #27 of 41 Old 02-25-2012, 04:36 PM
Maybe later.
Thats why.
1985 S10 Blazer 4WD
post #28 of 41 Old 02-25-2012, 06:43 PM
Banned
One piece driveshaft ???
OrangyX is offline
post #29 of 41 Old 02-25-2012, 09:59 PM Thread Starter
No still a two piece...just the rear shaft with the double cardan was changed.
post #30 of 41 Old 02-25-2012, 11:31 PM
Banned
Where did you get it at ??
OrangyX is offline
post #31 of 41 Old 02-26-2012, 12:14 PM Thread Starter
I got it from:
http://stores.ebay.com/Trans-Axle-Dr...id=p4340.l2563
All I can say, Greg at that store is a very stand up kind of guy! Great communication and fast shipping.
post #32 of 41 Old 09-10-2012, 09:27 PM
User is: Neeseius is offline
Send a message via AIM to Neeseius
I have the same conversion as you, but I've got a 3 inch drop in the back 2 inch in the front. I have massive vibration issues at high speed but i haven't shimmed it yet. PLEASE tell me what degree shim kit you used or exactly what you did to eliminate vibration
Truck - '03 Sonoma ext. cab 2wd auto 3.42gears
Motor - '99 4.3L vortec, .030 over; Comp 266HR .533 lift; comp 1.6 roller-tip rockers; Ported Vortec heads; Mach Performance PCM calibration; Hooker 1 5/8 Super Comp headers; E-fan
14.44 @ 95.53 MPH 1/4mile 2.18 60ft
Coming soon - Stealthram; and 13s
Neeseius is offline
post #33 of 41 Old 09-11-2012, 12:24 PM
Banned
Best $ ever spent !!
http://www.jagsthatrun.com/Pages/Par...aft-Align.html
OrangyX is offline
post #34 of 41 Old 09-11-2012, 01:14 PM
brent769's Avatar
User is: brent769 is offline
I too have changed my driveshaft out so I don't have the double cardan joint. I have the 3 degree shims but haven't installed them yet because my u-bolts are rusted on pretty bad. Does anyone know where I can get new u-bolts?? It is a stock height xtreme.
Red Sports Side 1999 S10 Xtreme ext. Cab. 4.3L V6, automatic transmission
brent769 is offline
post #35 of 41 Old 09-11-2012, 03:49 PM
I make pneumatics
262X02's Avatar
User is: 262X02 is offline
Send a message via AIM to 262X02
You should be able to get universal u-bolts at any parts store and cut the length down after install.
Brandon
06 TBSS AWD - my DD
10 MKV Jetta TDi - wife's DD
02 Xtreme, 4.3L, 5-speed, K&N FIPk, B&M shifter, Blazer DP Front Brakes, LS1 Disk Rear Brakes, PermaCool e-fans, Flowmaster 40 dual side exit, Marine Intake Manifold, CompCams 270AHR, CompCams High Energy Lifters, Cloyes Timing Set, MSD coil, Taylor 8.2 wires, PLX Wideband, HPTuners Pro, 39lb EV6 Bosch Injectors
Coming Soon: Turbo, Syclone headers & crossover, new Magnaflow exhaust
262X02 is offline
post #36 of 41 Old 09-11-2012, 03:51 PM
I make pneumatics
262X02's Avatar
You'll need to measure the degree of the driveshafts at different points to determine how far you are off and the shims you will need. The 3 degree shims usually work for most but you may need more or less depending on how bad the alignment is of the driveshafts.
Brandon
06 TBSS AWD - my DD
262X02 is offline
post #37 of 41 Old 09-14-2012, 11:40 PM
Originally Posted by ZQ8LS1 View Post
I did purchase this and I got the 3 degree shim kit. I threw the carrier bearing spacer in the trash obviously. I can't decide whether or not to use the tranny mount spacer since this setup was designed for the 2 piece shaft with a center piece. Also, trying to measure angles under my truck using a basic angle measure proved to be too difficult. I couldn't find flat surfaces other than the drive shaft and I couldn't read the needle.
My motor mounts are broken so I got a set of energy suspension polly's. Does anyone know if using polly motor mounts with a regular tranny mount puts the bell housing in danger of cracking?
Neeseius is offline
post #38 of 41 Old 09-15-2012, 09:29 PM
I misread this thread. I actually have a 1 piece drive shaft. I got rid of the 2 piece shaft, double cardan, and carrier bearing completely
Neeseius is offline
post #39 of 41 Old 09-16-2012, 09:39 AM
burnt rubber's Avatar
User is: burnt rubber is offline
Whan i bought my 2002 xtreme ( 4.3 , auto , extcab ) someone had taken out both parts of the 2 piece shaft including center bearing and put in a 1 piece but it rubbed sometimes and had a bad shake on deacceleration on the highway. After some salvage yard hunting and info from this site, i got a 2 piece shaft ( with no cardan joints )with center bearing out of a 91 s-10, 2wd, 4.3, auto , ext cab and grabed the yoke while i was there. I got it balanced just to be sure and proceeded to put it it in. After about a 1 hour install ( including 3 degree pinion shims from jtr) , I took it for a run, no vibrations at any speed and no rubbing. Didnt seem to need the rest of the kit from jtr, go figure .Best of all next time a joint goes its easy and cheap to change. By the way this install means no beating or cutting on floor or cross members and no cutting of the drive shaft.
FoaRyan likes this.
ZZ4 motor, TH350 with shift kit,78 camaro 8.5 housing narrowed with strange (torq-line) diff , bear street-strip axles and c-clip eliminators and richmond 3:42 gears. Complete zq8 suspension, including hop-shock & bilstein shocks.
post #40 of 41 Old 09-21-2012, 10:23 PM
brent769's Avatar
Wish I had your luck! I just installed my 3 degree shims from JTR, but I still have some vibrations. I'll probably make my own spacers (for trans. and carrier bearing) and see if that makes them go away.
brent769 is offline
post #41 of 41 Old 10-14-2012, 10:21 PM
User is: NickC978 is offline
just get a single cardan drive shaft i just got one and its working just fine. i had gotten the shims for 3* but didn't end up needing it once i had changed to a single.
NickC978 is offline
