All of your 2/3 drop info here!
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > Xtreme / ZQ8
Old 07-13-2007, 08:30 PM   #251
Hates 'know-it-alls'
grndscrpr03's Avatar
grndscrpr03 will become famous soon enoughgrndscrpr03 will become famous soon enough
Re: All of your 2/3 drop info here!
Quote: Originally Posted by 2LO4SNO
come to think of it, why the hell would i need to even touch the front bumps..N/M that part lol
you don't, the spindles will not change the amount of clearance between the LCAs and frame
Old 07-14-2007, 12:13 AM   #252
DREAM XTREME
2LO4SNO's Avatar
2LO4SNO is on a distinguished road
do i need to lose the hop shock?
Old 07-14-2007, 02:12 PM   #253
Teh S10Forum Hawk
HAWK's Avatar
HAWK will become famous soon enough
i dont believe you have to, but i would i never was a fan of the hop shock idea
Old 07-24-2007, 12:52 PM   #254
bellcranks no more
greencactus3's Avatar
most likely you wont. so might as well leave it there
Old 07-26-2007, 10:59 PM   #255
Derrick
tightextreme03's Avatar
tightextreme03 is on a distinguished road
i know some people have asked on here about the rear bumpstop. i have an xtreme that i lowered only the rear with 3" blocks (flat, and yes i did have some major vibrations, i have since removed the blocks). i did not remove the bumpstops and i did bottom out alot and sometimes so hard i thought i crushed my spine, but all and all i loved the look of the truck with the stock zq8 front and zq8+3" block rear. kinda made it look like the guys with bags that ride around with the front up and rear down. just a little info some people might find helpful!
Old 07-27-2007, 05:53 PM   #256
Flawless22 is on a distinguished road
How much tire rub do you get with those 18s? and what size tire are you using? I want to do this but put ither 18s or 20s on and am trying to figure out what size tire and rims i should go.
Old 07-28-2007, 12:31 PM   #257
http://www.s10forum.com/node/47
Old 08-27-2007, 03:39 PM   #258
mjvoket8 is on a distinguished road
Hey guys I just got an 01 Blazer extreme and I'm going to do the 2/3 drop. For the blazer, should I get the angled blocks or are the regular blocks fine? Also, I am new to the whole "chevy lean", any one out there have have any in put as to wheather or not I should get the spacers even for a blazer, not sure if they get the "chevy lean" or if its more the trucks. Thanks for the help.
Old 09-09-2007, 02:10 AM   #259
Drop & Destroy
G473R's Avatar
G473R is on a distinguished road
I dropped my xblaze lower than you plan on doing. I used angled blocks and yes I would get those too. Heard lots of people that used straight ones and had some major vibrations cruisin down the road. As far as the lean. I got a spacer and forgot to put it in when I did my drop. I can't really tell if it is leaning or not, doesn't look like it. Do you need one? Up to you. I'm sure if I measured ground to fender I would find out mine is lower on one side.
Old 09-13-2007, 08:11 PM   #260
xtreeeme
tiightclipse's Avatar
tiightclipse is on a distinguished road
hey guys alright im trying to decide on 18's and 2/3 drop or 20's and no drop if i got 20's and 2/3 will i have problems rubbing or anything without cutting all the stuff out or will it be easier to get 18's and not cut anything becuase i really dont want to cut anything i just want a good stance with some rims lets me kno thankssss
Old 09-13-2007, 09:27 PM   #261
bellcranks no more
20s/no drop is fugly
Old 09-16-2007, 02:52 AM   #262
Drop & Destroy
G473R's Avatar
I'm not sure how much of a difference it is between the xblazer and the xdime but I dropped mine on 20's, running 245/35 20 up front and I don't rub except on a full lock. And it's catching the sway bar from what the rub marks look like. On the s10 it could be diff, but I don't think you would have to much of a problem runnin 20's. Width is the factor really, not size of rim. Unless if on your s10 droppin it on dubs would catch the fender at the top...s10 guys help him out?
Old 09-16-2007, 03:56 PM   #263
S-Clusive North Texas
bwhitfield24's Avatar
bwhitfield24 is on a distinguished road
Blazer X's are 2 inches higher than Truck X's at the fenderwells. I measured myself
Old 09-27-2007, 07:49 PM   #264
Back_N_Black's Avatar
Back_N_Black is on a distinguished road
Quote: Originally Posted by chizwizdiz
With the 2/3 drop, can you use stock wheels and tires? Also anyone know any shops near louisville, ky that can help me with air bags?
Im outta Mount Washington, Kentucky right outside of louisville try Cool Cars, they also have plenty of goofy looking wheels and youve probable seen the convertible colorado running around at shows like Carl Caspers
Michael
Old 09-27-2007, 07:57 PM   #265
So I my truck sits stock right now, Its an 00 Xtreme and i wanna lower it 2/3 seems decent enough, but my questeon is with stock wheels and tires should it rub after an alignment? And if it does where? Rubbing sounds like something to worry about and i dont wanna F something up, i love the look of the drop but im not sure if its worth the risks if there are any that is . . . i worry a lot lol. Ive wanted an Xtreme since 8th grade now that ive saved and finally got one as a graduation presant i dont wann screw it up.
Michael
Old 09-28-2007, 08:30 AM   #266
Teh S10Forum Hawk
HAWK's Avatar
you'll be fine....... extremely minimal if anything (rubbing wise) nothing to trip about.
Old 11-07-2007, 06:28 PM   #267
slvrs10 is on a distinguished road
So here's my deal. My neighbor sold his ext cab S-10, and I bought his 2/3 drop kit. It was an extended cab, mine's an extended cab. The blocks are completely square all around, so I assume when he bought the kit back in '01, he didn't know he needed angled ones. I guess it's obvious if they're angled?
I have a rattle/rub/grind sound, that makes a constant sound when I'm at a constant speed, it sounds almost rotational when I slow down (it slows when the truck does), and starts to make noise as soon as I get going. It doesn't feel like something is knocking or anything, just simply the sound of rattle/rub/grind. Definitely from the rear end. Got the rear drums machined today, still there. I'm trying to figure out if it's do to having a tonneau cover with no tailgate (currenty being shaved), and maybe something it rattling, no idea.
But yeah, it might be a heat shield or something stupid, but the fact it sounds like a rotational noise when I slow down leads me to believe it's something in the rear end. If it's the blocks (or even if not) I have access to a machine shop, so I could angle the blocks myself, see if it works, and go from there.
Thanks in advance.
Old 11-07-2007, 06:36 PM   #268
bellcranks no more
measure your pinion angle
Old 11-07-2007, 06:47 PM   #269
Well, crawling under there is gonna be tough. What can I deduce from the angle I get?
Old 11-12-2007, 01:14 AM   #270
Teh S10Forum Hawk
HAWK's Avatar
look at your driveshaft, there is whats called a dust shield (??i think thats what it is) on it at the front...... it looks like a half circle at the front of it, check to see if that lost its seal if you dont see it, just bang around a bit at on your driveshaft to see if it rattles... if so grind the bastard off and carry on with your life.
that happend on my truck, and it showed a lot of the same symptoms yours is showing
Old 11-18-2007, 10:46 AM   #271
Thanks for the help guys. Turns out it was this stick (more of a branch actually) that got itself stuck between the heat shield, gas tank, and was resting on the driveshaft. Pulled it out, and the sound was gone.
Old 11-19-2007, 02:46 PM   #272
Teh S10Forum Hawk
HAWK's Avatar
i was somewhat right eh?
Old 11-25-2007, 06:54 PM   #273
low "N" slo
03xs10's Avatar
03xs10 is on a distinguished road
Ok guys i have read through here and got some good info, i have a extreme ext cab and will be ordering this kit with the angeled blocks, will there be worry of pin. angle? And can a shop cut the bump stops for me?
Old 11-29-2007, 01:15 PM   #274
Teh S10Forum Hawk
HAWK's Avatar
man you can the stops yourself no problem..... sawzall or even an angle grinder... its really easy...
that and black can of rustoleum paint and ur set.
dont worry about pinion angle problems.
Old 11-29-2007, 05:45 PM   #275
low "N" slo
03xs10's Avatar
Thanks for the reply, found the how too.
Old 11-30-2007, 05:16 PM   #276
never scared
Undaunted's Avatar
Undaunted is on a distinguished road
Ok, i dont know if this question has already been asked (didnt want to read every last post), but if I already lowered my s10 and noticed that I got the chevy lean, but I whent ahead and got my wheel alignment. Later if i corrected the lean would I need another alignment?
Old 11-30-2007, 06:18 PM   #277
Yep.
Old 12-04-2007, 10:46 PM   #278
Teh S10Forum Hawk
HAWK's Avatar
i would not worry too much about it,
its not going to to change it much at all.
hell s10s lean when the tank of gas is full... so your tires will never wear even. lol
worse comes to worse, clean your tires very very good, then drive into some sand and roll out, if the sand hits your tire it makes a lighter color on the tire, when it doesnt come in contact its just still black.. check to see if theres any uneven wear that way, or just chekc on your tires everyonce and a while. if they look like they are wearing shitty take it back to the shop and say they did a shitty job and you want them to do it again. lol
Old 01-02-2008, 09:57 PM   #279
Killerzmurf is on a distinguished road
Hi, Just bought a 2002 ext. extreme and drove it from atlanta to chicago. To put it simple, it drives really bad.
1. The rearend vibrates while accelerating so I guess it's the rear blocks that isn't angeled.
2. But worse is the frontend wich makes a "metal-metal vibrating, like something is loose sound" on the drivers side, it only happens when i drive on bad asphalt etc.
3. When crusing on the highway it's a pain to keep straight and the car is very bumpy. The frontend feels loose, there's around 1" freemovement on the steeringwheel.
I'm sorry but I'm from Norway so I have some problems finding the words sometimes. Hope "freemovement" does the trick for you.
As you can see on the pic, it has an unlevel lowering. It's very low in the front compared to the rear. I was thinking this could cause the problem with the feeling of a loose frontend and bumpy riding experience. Maybe worn out shocks and bushings from driving in this angle?
hope you guys could help me out.
http://img110.imageshack.us/my.php?image=b57412ug6.jpg
Old 01-06-2008, 03:14 AM   #280
Teh S10Forum Hawk
HAWK's Avatar
k where to start.........
you need to check to see if those are the stock zq8 springs in there, or if they are aftermarket, also check to see if it has lowering spindles on it.. i wanna know how it was lowered up front. (springs or spindles)
the front end movement means you need new upper and lower control arm bushings im about 99% sure... while your in there go ahead and replace the idler arm and check the pitman arm too. that will fix the loose feeling.. check your tie rods as well. this should also explain the metal on metal feeling... no bushings = metal on metal.
from your picture it looks like there may only be a 2" block in there??? measure it to see for sure and you can easily tell if they are angled or not just by looking at them..
worse comes to worse take a picture of it and ill tell you how much of a drop the block is and if its angled.
let me know if you need anything else
it looks to me to have a 2/2 drop on it
kevin
Old 01-08-2008, 12:58 AM   #281
cincystepside00 is on a distinguished road
ok so i'm hoping you guys don't chew me too bad on this but this is the most informative thread i've found about dropping so far and i have a question not dealing directly witht the 2/3. i have an 00 zq8 that i want to sit even not necessarily*sorry for the spellin im a lil drowsy* a full drop. could i just drop the rear and will the lean spacer work if i don't drop the front? thanks in advance
Old 01-08-2008, 02:47 PM   #282
