#101 |
Re: All of your 2/3 drop info here!
i have a 2000 xtreme and a 2/3 drop kit sitting in my room. I was told that if i put the 2/3 drop on my truck it would only lower my truck 1" than it is right now?? is that true?please help!!!!!!!!!
#102 |
Location: Lapeer / Midland, Michigan User is: OffLine |
If you got the 2" drop spindles for the front from beltech that are for the zq8 suspension then you will drop 2" in the front... and if you are throwing on 3" blocks in the rear then you will be lowered 3"
#103 |
What he said ^^^ and do you have spindles or coils sitting in your room?
spindles = 2" drop coils= .5" drop 3" blocks = 3" drop Last edited by HAWK : 01-03-2005 at 05:19 PM. |
#104 |
Listen to Daft Punk
I need an alignment asap, but no shop will do it becuase of no clearance. what do i do?
#105 |
go to firestone tire. they'll do it...
and those shops must be fockin gay i never found one that turned me away they went through the trouble of putting down a 2x4 if needed for clearance.. pull out the phone book and find a firestone tire... they did mine no problem |
#106 |
Listen to Daft Punk
I went to 2 local shops and NTB. I called firestone, 2 locations near me and both are not open. just goign to be drivin a couple a days with a pull to the lest and rubbing.
#107 |
Listen to Daft Punk
How does the front coil spacers work?
part # bel-4930 at summitracing |
#108 |
hey kuhndog56, i pm'd u back bro. be sure to talk to grndscrpr03 about it. he can help you im SURE. i will direct his attention to your post as well.
#109 |
Hates 'know-it-alls'
i PM'd ya kuhndog56
#110 |
Listen to Daft Punk
Thanks guys.
#111 |
RIP Grant
anyone have any idea how hard it is to fab out some fenders? I have 245/40/20 tires for my summer wheels......and i want to lower my truck 2/3.......Will they fit/turn alright if i cut out the fenders? i know i will in the front, not sure about the rear
#112 |
do you mean trim the fenderwells? i dont think that will be your problem really. it will be rubbing on turns at a full lock is what will get ya. you probly wont be able to full lock your wheel anymore. in the rear you shouldnt have to do anything. im bagged and dont even have my fenders cut up in the rear
with that size tire they should tuck pretty well inside right? |
#113 |
RIP Grant
#114 |
if i lower the rear only 2" will i still have to cut out the bumpstops?
#115 |
Beer Drinker
#116 |
only way i can think to improve it is running the right size wheel... having a perfect offset and backspacing will help maximize that. Last edited by HAWK : 02-16-2005 at 10:17 PM. |
#117 |
the 2/3 drop that i have is 2" coils and 3" blocks...if the coils only lower my front .5..the back will be lowered 3"?? i dont mind the front being only lowered .5 because i only want to drop the front a little bit..but the back that low with the front not so low..wouldnt that look kinda stupid?? what should i use for the rear if i lower the front with the coils because i already have 1" blocks in the rear and my truck sits level
#118 |
yea u are correct... using a coil will only lower your xtreme another .5" because u have 1.5" lowering coils on it already.... the rear WILL lower a full 3" if u put blocks on it.
i think if u r only going to lower it .5 in the front then only lower it 2" in the rear. that will give the right look to it u know? if u want to lower the front a full 2"...... then use spindles instead of coils if u do the 2" spindle drop. then id definitly go 3" block in the rear make sure u have the right blocks flat if single cab angled if extended cab |
#119 |
okay guys ive heard tons about angled blocks and flat ones, i got a 2000 Xtreme ext. cab and when i bought my spidles and blocks a year ago i was never told of this. i hope i have angled blocks but if i have flat ones whats soo bad about them? is something gonna fock up or am i fine with the flat ones
#120 |
i believe the pinion angle will be thrown off a bit..
u can look under your truck and notice easily... if theyre flat or angled |
#121 |
Fat Guys Rule!
#122 |
ok guys, i got confused here. are the part #s posted in this thread for the s-10 x-truck and the x-blazer, or are there different part #s for the x-blazer? btw this thred is one of the most helpful i have seen in a long time. thanks to all the peeps answering these repititious ?s.
oh and if there are different part #s can we get them posted up? |
#123 |
right now they are just the numbers for the s10 pickup...... so yea they are different part #'s for the blazer.... i will send xtremeninja a PM and have him update the thread with blazer numbers...
#124 |
#125 |
#126 |
Mega Man 2 Mod
Hey guys, sorry I forgot to list the Blazer parts, but have no fear they should now be posted up on the first page
#127 |
lol damn joe the blazer drop info still isnt on there....
#128 |
As far as S10 lean goes I used my sway bar to eaqual out the hieght by having one end link shorter than the other
#129 |
Mega Man 2 Mod
gimmie a few to PM barry again |
#130 |
hmmm never thought of doing that before... not a bad idea at all |
#131 |
Get Bent
Ok, has anyone skipped the blocks and went with drop leafs instead?
#132 |
#133 |
S-Clusive's Jester
this is a lil old but got any pics of a 2/3 drop on stock rims?
#134 |
XtremelyLow
Can some people post pics of their 2/3 drop, im thinkin of doing it late spring/early summer
#135 |
SLAM's Trusty Webmaster
#136 |
Here is mine....I put 2" spindles in the front but I completely redid the rear. I have 3" belltech leafs and 2" blocks. Still a total of 5" in the back. So I am 3.5" front and 5" rear drop.
#137 |
Neglected & Broke
i just droped the back of mine 3in and i love it! cant wait to do the front, i need to cut the bumpstops and then do something with the pinon angle.. (vibrations...)
#138 |
pinion? you really shouldnt have any...... did you get the right blocks? angled blocks for an ext and flat for a reg cab?
#139 |
Neglected & Broke
#140 |
Your pinion angle shouldn't have changed. I have not had a single problem with mine since I did the drop. Very odd that you are having vibrations. I bet it has nothing to do with the drop and something else is going wrong in your truck.
#141 |
wish i had bags
is it necessary to trim the fender flares back at at all when doing this drop? it looks like the tire may contact the flare after the drop, im running stock x wheels with 235/55 tires
#142 |
Choosy moms choose Jeff
#143 |
Mega Man 2 Mod
trim the flares, meh not needed, i mean you can or you can let the tire take care of it for you =)
if you are worried about the tire rub then go ahead and trim away, but yeah tire will rub on the flares, get a nice smell from parallel parking a few times, heh. or if yer not worried then go ahead and let the rubber do the work for ya |
#144 |
Mega Man 2 Mod
and for all wondering, i am gonna get on it tonight to get Zy to put up the blazer stuff, sorry for leavin ya hangin
#145 |
wish i had bags
any idea how much they might need trimmed?
#146 |
Neglected & Broke
heres mine just with the block in the rear, it REALLY nasty bout to go wash it, cant wait to drop the front
#147 |
Ex Minitrucker
when i had the 235/55s on it rubbed at first around full lock on the flares. After making a sharp turn I could get out of the truck and pull rubber off of the inside of the flare. Itll eventually wear it down so that it doesnt rub anymore. I wouldnt worry about trimming it.
#148 |
wish i had bags
i think ill just take the time to trim it, i cant wait to start working on it, i just have to wait until sunday so i can borrow a ball joint tool and a sawzall from my grandpa
#149 |
get a few strong blades too.. you'll need more then one
#150 |
Well I am running 18's with my drop and it doesn't rub at all. You shouldn't need to trim them at all.
