#51 |
Registered Slacker
Re: All of your 2/3 drop info here!
imma have to do that too? err im guessing that this 2/3 drop will void my warrenty? |
#52 |
Registered Slacker
how hard is it to remove the bump stops? or that link was the bump stop?
#53 |
that link was a how-to on removing the bumpstops, you can use air tools or a sawzall
and yes you will have to remove them, and yes it will void your warrenty (at least what i've heard) |
#54 |
Registered Slacker
ah serious? damn i cant void the warrenty shizz..its a 03 and the rents got the extended warrenty..they'd kill me if i voided it.. err..damnit..thanks anyways..at least i'll know wut to do wen i actually do it then..thanks again..
#55 |
Ex Minitrucker
From what ive heard itll only void your suspensions part of the warranty
#56 |
Registered Slacker
ic ic..hmm..err..i dunno..hawaii has some mean pot holes..well not that i go over all of em..but yea...err gotta think about this one, thanks though
#57 |
UAH By-product
So the spacer will raise one side up to match the other? or lower one side to match the other?
also...bump stops look like a pain in the arse ![]() Brad |
#58 |
Registered Slacker
err..oh ya..that reminds me..where do the spacers go? which end? which side? easy? hard?
#59 |
dude, sounds like you got audio problems if your blowing fuses/amps, you better be fixin that soon or your going to do some damage to your bat or alt.
sorry not on subject |
#60 |
Registered Slacker
huh? oh in my sig? ah i found the prob already..the amp was defective..bleh imma get it fixed..i have a old skoo RF runnnin my subs now..its all gee..thanks tho |
#61 |
CHANGE YOUR EMAIL ADDRESS
so you guys are saying that the zq8 sus only lowers the front 1.5" or did they lower the back too and if so how much and how?
#62 |
the front is lowered 1.5" with drop springs
the rear is lowered 1.5" with a pulled leaf some say it's a total of 2" all the way around.. because the x tires are more low profile or somethin.. but it's about 1.5" all the way around |
#63 |
so by buying a 2/3 drop kit like the one in this sticky i would have a total of 3.5/4.5 drop in comparison to a stock s10 not zq8 right.
#64 |
Yup, as long as you use the drop spindles and blocks as it says in the first post you'll get the 1.5" + 2" = 3.5" up front and 1.5" +3" = 4.5"
:thumbup: and to answer about it being compared to a stock s10 no zq8 yes you have a 4/5 (as most say instead of 3.5/4.5) and compared to any other zq8 you have a 2/3 drop more Last edited by HAWK : 04-24-2004 at 08:54 PM. |
#65 |
cool, thats what i figured but wanted to make sure thanks.
#66 |
no problem dude, glad we could help ya out :thumbup:
#67 |
Dildoans
#68 |
Dildoans
and i know there was some other info i was supposed to post, but i forgot to do it...lol...i'll have to search for it and post it.
#69 |
eh ![]() |
#70 |
#71 |
225/40/18 and yes i still rub.... thats because of my 8.5" wide wheels... im pretty sure any 8" wheel and under won't rub...
it's really not that big of a deal though.. no tire or rim damage on mine... |
#72 |
Ive got the spindles up front, and the 3 inch FLAT blocks on my extended cab. Front does fine but my back end is always soundin like its bottoming out....Frames hittin the axel anywhere i go....like bad...THOMP loud shit....the rubber bumpstops are gone...do i need to take the metal one out or am i missin something?
#73 |
it's best to take out the whole Bracket along with the rubber, i'm sure thats what your axle is hittin on.... then take some black spray paint, and spray it on there...
and just so you know, Angled blocks should be used on the extended cab trucks. but arent essential |
#74 |
blowin dro 24
#75 |
this should help you out on the spindles. i.e. tools
http://www.s10forum.com/forum/f198/drop-spindle-how-to-100292/ |
#76 |
blowin dro 24
The last knuckle assembly i took apart was in autos class about 2 yrs ago. the info u gave me was great. thanx xHAWKx
#77 |
I have a 01 Blazer Xtreme and was wondering what I ALL need to do a 2/3 drop. The 2" drop spindles, the 3" drop blocks. So here are my questions: Are the blocks needing to be flat or angled? Do I need to remove the bumpstop? I read that I probably won't need to flip the brake line but will it be a good idea to do it anyway? Is there anything else that I need to know? And finally, does anyone know the part numbers for summit racing for all the parts that I need? Sorry so many questions but I'm a newbie to this.
Thanx |
#78 |
i need more cowbell!
do the blazer xtremes have a different dust shield or something? the shield on my x doesn't look like it has the same bolt holes that are on the spindle, am i doing something wrong, or did i just over look something?
thanks, josh |
#79 |
why does it say that the bel-2100 fits malibu, monte carlo ss, grand prix, regal/gn, 1980-87, cutlass/442, 1980-84? doesn't say anything about fitting an 02 blazer x.
#80 |
i believe the blazers use a different spindle, that spindle is much more expensive. send a PM to THRICE here on the forums, and he can answer all your questions about the blazer, Xtreme2115 and chimera
#81 |
okay, i am pretty sure i got the wrong part here. i just wanted to make sure with someone before i sent it back. i think you are right about them using a different spindle because i saw some on stylinconcepts.com for like 260 a pair. wtf??
#82 |
yea, sadly they are much more expensive. send THRICE a pm.. he can help you out on what parts to get
#83 |
Listen to Daft Punk
Soon i'll be doing the 2/3 and i had a few questions.
Does this void warrenty? I heard cutting off the bump stops do but if i left them on until the warrenty is up would that cause any problems? I ahve an extended cab and do i really need angled blocks? Can I have the part number for the 3" lowered blocks? THe belltech drop spindles that is stated in this thread from summit that costs 150 will fit on my 03 X, right? thanks for any help |
#84 |
will it void warranty. i believe y2k xtreme said Yes it will PM him, he will know for sure and i dont think you could drive it without the bumpstops out.. you would slam em so hard all the time it would hurt.. lol
2) you dont HAVE to have angled blocks but it will throw off the pinion angle which isnt good and the part numbers are in the first post of this thread. get the angled blocks. its better and they are cheaper 3) yes the spindles stated are the ones you need, the part number is in the first post of this thread as well any more Questions. just ask away :thumbup: |
#85 |
Listen to Daft Punk
i got the part numbers for summit but they dont say which one is angled or not.
thanks for the info |
#86 |
bel-6202 if im not mistaken
#87 |
UAH By-product
don't wanna mess up an air dam. would a 1-2 drop suffice or would that be pretty pointless? low budget so i dont wanna duff up 200 dollar air dam. wouldnt bottom out near as bad either would it? could i get by with just cutting out the rubber on the bumpstop? does belltech even have a 1" spindle?
Brad |
#88 |
no 1" spindle drops out there that i know of... u have to go 2" and it doesnt even effect your airdam that much. i've had the stock one for 6 years and its still on there... it will get scraped up underneath, but take it easy up steep driveways and your fine. and you can get away with just taking the rubber out. but it will hurt like a bitch when that axle goes up into that bracket. youre better off cutting it all off
#89 |
UAH By-product
well i just put a new air dam on it about 3 months ago... i still sit level because of it (im broke... good game UAH)
mark my word... im so poor now.....in 5 years after i start workin... bags.. there will be bags.... Brad |
#90 |
ya i'd go and do the drop. but thats just me, cuz i hate teh gap in it
oh and i see your truck is black. thats the perfect color scratches on the top will not show up. thats why mine has lasted so long... white truck get screwed very quick. but on our black trucks it hides the scrapes. so go do the 2/3 drop ![]() |
#91 |
UAH By-product
mine hasn't hit ANYTHING yet.... ive been lucky.... and whats this with scrubbin. i don't wanna be scrubbin tires. 1/2 just seems more practical for me.. would DEFINATLEY make a difference....just not as drastic...
ive got a jar started for saving... so... yea... im in the right direction. Brad |
#92 |
I'm a huge ass
hey guys i got a few questions first is i want to get the 2/3 way bad i have an 01 x cab Xtreme i want to get an exhast for it too but im thinking about running the pipe in between the leafs and frame so the tip can be way off to the side but still stick straight out dont know how it will work with the drop? i also want 18s i really like the boss 304s look like a sweet stock rim but bigger and chrome but the only make them 18x9 so will the fit witha low pro tire and drop?
#93 |
I'm a huge ass
bump bump bump 8-) :-D
#94 |
noma94
Dan |
#95 |
u are exactly right
#96 |
UAH By-product
plus it would handle better
ESP if you throw on some zq8 sway bars... which ive seen for sale often on here.Brad |
#97 |
Department of Redundancy Department
Please let me know if you do this, as I'd still like to try it. (Mines a ZQ8. Not dropped.) Thanks. |
#98 |
#99 |
6202 for extended cab skrot74
xtremeninja i just noticed a flaw in your post... you have 6100/6102 when you need 6200/6202 instead cuz the other is for 2" blocks not 3" |
#100 |
Mega Man 2 Mod
shit, good catch Kevin
