El Conquistador
2/3+zq8=bounce bounce bounce?!?!
i haven't been 2/3 for very long. the stock bilsteins only have 45k miles on them. bump stop brackets in the rear are whacked off. any suggestions on how to stiffen up the rear so i don't whack the axle on the frame anymore? i don't drive like a maniac but some the whoops in the road must have the perfect rhythm to bounce the axle into the frame.
that short kid
Re: 2/3+zq8=bounce bounce bounce?!?!
shocks could be the culprit even though they have low miles. Im at 5.5 in the rear w/ bumpstops and bumpstop brackets remove and very rarely hit the frame, and thats only because im on 20's in the rear now.
El Conquistador
ya that sucks...hhmmm guess ill shop around for some shocks
bellcranks no more
notch
El Conquistador
ehhh its merely a daily incase of resale i don't plan on wanting to deal with a notched frame.
Drop & Destroy
just do one of the small bolt on curcular notches
don't notch a static truck. That's ghetto. Just get some belltechs. Mine are stiff as hell
El Conquistador
ya less than a hundred bucks for some belltech nitro drop 2s...gonna score some for the back right away.
bellcranks no more
how is it ghetto? if you are bagged you can lift up to where you dont bottom but for static you are stuck.... i think low static SHOULD have a notch as to where a bagged truck doesnt need one |
Drop & Destroy
exactly and its not ghetto if they make a easy to intall ****ing bolt on notch at summit for a flip kit.....so summit is ghetto then.?
Yea did
Do both, Notch it, get shocks and your set....btw notching a static truck= Not Ghetto
I'll do it tomorrow
Location: Kingston Springs, TN. User is: OffLine ![]() ![]() |
It should not hit the frame anyway with the bracket out. How is the rear dropped?
The Beast
I took off my worn out Bisteins and installed some new KYB red monomax shocks. Has a nice stiff ride now. Much better. The pistons are much larger in diameter compared to the Bisteins. I have a 2001 V6 Xtreme Xcab.
I AM CANADIAN
You should not be bottoming that hard, I have 2/3 and I got new Bilsteins when I did my 3" drop, get new shocks it will feel way better.
4/5 static
mine hits 2....thinkin about air shocks and reinstalling sway bar
RIP Sean Taylor
mine started hitting hard after i dropped it and then i noticed that one of the rear bilsteins had like blown out, so i went with the beltech drop shocks, and it was much better...however if haulin ass and hit a ditch or carrying some weight it will bottom out every now and then!
shifting gears
You can get bilsteins (or even cheap gabriel shocks) at AutoZone. They all have a lifetime warranty, so you can swap them out as often as you need.
