What would you do?
Go Back   S-10 Forum > Suspension Tech > Juicin' It
Old 02-10-2004, 04:50 PM   #1
Rollin Car Club
RikuY
What would you do?
I am looking for ideas for my truck. It's on bags now with some 18'&20's. I want to do some juice and serious juice at that. What kind of a set-up would you do. Money don't matter, but be realistic (as in no 20 pump set-ups). I need to three-wheel, and drag frame.
Already has monster notch in back.
What would the set-up be for 18's all the way around?
What would it be for 13X7's all the way around?
Let me have it...
Thanks to all the replies in advance...
Old 02-10-2004, 06:51 PM   #2
lays frame on 22's
neverfinished94's Avatar
neverfinished94 is on a distinguished road
Re: What would you do?
a 4 pump 4 dump setup would be very clean and you would be able to do any move you wanted to. i would run at least 6 batteries but 8 if you had the room. i would stick with pro hopper or cce. i personally like pro hopper. havent had any experience with hi lo though. i saw a pic of someones setup on the forum and it was VERY clean. im sure if you looked thru the posts you would find it. lata
Old 02-11-2004, 01:11 AM   #3
dont be a pussy
NoDime4myTime's Avatar
NoDime4myTime is on a distinguished road
4 pumps is a waste of money, you can do all the stuff with 3 that you can do with 4, save a couple pennies and room.
Old 02-11-2004, 08:28 PM   #4
lays frame on 22's
can you lift each individual corner?
Old 02-12-2004, 02:52 AM   #5
dont be a pussy
no, but you can set it up to lift individual fronts or backs, control of lifting individual corners is kinda retarted, either do a stand 3 or a standing dog leg.
Old 02-12-2004, 10:17 AM   #6
Rollin Car Club
RikuY
Thanks for your input. Two pumps to the front is faster, given batteries are doubled. Also, I think I am going with four just to keep the one pump to the front from burning up. I am looking at it so I will not have to by a new motor in a couple of months. I hope this set-up will be robust enough to handle my switch-throwing...
For what it's worth. Some people do 4 or even 6 pumps to the front (6 or 8 pump set-ups) just to grill fools at red lights. I don't think 6 pumps is the way I am going to go, but seeing an S-10 do a four foot hop from rest is a jaw-dropping event no matter how you look at it.
Neverfinished,
Thnks for the help as well. 4 pumps is sounding right. What do you think, 12 batteries? or 16? I am getting serious about this, so I might as well do it right.
Old 02-12-2004, 11:30 AM   #7
EyePoppin's Avatar
EyePoppin is on a distinguished road
I thnik someone is filling ure head with BS. All you need for your "Switch Throwing" is 2 pumps, u will have 3 wheel and u will need spindles to lay frame.
4 pumps is way over kill for what u want to do....but to each is his own, i say, unless u have an old skool low rider, 4 pumps if a waste of money and a waste of time,
Old 02-12-2004, 12:40 PM   #8
Thetwiztidklown
i would go with a 4 pump setup like neverfinished94 said and i like pro-hopper to and know people who run cce and like it but most of it depends on the install if you run 4 pump and a chain bridge you can do a standing 3 three plus have side to side if you run a 3 pump 4 dump you can still do a standing three wheel but not side to side and a 2 pump you can only do three wheel if you drive in circle and dump one back wheel or less you do a 2 pump 8 dump setup which will give you all the moves of a 4 pump setup up its up to you what you want i run my setup 12 volts so i never charge batteries and dont have to worry to much about burning a motor up but you can buy a street charger if you dont want to charge batteries but i am not in to fast i have a 2 pump 4 dump setup with 2 switches and rides better then all my friends bags
Old 02-12-2004, 04:09 PM   #9
Rollin Car Club
RikuY
I already have the spindles as I drag frame now with my bags... I know what you're saying about the "need" 4 pumps, but I don't "need" any of this. Good lookin out though...
Old 02-12-2004, 09:24 PM   #10
lays frame on 22's
if it were my truck i would just run a 2/4 with 4 batteries. the guy said money's no object and he wants to do all the moves. that sounds like a 4/4 to me. if you want to hop then the more batt's the better. even with 8 batt's you're gonna be fast and hop. 16 batt's is crazy
Old 02-13-2004, 12:31 AM   #11
LAID OUT CUSTOMS
Im not tryin to sound like a dick man but what does it matter what we would do its your truck do what you want to do.
hydraulics and bags are both the shit properly setup they can both ride great or hop 4' so when it comes down to it its your truck do what you want
Old 02-13-2004, 10:47 AM   #12
Rollin Car Club
RikuY
You know... One of the great benefits of talking on a forum like this is to get ideas. More input and viewpoints into my head about my situation helps me see different things I would not have thought of on my own. This is why I posted a question like this. You don't sound like a dick, but if you don't want to answer the question, thanks for reading anyway.
Have a nice day...
Old 02-14-2004, 08:13 AM   #13
Tandem-Madness
Eyepopin, your sorta right. Yes with 2 pumps and 4 dumps, you will have the abilty to 3 wheel motion, but to have a standing 3 wheel, you need 3 pumps, with a chain bridge, or 4 pumps to control each wheel individually.
Old 02-19-2004, 11:53 AM   #14
not a such a fatso anymor
haktup's Avatar
haktup is on a distinguished road
Not really you could do standing 3 with 2 pumps if you chain bridge it and set it up properly. However if money is not a problem I would go with 4 simply to keep things looking equal I would run no more than 8 batteries make sure to run prestolite blocks. I personally would only run 48 volts but you could run more I just don't like what higher voltage does to stuff start blowing solenoids and pump just not fun! and with 48 volts you can hop. but if you want big air run more.
Old 02-19-2004, 12:03 PM   #15
haktup's Avatar
OH YEAH just so you know just because you have 4 pumps doesn't mean you can stand 3 without a chain bridge I did a 99 extreme that stood three but not with out a chain I tryed all kinds of tricks just would not do it they rebuilt it a couple of winters ago using 2x6x1/4 square tube stands on it own now but wheigh 4 tons tanks aren't BUILT AS HEAVILY AS THIS DUDES TRUCK. All though he did inquire about body dropping it.
Old 02-19-2004, 12:15 PM   #16
EyePoppin's Avatar
RIKUY do u want to do a stand ing 3 wheel?
Old 02-20-2004, 07:20 AM   #17
Mad man from michigan
blazentrout
thats the one with eddy on the hood, correct? i am of the 4 pump/8 battery settup my self with every thing set as far back in the truck as you can.
Old 02-20-2004, 10:13 AM   #18
Rollin Car Club
RikuY
Why yes... yes I do...
I just talked to my friend last night and we are ripping off the cab and bed and boxing in and reinforcing the entire frame rail. A couple of extra crossmembers are coming into play as well. You guys have started to sway my thinking though. I may finish my truck with Suicidedoors new cantilever kit for the S-10. I might have to go old skool Caddy for some juice.
I am still rocking my monoleaf set-up in the rear, but that is the only thing not done on my truck. That new kit should be nice from Suicidedoors. I am starting to like the idea of a finished truck and moving on to something else. That way, I will be down with air and juice...
Sounds good to me...
Old 02-23-2004, 01:20 PM   #19
haktup's Avatar
yes trout that is the truck all eight batteries when in the back it just did not want to stand.
Page generated in 0.20653 seconds with 12 queries
