01 Bagged Truck 4 Sale
what coils to run
What coil should I run in the front ???
thanks |
dont be a pussy
Re: what coils to run
really depends on what you want to do, hop or just up, down, drag.
i want to drag and up and down no hop
dont be a pussy
for just up and down, nothing special, you can run your stock springs up front.
thanks
Stock springs cut of course....u arent going to be able to fit the whole coil in there.
u just cant buy any coils like 1/2ton or arnything
what is better to run powerballs in the front with accum or option B coil and cylinder or if there is another way tell me |
dont be a pussy
you can do coil over in the front with powerballs in the front, takes a bit of work and welding on the lower control arm it seems pointless to me. I suggest doing a coil under set-up with the stockers cut down, or 2 ton coils.
ok thanks do u have pics of ur setup or any pics at all of hydros in a BD on 20's Sdime
Ya do a Coil under setup, ull be a lot happier with it.
dont be a pussy
thanks again
dont be a pussy
Can Yah Hear That China!
what could i get some good hop with? 2 ton coils? how do you hop? just flick the Front up switch? i havent played with switches before so i dont really know??
ull get the hang of ure switch and when to dump / lift ure truck and hopping.
dont be a pussy
if you really want to hop I know someone who has a pump laying around that will get you so much hop its sick! I might also be able to hook you up with some extended uppers. I am not into hopping but I am accidently a hydraulic and s10 expert ![]() |
dont be a pussy
off the top of my head I cannot remember how many turns to have, I will check here in a second. You will have to cut your frame for control arm clearance and have spindles to lay. If you want you can swing by and check out an s10 I am building and see exactly what needs to be cut and what not.
Resident Pain in the Back
Mad man from michigan
Location: grand rapids michigan User is: OffLine ![]() |
the best no work/cut coil(they are 6" tall out of the box) for the s-10's in opion is the red's 1ton precut with a 6" cylinder, that way you wont lock up as hard.
