time to buy need some info/help
Go Back   S-10 Forum > Suspension Tech > Juicin' It
Old 07-27-2004, 01:48 PM   #1
MiKeZ97MiNi's Avatar
MiKeZ97MiNi
sup guys i been debating wheter to go with bag or dros but i made up my mind i want hydros i want to be able to a standing 3 wheel.. not really interested in hoppin its just gonna lay frame
i was thinking a 4 pump or 3 pump setup and a 4 link in the rear
http://prohopper.com/kits/pro_competition_kits/(ph150)pro_comp_4-pump_kit.jpg
for $1,699.00
my friend does custom suspension setups so he is doin all the work i just need the stuff. i wanna do it right ya kno
Old 07-27-2004, 01:54 PM   #2
MiKeZ97MiNi
Re: time to buy need some info/help
forgot to ask what size cylinders should i get 8,10,12?
Old 07-28-2004, 04:36 PM   #3
ITS NOT EASY BEING EASY
MODERATOR
Dragginbody's Avatar
Dragginbody is on a distinguished road
if you got the dough get the best 4 pumps you can get.
run 10s front and whatever kinda lift you want cylinders in the back.
Old 07-29-2004, 03:29 AM   #4
Naughty T's Avatar
Naughty T
If you just want to lay out and 3-wheel, you can save some money and get a 3 pump setup... And don't get 10" cylinders in the front... Get 8"s... Now the back is kind of tricky... If you want it to lay out, you have to consider this... Hydraulics have different measurements to take into account then air bags do... You have your mounts on top of the axle, cylinder collar, donuts and spring... The lower you go the bigger your bridge will have to be... This can effect the size of the cylinders you run... Take for example my truck... My truck lays frame... I have a 12" step notch and 2.5 turns in the rear coils... I am running 18" cylinders in the back... The tops of the cylinders stick up about 6" above the bed rails... Now I have 2 choices... Get a Snug or nothing at all because a tonnue is out of the question... With that being said, let's talk about the issue of stanging 3-wheel... You should probably run 12" or 14" cylinders... You should also get some Power Balls... Pro Hopper calls them Pro Balls... You will also need a chain bridge... You should chain the truck at around 7" to 9" to get a nice 3-wheel... You will also need to reinforce the stress points of your frame... Those being the rear arch above the axle, between the bed and cad, and the front where the control arms mount... Reinforcing the control arms and changing out your ball joints is not a bad idea also... If you have any more questions, I will help out as much as I can...
Old 07-30-2004, 05:32 PM   #5
MiKeZ97MiNi
i want to keep everything under a tonneau cover is that still possible and be able to pull a standing 3
Old 07-31-2004, 01:08 AM   #6
Naughty T's Avatar
Naughty T
Yes... Just make sure you measure everything out to fit...
Old 08-02-2004, 09:05 AM   #7
EyePoppin's Avatar
EyePoppin is on a distinguished road
Good luck with 12/14" cylinders, i had a hard time fittin 10"ers under my tonneau.
Old 08-02-2004, 05:43 PM   #8
not a such a fatso anymor
haktup's Avatar
haktup is on a distinguished road
I could do it if you want ideas pm me.
Page generated in 0.10579 seconds with 12 queries
