switch wiring
im in need of some help maybe someone can answer this one for me....i lost the instructions for the switch box and i dont no whut switch does whut...i took the box apart to take alook and the first two switch have 12 wires coming out then down one side they are single throws with two wires coming off and then the other side has double throws with four coming off each...my question is whut do i wiring where....i have a two pump 4 dump 6 solinoid 4 batt. setup. i got one wire coming off each dump well two but ones ground the one wire coming of the group of solinoids...some please help...ive tried searching...
Pro Hopper Biaa
Re: switch wiring
http://www.layitlow.com/tech/switches_10.shtml
try that 10 switches 2 pump 4 dump setup |
Neighborhood Dragger
Re: switch wiring
suicidedoors has them too.
Re: switch wiring
okay i got it all figured out but i dont kno where to wire my 24 volt switch box to....i wire front left down to one dump then front right down to the other dump? then where do i wire front right up and front left up too? the one wire coming off the solinoid??? then its going to be the same for the back? i got four batteries but im running two bays of 24 volts to each pump with three solinoids...is that proper? or should i only run 2? or run 36 volts to each pump then if i do that how do i wire up the 24 volts switch box...kinda confused??...
Re: switch wiring
