rear bridge with droz!
can i see some pics of rear bridge setups on s-trucks with hydros!
CHANGE YOUR EMAIL ADDRESS
i have never seen a s series with fluid but i have seen people just use like 4 inch c channel welded on top of the notch and it seems to work good... especially inexpensive
look at my AV, that is when my truck had dros....sorry i dont have any more pics...
I'll try to find some pics of when my truck had juice, but it wasn't that good looking.
If I find anything, I'll post a link to the website. |
thanks guy's!
dont be a pussy
Re: rear bridge with droz!
http://www.s10forum.com/forum/attach...chmentid=45430 |
i never said it wasnt ghetto hahahah nice bridge btw.
Sittin on Chrome
Location: Calgary, Alberta, Canada User is: OffLine ![]() |
eacyde is that just a peice of c iron or what ever welded on a notch? looks good im trying to decide how i want to redo my rearend cause right now its on the leaf springs and i can see it ant good for the springs thx Jason
You can see the entire thing at: Joey's Hydro Install The frame notch is square tubing, the crossmember is 1 1/2" tubing that I bent and fishmouthed together... Everything is primed, then painted and cleared to match the truck... Last edited by Tandem-Madness : 02-07-2004 at 11:18 AM. |
dont be a pussy
sorry if I offended you or anyone using c channel, it just seems like the easy and cheap way out to me ![]() |
Sittin on Chrome
My new rear setup that I am working on will be more stealth. I am jelous of rear bag setups that are completly hidden under the bed so I am working on something that will be hidden. |
Sittin on Chrome
ok cool thanks cause im thinking about doing that what did you use to attach the cyenders to the axle??? thanks alot Jason
I would steer away from c channel, it works but you will be unhappy with it unless u cover it up. I would go with 2x3 square and weld it INBETWEEN the 2 notches.
ok cool thanks alot eyepoppin greatly appreciate all the help i am gonna cover it up but ill propably go with 2X3 any ways what should i use to attach the cyenders do my axle? or how should i do the bridge? thanks alot everybody is there a site that sells hydro rear brackets thx jason
use either powerballs or a heims joint, with a mount on the axle.
ok cool thanks does anyone know where i can pick up some axle mounts for droz? thx jason
Click link in my sig. |
thanks alot im not good at fabing so hopefully i can get jason to make me somthing hehe thanks alot for all your help greatly appreciated Jason
///Relaxed Atmosphere
well, i guess i can post mine here too, even tho im sure i will catch shit from somebody on here cus its not as kewl as theirs, oh well. Anyways, for the axle mounts i got some 1/4" C chanel and welded that to the axle, then welded my powerball to that for a real nice flat mounting surface, it worked really well. When i ordered the kit i also ordered some mini-coil cups for my minis that im runnin in the rear, well when i got them they were fukn rediculious, they didnt fit worth shit and had tons of play on them inside the spring, soooooooo, i got some 3" round stock billet aluminum and machined my own cups for the coils, no play, perfect fit and look much better than the ones that came with the kit.
I also attatched a pic of my bed also, with my battery mounts and seliniod mounts and my pump mounts. enjoy........and if you dont like what i have done to my truck as far as the setup of my fabricational skills, please keep it to yourself, i work with what i have. taylor |
why the hell cant i attatch pics, its says im past my quota or something, ive exceded my limit, whats up?/???/?
taylor |
ok, well i had to do a sounddomain.com quickie, i still dont know whats up with my attatchment limit thing, but here ya go, once again, if you dont like what ive done, thats fine, just keep it too yourself, im not a professional fabricator, i work with the tools i have and time i have.
#24 |
holy shit that is bad ass great job and thanks for the info so is that four linked? im trying to learn this crap to redo my set up thx love the maltease cross's great job Jason
#25 |
I think that looks kick ass taylor. Great job!!!
#26 |
Sittin on Chrome
Are you running the Suicidedoors mostly bolt in link? Looks good man. |
#27 |
no its not a suicide doors product, its made by steve at Can-Do, i really wasnt fond of the whole "bolt-on" thing but, after i talked to steve about it a few times i just decided to give it a try, it seems to work just fine. But to answer your question its made by Can-Do Specialties.
thank for the comps guys, i will throw some more pics up when i get more accomplished. taylor |
#28 |
Ay taylor, if u dont mind, pm me and let me know how much Steve charged ya for that kit....
#29 |
BTW take some pics of ure bottom bars + mounts
AS far as ure bed, did u just drill holes and spot weld the sheet metal in? I am sheetmetaling my bed this year and i dont know which way i want to do it. Last edited by EyePoppin : 02-09-2004 at 02:40 PM. |
#30 |
eyepoppin,
I can get some pics of them bottom bars when i get home, do you want to know how they connect to the axle or to the frame?? As far as the bed goes, i made a skeleton out of 3/4"x3/4" bar along the bottom of the bed and also along the sides, leaving the stock bed inplace, or what i had left fo the stock bed. The side peices i cut to legnth then welded the top of them to the bed rails and smoothed them in so they looked good. Now, i know most people cut their old stock bed completely out of the bed and make a whole new one out of sheet metal, but the way i did it seems to be fine, its supported greatly all around, mind you the bed is now really fukn heavy, but im not too concerned about that really. When i first strated the project i was just going to lay sheet metal down and spot weld it from underneeth to keep it in place, but i decided to lay some sturdy bracing down for it would be better and give it a good flat platform to lay on. then i just spotwelded it into place and smoothed it out. It seems to work good tho, i havent had any problems yet. i will let you know of them pics, i will post them here when i get them and i will also pm you with how much that 4 link cost. taylor |
#31 |
jesus god, how the hell do i send a PM now, i dont see the link anymore, what the hell is goin on with this forums now, i cant post pics and i dont have a pm option on the page anymore, whats up?
taylor |
#32 |
Rollin Car Club
Hey Zero,
Please let me know the details of how to get in touch w/ Can-Do. Website, phone, anything would be great. Thanks in advance. RikuY |
#33 |
#34 |
