pump problem
Go Back   S-10 Forum > Suspension Tech > Juicin' It
Old 05-23-2004, 07:56 PM   #1
FTW
slammed 97s1o's Avatar
slammed 97s1o is on a distinguished road
pump problem
my friend just bought a nissan hardbody with a 2 pump system on it. when he hits the switch one of the pumps sounds like its got a gear grinding but it still works. i was just wondering if anyone knew what might be causing this problem. it sounds really bad and hes afraid to drive it like that.
Old 05-24-2004, 01:29 PM   #2
EyePoppin's Avatar
EyePoppin is on a distinguished road
Re: pump problem
When was the ast time he checked his oil??
He may just need a new pump head...
Old 05-24-2004, 01:59 PM   #3
Lay'd
BuiltNotBought99's Avatar
BuiltNotBought99 is on a distinguished road
Re: pump problem
I agree with Eyepoppin. I may have run low on fluid and burnt up the pump head.
Old 05-24-2004, 06:15 PM   #4
FTW
Re: pump problem
he just bought the truck yesterday and it started doin that when he got home about an hour later. him and they guy he bought it from played with it for about 45 minutes before he left the guys house so he would know how to work it. i will check the fluid level tonite and see if its low but it doesnt have any signs of leaks so i dont know.
i do know that this has made me decide to keep the airride on my truck and not switch to dros like i was thinking of doin.
Old 05-24-2004, 09:54 PM   #5
Resident Pain in the Back
Zer0KlearancE's Avatar
Zer0KlearancE is on a distinguished road
Re: pump problem
Just be sure not to overfill the pump when you check the fluid level.
Old 05-25-2004, 12:33 AM   #6
FTW
Re: pump problem
well it isnt low on fluid. i am going to take the pump out tonite and get it checked out by one of the guys at work that does hydraulic systems. he also has a problem where the back end feels like its about to slide out if he drives at any height other than fully lifted.
Old 05-25-2004, 04:07 AM   #7
Re: pump problem
Could have air trapped in the line and moving through the pump head, just my opinion tho.
Old 05-25-2004, 08:17 AM   #8
EyePoppin's Avatar
Re: pump problem
Id say change the oil purge all the oil outta the lines (that u can) take the tank off of the pump and clean it out, make sure there isnt any "huge" chunks of metal in there. There should just be some shavings, that is just fine. just no big chunks...
What kinda pumps are they?
Old 05-26-2004, 01:11 AM   #9
FTW
Re: pump problem
im not sure what brand they are they dont have any markings on them what so ever.
how much would it be to up grade it to a 4 pump setup. he has 8 optima yellow top batteries and only 4 are hooked up right now 2 to each pump.
Old 05-26-2004, 10:23 AM   #10
EyePoppin's Avatar
Re: pump problem
If i were u since u dont know what kinda pumps those are, i would get a brand new 4 pump setup from Matt at Gauge (link in my sig). Then ull know u have good parts, and then u wont have to worry havin 4 pumps if the 2 are going to give out. Because u do not know if this person that had it before ure boy hooked up 96 volts to the pumps and started hopping with it or not...
Old 05-26-2004, 01:36 PM   #11
two pump chump
120clown is on a distinguished road
Re: pump problem
ok here is what i would do take the moter off the block (two screws on the moter endcap) once you have it off of the block there should be a key (witch connects the moter to block) check that key i would say it sounds like it may be striped out if it is that spline key they are cheep. other than that get a new moter 89.00 for a good one dont be cheep go all out!
Old 05-26-2004, 10:49 PM   #12
FTW
Re: pump problem
ok well he has decided that he is just going to buy a new set of 4 pumps. he was wondering if the turbine pumps were any good? http://store.gaugemagazine.com/index...ROD&ProdID=332
theres a link to the ones he wanted
Old 05-27-2004, 08:21 AM   #13
EyePoppin's Avatar
Re: pump problem
Yes those turbine pumps are fine. Just so you know all he needs is a street kit. Like this one - http://store.gaugemagazine.com/index...ROD&ProdID=308
Old 06-10-2004, 01:39 AM   #14
cmb75's Avatar
cmb75 is on a distinguished road
Re: pump problem
should of checked the dump valve, the same thing happened to me. my dump was broke in half, due to the pressure
Old 07-01-2004, 07:31 PM   #15
biglove is on a distinguished road
Re: pump problem
thats kinda high aint it 1300 http://www.prohopper.com/home_frame.html
never mind 4 pump system
Old 07-01-2004, 07:55 PM   #16
two pump chump
Re: pump problem
whatever you do dont run delta dumps they are only rated for 2500 psi and the cartreges swell get the italians or a adex
Page generated in 0.20444 seconds with 12 queries
