new to hydros
Go Back   S-10 Forum > Suspension Tech > Juicin' It
Old 10-30-2007, 10:10 PM   #1
new to hydros
i am new to hydros. i have a 97 isuzu hombre 4.3 vortech automatic. i have 2 cce pumps and 4 dumps runnin on 48 volts. i have read that your not suppose to run hydros in the winter. i live in florida so i should be ok right? i think the coldest it gets is maybe in the 40s and i am running hydraulic 68 fluid. i will be going to TN though sometime around christmas. will i be ok to drive this up there and play with it some? also i read about street chargers. is there a cheaper place to get them than for 340 bucks? i mean thats high. i would rather just keep charging my shit every other night since i can charge all 4 bats in about 5 hours at 12 amps. also what do i need to do to lay on 22s or maybe just maybe 24s? i want to body drop sometime also. stock floor or regular?
Old 10-30-2007, 11:21 PM   #2
juiced dimebag's Avatar
Re: new to hydros
u will have to definently notch it tub the front and rear and if its just single leaf u will definenlty need to link the rearend stockfloor or traditional, well it depends on how good of a fabricator u are as for hittin switches out of town i wouldnt unless u r bringing a battery charger and some tools thats the last thing u want to happen is to blow a seel out of town because of the cold.
Old 11-02-2007, 12:58 AM   #3
Re: new to hydros
yeah i don't want to blow i seal. that would suck ass. damn fuel pump went out yesterday. as far as a fabricator, i can make it if i know what i need. which is easier to do though? regular or stock floor?
Old 11-02-2007, 05:08 PM   #4
Re: new to hydros
i just finished my first stockfloor and from my experience a stockfloor is a lot more work and precision than a traditional but the last time i did a traditional was when i was 15 on a fullsize
Old 11-04-2007, 10:52 PM   #5
Re: new to hydros
i will prolly go with the traditional then....since you get the same effect with less work. i am having a problem with the front passengers side leaking down. it leaks down fairly fast to...like within about 10 minutes. no fluid coming out though....so whats the problem? do i need new seals up front or is there just air in there? haven't had the line off so don't see how there could be air in there.....
Old 11-04-2007, 11:18 PM   #6
Cheez-It eater
Lee337's Avatar
Re: new to hydros
do this,
lift the front then close the slowdown valve on the front pump. If it still goes down then it's a bad check valve.
If it stays up, it's a bad dump.
Old 11-04-2007, 11:19 PM   #7
Re: new to hydros
your dump block might be not closing all the way rigth now my front also leaks down but its very slow u wouldnt reaal notice it unless it sat there for like a couple weeks u also could have air in the lines
Old 11-04-2007, 11:20 PM   #8
Re: new to hydros
i mean check valve valve my bad
Old 11-04-2007, 11:22 PM   #9
Re: new to hydros
also one of ur accumies could be leaking nitrogen
Old 12-06-2007, 08:32 PM   #10
undergrounds10's Avatar
Re: new to hydros
If it was a blown seal up front on your cylinder, you would have oil everywhere
