My Backhalf, and juice install......
Go Back   S-10 Forum > Suspension Tech > Juicin' It
LinkBack (1) Thread Tools
Old 01-28-2007, 08:48 PM   #201
5.74x4's Avatar
Re: My Backhalf, and juice install......
looks good man, will your design be kinda like running accumulators on a juiced truck? the bags allowing a ''cushion'' to absorb the roughness that hydraulics are soposed to be known for. i dont have accumulators on my truck and it rides better on cylinders than when it was a 5/6 static so i dont know if i will add them down the road or not. but anyways keep up the good work.
Old 01-28-2007, 10:04 PM   #202
-MMW-
ZEROpsi's Avatar
no auctually it will not function like that really. The air bag will function like a spring normally does in a hydro setup. But instead of having a 3/4 ton or 1/2 ton...or 1 ton.....i can adjust it to any spring rate i choose. An accumulator will have a nitrogen charge that will apply back pressure and instantly dampen the suspension.....
An airbag acts similar to a coil spring.
and an accumulator being applied acts similar to a shock.
just having the air bag with my setup will not let it function like an air bag, the air bag will just support the weight and absorb some of it......adding an accumulator will auctually dampen it and smooth it out.
I will also be running accumulators with this setup.
Old 01-29-2007, 01:29 AM   #203
5.74x4's Avatar
makes sense to me now. i hope i get a chance to see it at a show some day. i don't think we live to far away from each other so maybe we'll attend a show together this season.
Old 01-29-2007, 08:01 AM   #204
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
I like your tolerences man
Cool bags too.
Old 01-29-2007, 08:08 AM   #205
-MMW-
ZEROpsi's Avatar
yea, i dont go to that many shows. mainly because im usually workin in the garage on the truck.......but i will probably get to a few this year with everything hopefully. ITB will be one of them, as will Havok and the RA event.
Old 01-29-2007, 08:58 AM   #206
PUNISHING GROUNDS
got_u_sick's Avatar
Looks insane! Pretty much some of the sickest frame work ive seen someone do. Looking foreward to seeing this thing at Havoc and ITB.
Old 01-29-2007, 11:21 AM   #207
-MMW-
ZEROpsi's Avatar
thanks
Old 03-01-2007, 12:29 PM   #208
forum idiot
orangesonoma's Avatar
cleaned up...keep it clean guys...
Old 03-01-2007, 12:36 PM   #209
-MMW-
ZEROpsi's Avatar
Im not quite sure ware i left off on this last.......alot of my pics got deleted from the origional server....so here goes.....
update pics:
got the cantilever arms, and the bushings for the cantilever.
I machined the bushings for these myself. I bought a chunk of delrin materail, I used to use it alot at my old work for rod ends and what not, and they hold up very well, and last a looong time really, they are alot harder than polyurethane, but i think they will work well for what i want to do. I just cut them down to size and machined the lip on my lathe.
the brackets I designed on CAD and sent out to be lazer cut, they turned out great!
but, i should have the canti together this weekend!
eh, got some work done.
the hardest point is getting everything aligned properly so that it stays bind free through its entire travel arc. I probably had it set up with 30 different bar legnths and natural arc points, and in finally found what worked best. I also figured out a way to get a few extra inches of lift out of everything.....idk what i was thinking when i designed those brackets, but the center mount point should of been higher than the lift source mounting point.......so i fixed that and i will take care of that left over hole later.
I also got all my link bars and wishbone off the truck and offically cleaned and ready to drop off at chrome.....which is finally this week.
enjoi
chrome time!
pictures of the cantilever at full drop:
Pictures of 4" of lift at the cylinder = 10" of lift at the axle....
just overview pics of everything
Old 03-01-2007, 12:36 PM   #210
-MMW-
ZEROpsi's Avatar
the bender and stand.
Old 03-01-2007, 12:37 PM   #211
flat blue and layin frame
BIGGERISBETTER's Avatar
I saw some of the new stuff you did on your SSM and its looking killer. Great job man.
yeah... that stuff ^^ haha. I love the tube work around the rear end.. It all blends really well.
Old 03-01-2007, 12:43 PM   #212
forum idiot
man that looks great...
Old 03-01-2007, 12:57 PM   #213
Tonight the world is mine
TubbD's Avatar
Wow!!!
Old 03-01-2007, 03:53 PM   #214
That is just crazy sickness right there.
P.S. Glad you're back
Old 03-01-2007, 04:15 PM   #215
PUNISHING GROUNDS
got_u_sick's Avatar
Man ol man...that is some of the sickest shit I've seen. Awsome work, keep it up.
Old 03-01-2007, 07:35 PM   #216
-MMW-
ZEROpsi's Avatar
thanks guys
there will be an update this weekend, i cut out the entire cab floor and made it flat.....along with the firewall. I should be finishe dup with the skeleton and bracing of the cab floor this weekend.
pics will follow
Old 03-01-2007, 08:17 PM   #217
Lay'd
BuiltNotBought99's Avatar
Man that is some awesome work bro. One or the cleanest setups i've ever seen.
Old 03-01-2007, 08:27 PM   #218
2.2X-10's Avatar
thats is wild..props to you
Old 03-01-2007, 09:46 PM   #219
feelin a lil flakey
genx-treme's Avatar
Welcome back, and that's some killer work bro....welding all that tubing must have been a pain in the azz...it would have drove me nuts
Old 03-02-2007, 01:05 AM   #220
Astral Weeks
NeverEnough188's Avatar
glad to have you back taylor
Old 03-02-2007, 11:29 AM   #221
Burnt Blazer
black_ice_02's Avatar
love the setup... keep it up man
Old 03-02-2007, 01:15 PM   #222
I Like Fire....HaHaHa
JACKEL's Avatar
Hats off to ya. Thats awesome shit.
Old 03-02-2007, 01:24 PM   #223
Turbocharged Pimp
jimhrabe's Avatar
Good to see ya back I'm looking forward to some updates on this
Old 03-03-2007, 07:48 AM   #224
fiveinchbodydrop's Avatar
im ready to see thisthing in person at all those shows! looks killer man, im green with envy
Old 03-03-2007, 10:41 AM   #225
KentuckyMinis.com
Slammed83Mazda's Avatar
no shit.
Tubing work is incredible Im glad this thread is still going.
Old 03-03-2007, 12:52 PM   #226
dixie highway destroyer
xbrightsidex's Avatar
i'm really interested in this air springs and hydros setup. are you going to have a complete air management setup as well, or just going to fill with a show compressor. also, are you planning on air/hydro for the front too?
Old 03-03-2007, 02:24 PM   #227
-MMW-
ZEROpsi's Avatar
yea, im doing the same setup up front also, with athe air/hydro setup.
i will not be having a complete air setup to control this, maily because i just dont have any room to put it on the frame anyware, I may possibly add a simple compressor to fill it to whatever psi i want, and then, use dump valves to adjust that when needed, but i wont have a tank, multipule compressors, and multipule valves and the whole deal. Maybee on my next project, and i can plan for the layout of everything, but on this ride its not gonna happen.
taylor
Old 03-03-2007, 02:33 PM   #228
taylor
awesome. that's what i was figuring, since those bags should probably never need more than 100 psi really. so just a compressor, a few check valves, and a couple dumps to make it a dump-only f/b. i sure hope you don't ever really plan on hopping with those bags on there though. they won't handle an immense amount of pressure... especially with that crimp ring style.
Old 03-03-2007, 02:58 PM   #229
Mcfly Minis inc
Mcfly Minis's Avatar
Simply awesome fab work.
Old 03-03-2007, 07:26 PM   #230
-MMW-
ZEROpsi's Avatar
yea, im only running 24v so hopping wont be an issue. Im not much into that anyways.
Old 03-03-2007, 08:25 PM   #231
stone the crow...
Draggin97's Avatar
awesome work man! So i take it the bags are to dampen the hydro's? It looks like a real interesting setup.
Old 03-03-2007, 09:30 PM   #232
-MMW-
ZEROpsi's Avatar
na, the bags dont really dampen anything. I mean, even in a nomal air bag setup, just throwing bags in it dosent dampen your ride at all, or smooth it out....adding shocks as well as bags does.
The bags act solely as an adjustable rate spring, instead of a fixed rate. That means i can tune the ride style to that particular day.....if im going to be at a show most the day, or just doing short cruises (which will be most the time) the bags will be filled with a higher psi, to get a more ridgid ride so i can ride o-so-superlow without having any floating, and keeping from bottoming out at all.....Or when im going to be going on a more casual ride, was i may not be driving slammed all the way thare, and may be at a more commor ride height, i will run a medium pressure in the bag, so that it will give me a softer spring rate and have s softer ride, and maybee alittle float.
I will also be running accumulators on this setup, and those will be what is dampening my ride.
Old 03-03-2007, 10:03 PM   #233
bellcranks no more
greencactus3's Avatar
shit thats shexy.. i right click-saved a lot of them!! theyll be poping up in my screensaver every now and then
Old 03-04-2007, 02:52 PM   #234
stone the crow...
Draggin97's Avatar
Thats really neat man, i do not know a thing about hydros but what you are saying makes sense. Keep up the killer work .
Old 03-04-2007, 04:33 PM   #235
bodydropped on 22s!
JMew03's Avatar
wow... thats look great
Old 03-04-2007, 08:27 PM   #236
What to put here?
Nice, and welcome back!
Old 03-05-2007, 03:04 PM   #237
ITS NOT EASY BEING EASY
MODERATOR
Dragginbody's Avatar
welcome back taylor. keep postin pics!
Old 03-05-2007, 05:02 PM   #238
xtrmlow's Avatar
yes more pics why dont you show everyone the new cab floor and bed??
Old 03-05-2007, 05:16 PM   #239
-MMW-
ZEROpsi's Avatar
lol
cus im SLOW!
haha, ill post some pics of the floor soon, i forget about pics on this site sometiems.
they will get posted tho!
tahnks guys
Old 03-28-2007, 01:01 AM   #240
Severed TIES pledge
2 LayLo's Avatar
Any progress with the chrome on this bad boy
Old 03-28-2007, 09:43 AM   #241
TUCKIN
lade-lo's Avatar
where di you get that bender and how much was it?
Old 03-28-2007, 10:17 AM   #242
JACKEL's Avatar
Great question. I'd like to know also.
Old 03-28-2007, 10:27 AM   #243
Pro Hopper Biaa
juiced93's Avatar
looking good taylor shits tits...
hell it almost looks as good as this...
Old 03-28-2007, 11:07 AM   #244
-MMW-
ZEROpsi's Avatar
update eh......
lol
got some update with chrome and what not.....I know its early in the game for chrome, but i wasnt planning on having the chromer get it done so fast......he quoted me a few months, and had it done in a few weeks lol....o well, it looks perty.
also, got most of my cab floor constrcted, and framed it. Im just bascly making a skeleton on the inside for it while its on the frame, then when i send the frame out for powdercoat, i will have a little more room in the garage and will beable to weld the rest of the floor up and put some sheetmetal on it and make the firewall and what not.....
ive gotte alittle work done in the past few weekends, i wish i had actually gotten more done, but ill take what i can get.
since i couldnt find a new bed in my price range....i had to try and salvage the one had. Word of advice, dont stand your bed up on end for any long amount of time....tweaking occurs, and it takes forever to get back to strait.
I knew i didnt want to run any sort of inside to my bed, just a tubing shell and mount it to the frame like that. On the top rails i just flushed up tubing to that when i filled the gap in with welds, it would smooth out flush with the bed top, and give it a nice rounded look on the top side.
again with this, i just want my basic frame installed, then when i take it off the truck and send the frame out for PC i can do all the final welding and tube placment everyware.
Old 03-28-2007, 11:10 AM   #245
-MMW-
ZEROpsi's Avatar
the bender is a JD2 Model 3 bender. Its a great bender....with the dies and everything its about 800$ total, but worth every penny. Every bend on my truck was done with this bender.
At work we use a JD2 Model 4 bender. Its even more kick ass.
JD2 is the place to be when it comes to buying a bender, it really dont get much better for any other bender on the market for under 5k.
Old 03-28-2007, 11:11 AM   #246
-MMW-
ZEROpsi's Avatar
answered above....hope that helps.
I made the stand and hydro conversion from scrap parts i had around the garage......its much better than cranking it by hand lol
Old 03-28-2007, 04:10 PM   #247
Baller Status
DarkGreen03's Avatar
I love the setup, the inside of the bed will look sick, and the chrome looks amazing. keep up the damn good work. I wanna see it come together.
Old 03-28-2007, 06:51 PM   #248
xtrmlow's Avatar
hell yea!! looks amazing!
Old 03-28-2007, 11:57 PM   #249
Severed TIES pledge
2 LayLo's Avatar
looks badass, chrome is amazing on there
Old 03-29-2007, 07:57 AM   #250
JACKEL's Avatar
I found that bender real easily on EBay. Not bad at all. I definitely have to keep that on my wish list.
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f152/my-backhalf-and-juice-install-229828/
Posted By For Type Date
mazdabscene.com ~ View topic - LOOKING FOR THREAD, hybrid air system This thread Refback 09-07-2007 08:13 PM
