#1
MichiganMetalWorks.com
My Backhalf, and juice install......
Ok, i bought a S10 about 1 months ago. When i got it, it was bagged, with a not-so-nice bag setup. I proceded to bodydrop it, cut the frame off and backhalf it, and also juice it.
Here are some progress pics of the backhalf, and juice setup. Since a body drop has been covered millions of times on here, im not gonna post any pics on that, its pretty easy. But anyways. Here is what i started with, it had a really old FBI 4 link on it, and it was a 50 50 setup. It worked for him for years, i think he drove daily on it for almost 4 years, with no problems. But, i dont like air, or the install. I proceded to strip the frame, and take all my measurements, ![]() |
Re: My Backhalf, and juice install......
I then proceded to start the mock up of everything, built the notches, and the lower frame rails, got them all cut and set into place. The setup is made to lay on a 23" wheel. However, i will probably only go with a 22", but the option is thare if something should arrise. The notch looks enormous just sitting thare, but thats because i made the frame continue low to the ground, and not curve up like the stock one.....it gives off an illusion of being way way large, but its not, just enought to lay down on a 23" wheel and tire combo.
Then i capped the ends of all my rails ware i wasnt going to run my wire, and hydro hoses through. Cut out with an angle grinder and welded into place
Here i am with the basic layout of the frame. The back section will house a fuel cell, and two optima batteries. The pumps will be located up front on the lower frame rails. I am running a 10" cylinders in the back, over the axle, with 3/4ton mini coils. the fuel cell is from summit, and it has all steel braided fuel ines. Also, stainless steel brake lines are being added, and all they hydro setup will be done in stainless steel hardline. pics ![]() |
I then 45deg cut all the rear end box tubing, and welded in place the fuel cell location, as well as some more tubular structure. and set the fuel cell in place for fitment.
Now i moved on to making the cylinder mounts, and fabbin them into place, as well as making the tubular members for the support of those. I never had alot of experince with welding notched tubing together.....but im gettin better at it.
I then started plumbing the hydro pumps, with the hardline. That is a ****in bitch, im glad i only have to do it on this install, doin that all the time would get agravating. The complete setup is 2 pumps, 2 dumps, 6" up front 10" back, two optima batterise, 24v street charger.
Im now to the point of finishin the driveshaft hoop, finishin the wishbone for the suspension. Mounting the pumps in theif final location. Then i got hours and hours and hours and hours oof blending welds and shaping everything the way i want it. Then some gussets on locations. all the wires and hoses are going to be routed inside the frames tubing, thats why you see access holes at some points, and ends not capped yet, it will all be hidden inside, besides the cylinders hardlines, those will be visible. Frame is gonna be painted and clear coated. I will update with some mores pics as i get stuff done. Last edited by ZEROpsi : 02-05-2006 at 12:44 PM. |
I cant win for loosing.
sweet frame you got there...
GIT-R-DOWN
nice work
Awesome User
all that work for juice, ugh
looks good man
yea i guess i should have just jumped on the bandwagon with the rest of the country and "bagged it" lol, just like every other 16yo girl right? your probably the typical dusche that thinks that air is something put here by the gods, and if you dont have it...your just not cool. Ive had air setups, hell ive had many air setups, and plain and simple, none of them have been as nice as my juice installs, none have rode as well, or preformed as well. If you cant appriceate work for what it is, your a looser. HAHA. |
thanks for the compliments everyone. Its starting to come along very well now. But its just begining now.
Thanks Taylor |
yea, i was checking it out on SSM the other day. real badass work man.
oh come on guys, can we have atleast one thread without bashing?
Some Day
Ben seriously wtf where is my money please...
Some Day
work looks pretty nice man!
Awesome User
I just hate juice, never have liked it |
damn dude where are you from you do awesome work had a couple of questions for you but don't wanna whore the thread shoot me a pm or email or something if ya can find the time.....
forum idiot
looks nice...
i can tell thers somethin you got on your mind about it. |
i dont give a fuk, whore away lol. What ya need to know? Im from michigan. |
forum idiot
any pics of the truck before you tore it apart? |
i was wonderin how you got your box tubing to bend so nicely what steps did you take? for starters
#24 |
sorry, no other pics. I bought it, and dissassembled it in the same day. And put everything from it up for sale that i wasnt gonna use. it was your typical bagged S10 tho, it was nothing special. But the list of shiet im doing to it is a mile long now. I just got my glass for the chop top, so that went alot smoother thatn expected. And the front end swap is on its way, but i will probably save that for after i do the motor work, just to make sure the room is thare.
I wish i did have stock pics of it tho, kinda pisses me off that i forgot to take any, but o well. Taylor |
#25 |
auctually, there is no bends in the box tubing. I cut out of .25 plate steel my notch plates, and tops. Then welded them in like a normal notch, i just cut them out with my plas, and cleaned them up with the grinder, then welded them in. I threw around the ideas of pie cutting, and bending them, but i just didnt see it workin out the way i wanted it to. So i just cut everything i needed, made a jig for it all, and welded them in place. Turned out good. And honestly, alot of ppl have thought i bent some 2x3 for the notch, but its not. Taylor |
#26 |
damn thats pretty impressive man i doubt i can pull that off so clean looking
#27 |
bodydropped on 22s!
looks great..
i do have a question. whats with the crossmember running under the driveshaft? how much lift can u get? |
#28 |
also what kind of bender are you using for the round tubing i'm in the market for one and was wondering what everyone is using and about how much u paid if u don't mind throwing that kinda shiz out there?
#29 |
Beer, Bait and Ammo
thats pimp shit man,
#30 |
Thanks Taylor |
#31 |
hell yea man thats kinda what i wanted to hear i know the exact one you are talkin about and i will go pick it up ( i don't do much bending at all either) just a bunch of measuring i'm sure
#32 |
NTBSSHEVN
Looks good and nice install on hiding the wires and lines and stuff. What happened to your other truck. I remember you were trying to sell it a while ago. |
#33 |
Taylor |
#34 |
lol, you must not have read the post i didnt bend the box tubing at all. cut and plated my own notch, and capped it all off. I sold my old dime about a year ago, and built a mazda between then and now. then sold the mazda when i was done with it, and now have this. Taylor |
#35 |
NTBSSHEVN
#36 |
i kinda knew what ya ment, i was just farkin with ya. thanks |
#37 |
Mmmm Tire smoke.
Looks nice. Are you building it to hop, or just for adjustability?
#38 |
lol are you kidding?no, its not going to hop. espically with 24v and accumulators. taylor |
#39 |
Got Juce
Thats slick man, I like it . Now post more pics .
#40 |
Lay'd
Nice work man can't wait to see it all finished and painted up. Btw I love juice also.
#41 |
Damn you some nice tube work man wow.
#42 |
run the hydro pump straight to a large 5 gal nitro accumulator. then run you valves from it Jus like an air ride setup. This way you could hap once or twice. then wait for the comp to refill the main tank. This way you could get F,B,S,S with one pump and hop on 24V lolJust a crazy thought. |
#43 |
ASASN8
Damn nice work man, if i ever get enough money i will probably do Air bags, but i love the juice setups, no air compressors, no wait time.
Sweet work!!! |
#44 |
Very nice install...Can't wait to see it wtih the pumps and batteries installed...Where are you planning on putting them, on each side of the driveshaft?
#45 |
Mmmm Tire smoke.
#46 |
you use the work compressor in thare....but a hydraulic setup dosenthave a compressor, and adding one to beable to compress the nitrogen faster....really would be ponintless....... The easiest way to hop with 24volts is to just have the accumulators on a gate valve, to turn the on and off and on whenever you would want to, , then just hop it like normal. And for FBSS on one pump, you can just do a single pump, 4 dump setup. It puts alot of strain on the pump, but there are pumps made specifically for that purpose. I have a feeling im not understanding what your saying tho, idk........ Yea, the pumps are going to be mounted on each side of the drive shaft. And the batteries on each side of the fuel cell. Taylor |
#47 |
I own 5 S10s
just a quick Q thier if ya will
have you ever done a set up with the CLY mounted in a peice of pipe? becus every setup I have seen like that dosent hit sides very well. from what I have seen the cly wants to piviotto the side when you hit sides and witrh the pipe in the way it keeps the cly strait up and down binding up. I have seen a few setup around hear like that. including my old setup. |
#48 |
woof
you're the only dude on juice that doesn't totally hack everything and have horrible taste, nice job zero.
#49 |
if ya read through everything, youll see, its not set up to hit sides. i have no desire to beable to drive down that street sideways. Its a front back setup, ontop of powerballs. And yes, ive done a few setups with the cylinder running inside a pipe, and it allways works wonderfully, and preforms just how i want it to. whitedime, thanks for the compliments, but you should loook around a bit man, there are tons and tons of sick ass hydro installs on minis or trucks or cars for that matter, lots that arent "lowrider" style. And im willing to bet, that there are twice as many hack jobs that involve air ride than hydros. mainly because air is more popular. Taylor |
#50 |
blazin dime
That Is Bad Ace Where In Michigan Are You?
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f152/my-backhalf-and-juice-install-229828/
| mazdabscene.com ~ View topic - LOOKING FOR THREAD, hybrid air system | This thread | Refback | 09-07-2007 08:13 PM | |
