i want to sitt 3 wheel
Go Back   S-10 Forum > Suspension Tech > Juicin' It
Old 11-17-2008, 08:56 PM   #1
i want to sit 3 wheel any ideas on linking?
Old 11-17-2008, 09:06 PM   #2
minituk's Avatar
Re: i want to sitt 3 wheel
Hydro's
Old 11-17-2008, 09:36 PM   #3
yep 18in rear cyc 8s in the front
Old 11-17-2008, 09:39 PM   #4
CANDY_LOW23's Avatar
if you got 18s why cant you 3 wheel? how many pumps?
Old 11-17-2008, 09:40 PM   #5
two pumps!
Old 11-17-2008, 09:41 PM   #6
wheres your set up at? in front of the axl?
Old 11-17-2008, 09:43 PM   #7
ooo... ya you gotta do somethin with them dumps, its a pain. im not sure how, (i only run 4 pumps lol) have you ever cheaked out layitlow.com??
Old 11-17-2008, 09:44 PM   #8
naha i have 4 batts and both pumps mounted up against the tail gate . can only do rolling three wheel.
Old 11-17-2008, 09:46 PM   #9
that might just be a weight issue. or a chain bridge. that will get the nose way up there!!
Old 11-17-2008, 09:48 PM   #10
chain bridge? it is noched and bridged!
Old 11-17-2008, 09:52 PM   #11
what the F!!? the only thing i can think of is put a big fat chick in the back. lol. can you like sit on the back and brign the front up? FYI i have never put hydros on a truck so im shotin from the hip.. sorrry
Old 11-17-2008, 09:57 PM   #12
oh ! and no iv had 250lbs. people sit on the back corner it dosnt work!
Old 11-17-2008, 10:02 PM   #13
man. the cylc ant too close togeather are they? Im at a lose really. maybe you should just buy my CCEs and call it a day... lol
Old 11-17-2008, 10:17 PM   #14
naha i have a 4 pump setup in the atic. but thats for my 63 impalla
Old 11-17-2008, 10:19 PM   #15
ooooo you suck. thats my dream car!!! anyway sorry i couldnt help. good luck!!
Old 11-18-2008, 07:37 AM   #16
manual>automatic
Driveway Kustoms's Avatar
Old 11-18-2008, 02:41 PM   #17
tohoopty's Avatar
need pics of said setup.
Old 11-18-2008, 05:15 PM   #18
Quote: Originally Posted by Driveway Kustomz
oh but ur bolt pepboys stock truck is sooo much cooler!!!!!!! putt some air or jucie on it and acually fabracate somthing instead of playing with bolts than talk to me !
Old 11-18-2008, 05:26 PM   #19
Certified Auto HVAC Tech
layinlow88's Avatar
yea...go get some pics of your setup
Old 11-18-2008, 05:29 PM   #20
heres the pic with the ten inch cyc. but i put 18" in
Old 11-18-2008, 08:26 PM   #21
tohoopty's Avatar
would the 50/50 link have anything to do with it.
Old 11-20-2008, 09:04 PM   #22
yeah i cut that out cuz it binds like a bit*h so im debating on two tings i taking the gas tank out and going to make it a straight 4 link but i was also thinking about mounting my cycl. on th link to get more lift and im just trying to get some ideas b/c i dont want to put it in again and not be able to sit 3.
Old 11-21-2008, 11:19 AM   #23
manual>automatic
you have 11 posts and already trash talking, and get it right I work at advance auto
well this weekend im fabricating my new exhaust so thanks for that...like the others im still waiting for pictures to see what you have actually fabbed up too
edit--mbad didnt see the pics posted already, but Ive seen some ppl use chains or straps to limit rear travel, raising the front end idk jus a thought
Old 11-22-2008, 03:42 PM   #24
Burnt Blazer
black_ice_02's Avatar
3 pump would be best IMO, for standing 3
you want to be able to lift both front and 1 rear.
My dime couldn't lower one side individually without weight or force on that corner. thats why turning helps.
to see if your weight is distributed properly try having someone push down on the desired corner, while lowering that corner. Once its 3'd it should stay. If it falls you need more weight.
Best link setup IMO would be a wishbone 3 link with a heims joint on the wishbone
Old 11-26-2008, 11:48 AM   #25
''true believers''
ftp ride's Avatar
you could even get the wishbone bar from sd with the super pivots.with that you should be able to 3
Old 11-26-2008, 05:08 PM   #26
Nasty Habitz c.c.
NastyRedz's Avatar
I can make it 3. Mine went 3, Use the chain bridge, you can add it to that setup.
Old 12-07-2008, 01:00 PM   #27
a chain bridge will def get more lift out of a system for standing 3... make your chain 2-3 inches shorter than your cyls. when you fully extend your cyl on one side it will push the other side down. (its a fulcrum effect) this is alot better than extra weight or super long cyls. using johnny joints or super pivots will help more than using poly bushings.
Old 01-10-2009, 04:51 PM   #28
whats a chain bridge? havent hered that yet! got a pic?
Old 01-10-2009, 05:31 PM   #29
oh dont u need electrical cutoff valves that allows independent lift of the rear wheels
Old 01-10-2009, 08:13 PM   #30
http://www.layitlow.com/tech/suspens...inbridge.shtml
Old 01-10-2009, 08:44 PM   #31
thanks , but i have a two pump set up . dont think it whould work but then i seen that cut off vale would work but who sells that!
Old 01-11-2009, 05:51 PM   #32
-=Hand Made=-
RD Fabrication's Avatar
all you need to do is use 4 dumps on the rear pump and wire it accordingly... the single pump will then act like 2 pumps.
Old 01-18-2009, 07:36 PM   #33
wait...what?
ura HOE call me's Avatar
Best way would be a do a rear 4-link and add a third pump. Do a chain bridge.
Old 01-24-2009, 10:00 AM   #34
DrivewayCustoms's Avatar
agreed with ^^.two pumps to the back, chains should be about half the length of your cylinders.
Old 02-23-2009, 05:52 PM   #35
deuce deuce!
Kunde's Avatar
Old 02-23-2009, 05:56 PM   #36
deuce deuce!
Kunde's Avatar
the accord is my buddies his set up was 4 pump 4 batt's he changed to 1 pump 4 batt's no chains. he built his own controll arms in the rear for a gangster three wheel.
the blue car is just a reg two pump four batt set up from cce. both cars are ran with accumulators no springs.
Old 05-01-2009, 11:36 AM   #37
Ive heard alot of bad talk about super pivots, like the truck will ride all wobbly, etc... i havent done any setups with them, but curious how they ride...
how much of a difference are super pivots gonna make vs plain bushings on a hydro setup? (so far ideal is cando s-10 fwd 4 link, 12in rear cyl, coil overs, chain shorter than cyl)
Old 05-01-2009, 12:51 PM   #38
-=Hand Made=-
theres nothing wrong with superpivots.. if the suspension is setup properly, its not going to wobble.. the only reason to use superpivots is if you wanna do side to side without destroying normal bushings
