hydro ?
Go Back   S-10 Forum > Suspension Tech > Juicin' It
Old 01-30-2004, 07:47 PM   #1
heresdamanladies's Avatar
heresdamanladies
hydro ?
think this is the right place i have a question can i play with my hydrolics while i am recharging the batterys? thanks
Old 01-30-2004, 07:59 PM   #2
Oh, yea...
Braind3ad's Avatar
Braind3ad
Re: hydro ?
Back when I had dros I never tryed that. But if you're charging it, let it do it's thing bbboooooyyyyyy!
Old 01-30-2004, 08:02 PM   #3
heresdamanladies
Re: hydro ?
lol ok cool thx i didnt know i just bought a truck with hydros and i cant wait for it to charge lol
Old 01-30-2004, 08:10 PM   #4
Oh, yea...
Braind3ad's Avatar
Braind3ad
Re: hydro ?
Well, congrats on your new truck! Post some pics foo.
Old 01-30-2004, 08:11 PM   #5
Lowridn' Papa
Southern's Avatar
Southern is an unknown quantity at this point
Re: hydro ?
I'm tempted to go hydros.
Old 01-30-2004, 08:11 PM   #6
tbranscom
Re: hydro ?
i dont think it would hurt but you'll drain em faster than they can charge.... be paitent!
Old 01-30-2004, 08:16 PM   #7
heresdamanladies
Re: hydro ?
lol thanks alot guys Jason
Old 01-30-2004, 08:18 PM   #8
bawls2thewalls is on a distinguished road
Re: hydro ?
I have a hydro set up on my 99 and you should not be able to play while you are charging because your system ground should be unplugged while charging......I could be wrong though....just my .02
Old 01-30-2004, 08:28 PM   #9
heresdamanladies
Re: hydro ?
whoa how unplug my system ground? is it different on every system? i figured you just hook up neg and positive but i guess not lol Jason
Old 01-30-2004, 08:44 PM   #10
tbranscom
Re: hydro ?
ohh yea disconeect the ground! i forgot its been a while
Old 01-30-2004, 08:58 PM   #11
Can Yah Hear That China!
HelloS10's Avatar
HelloS10
Re: hydro ?
im looking to put some Hydrolics on my s10 sometime into the future, what in your setup determines how many batteries you need, i know on bags that adding vavles will give you side to side and everything as compared to a standard minimum setup, but whatts the deal with the batts i knw they need to be vented b/c they build up hydrogen gas.
Old 01-30-2004, 08:58 PM   #12
SoonToBeLowS10's Avatar
SoonToBeLowS10
Re: hydro ?
There should be a big black platic peice between two wire's.. pull that apart.. that's klnown as your "Quick disconnect" it should be your best freind if anything ever goes wrong with you Hydro's..
Old 01-30-2004, 09:13 PM   #13
Oh, yea...
Braind3ad's Avatar
Braind3ad
Re: hydro ?
And it would normally be under the driver seat for quick access to it. I'm sure you have one, but if you don't, GET ONE NOW!
Old 01-30-2004, 09:15 PM   #14
Oh, yea...
Braind3ad's Avatar
Braind3ad
Re: hydro ?
As for the batts, you don't need a ton of batts, they just give you more power. They let you go up faster and you have gogo-juice for longer.
Old 01-30-2004, 09:43 PM   #15
Re: hydro ?
My setup has 4 batteries (can get up to 48 v), I run them at 36 v. Which gives me plenty of play time......
Your ground disconnect (which you should have one) is used to stop the system in case of a solenoid sticking, dumps sticking open etc. I would recommend that the ground be in the rear of the car or truck.....it is possible for the ground to seize on the connector, which could cause a fire, your car or truck might get blazed, but you will be much safer then putting under your front seat...
I love my hydros, but your ride is not going to be that good unless you get accumalators......remember also there is upkeep with them as well....but there is upkeep with anything.....just treat them good and have someone install them who knows what they are doing.....50% product 50% installer, if all done right you should not have any problems.
Old 01-30-2004, 09:57 PM   #16
woof
whitedime's Avatar
whitedime is on a distinguished road
Re: hydro ?
can someone explain what accumulators are and what they do
Old 01-30-2004, 10:11 PM   #17
Re: hydro ?
Accumalators are placed on the pump, one for each cylinder. They have a nitrogen charge in them that allows them to hold fluid in the 'belly', which acts as a shock absorber which greatly improves your ride, however they will slow the system down a little, but rides great....
Old 01-30-2004, 10:11 PM   #18
I'm poor
motomullet's Avatar
motomullet
Re: hydro ?
reservoirs filled with air, acts like a shock, smoothens out the ride.
Old 01-30-2004, 10:14 PM   #19
Re: hydro ?
motomullet....just to clarify they are filled with a nitrogen charge
Old 01-30-2004, 11:09 PM   #20
Oh, yea...
Braind3ad's Avatar
Braind3ad
Re: hydro ?
Check this out for accumulators. You can learn a lot from this site.
http://www.layitlow.com/tech/accumulator.shtml
Old 01-31-2004, 04:55 PM   #21
heresdamanladies
Re: hydro ?
may bad guys sorry i just now saw there is a actual hydro section thanks for everything guys
Old 01-31-2004, 05:00 PM   #22
heresdamanladies
Re: hydro ?
i dont know about that quick disconnect thingy lol ther is a jumper cable clamp is that my quick dissconnect? ill take a nother look after a while thanks guys
Old 01-31-2004, 05:28 PM   #23
Just a member
burple's Avatar
burple will become famous soon enough
Re: hydro ?
Moved to hydro forum.
Old 01-31-2004, 08:02 PM   #24
heresdamanladies
Re: hydro ?
thanks miniburple
Old 02-04-2004, 12:23 PM   #25
EyePoppin's Avatar
EyePoppin is on a distinguished road
Re: hydro ?
Yes you can do that. But once u are out of Battery power...u cant play anymore...just like air.
Old 02-04-2004, 09:28 PM   #26
heresdamanladies
Re: hydro ?
eyepopin what can i do??? lol thx
Old 02-04-2004, 09:33 PM   #27
heresdamanladies
Re: hydro ?
braind3ad thanks ill get some pics when i weather gets nicer when i can wash her up theres pics on the forum its "the worst truck on the forum" i think thats what its called its got some little 13 rims lol i need new rims bad jason
Old 02-04-2004, 09:47 PM   #28
heresdamanladies
Re: hydro ?
can i charge all for on my batterys with out unhooking all the stuff? just as long as i undo my ground clamp thing? and i have to chargers so i can charge 2 batteriers or is there a way to charge all four at the same time ? thanks Jason
Old 02-05-2004, 10:20 AM   #29
Sittin on Chrome
eacyde's Avatar
eacyde is on a distinguished road
Re: hydro ?
I dont know about all this "Unhooking the Ground" to charge the batteries. Do you disconnect the ground on your main battery to boost it?
Anyway, It all depends on the charger. my charger will only charge 12 volts at a time so I rewire all 4 of my batteries so they are 12volts. some chargers will do up to 96 volts, but they cost big bucks.
Peace
Old 02-05-2004, 10:48 AM   #30
EyePoppin's Avatar
Re: hydro ?
Read the question that u asked in the first post.
Old 02-05-2004, 10:50 AM   #31
EyePoppin's Avatar
Re: hydro ?
What Voltage Does ure set up have, if u have 2 batteries and they are ran at 24 volts no u cant leave them all hooked up unless u have a 24 volt battery charger. I would recommend unhooking everything to charge your batteries.
Old 02-05-2004, 10:51 PM   #32
heresdamanladies
Re: hydro ?
ok cool thanks alot guys i got four batteries ill just charge one by one and un hook everything Jason
Old 02-05-2004, 10:52 PM   #33
heresdamanladies
Re: hydro ?
sorry about that to eyepopping Jason
Old 07-31-2007, 05:53 PM   #34
killadime is on a distinguished road
Re: hydro ?
any pics of the setup..........
Old 08-01-2007, 01:12 AM   #35
Pro Hopper Biaa
juiced93's Avatar
juiced93 is on a distinguished road
Re: hydro ?
holy old scool... get rid of that shit and run a welding lead up under your seat and use that for your ground. get rid of the clamp i ran 2 grounds on my truck one in the back and one under the seat. under the seat was for crusing used the one in the rear when i was outside. i liked having the ground under the seat cause havin to pull over and pull the ground takes too long and im lazy
