How do I charge my batteries?
Go Back   S-10 Forum > Suspension Tech > Juicin' It
Old 07-29-2006, 01:34 PM   #1
No S-Series... Just a GTO
jimmything08's Avatar
jimmything08 is an unknown quantity at this point
How do I charge my batteries? Im a hyrdo newbie, so please help!
Old 07-29-2006, 03:47 PM   #2
registered s10 sex offender
orangesonoma's Avatar
orangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud of
Re: How do I charge my batteries?
with a battery charger...
if you get a 12 volt charger you can only do one at a time...but if you got a selectable one...you can do 12...24...36...48 volts...
Old 07-29-2006, 04:11 PM   #3
lol thanks Brian... I meant, and I should have said this, do I leave them in the car, how long does it take, etc?
Old 07-30-2006, 06:39 PM   #4
**** you
AssDragginSdime's Avatar
AssDragginSdime is on a distinguished road
you can use a 12v battery charger on as many batteries as you want. Just make sure you wire them in parallel. I have 2 6amp chargers for 4 batteries. I throw them on overnight, and there done by morning. each charger is hooked up to 2 batteries. I leave mine in the truck. I guess you could take them out if you wanted to but there really is no point.
Old 07-30-2006, 09:17 PM   #5
Could you explain in parallel?
Old 07-30-2006, 10:06 PM   #6
so you need to unwire them when you want to charge them?
then once they are charged wire them back up?
Old 07-31-2006, 01:10 PM   #7
draggindimes is on a distinguished road
2 chargers! damn. i just bought a 48 volt charger from batterystuff.com and charged all four of my batteries in series in like 8 hours. plus its a lot cheaper than buying multiple chargers. and the damn thing was so small you can fit it anywhere in the truck to take with you if you have to.
Old 08-01-2006, 12:57 AM   #8
benn is on a distinguished road
i had a street charger in me regal it was sweet never had to think about batteries
Old 08-01-2006, 04:12 PM   #9
Guanta is on a distinguished road
to charge your batteries in parallel you connect all the positives together then connect all the negatives together. take the positive lead from the charger put it on the positive post on the first battery. Then take the negative side and connect it to the negative post on the last battery. Make sure its first and last! ALSO DO NOT FORGET TO UNDOE YOUR GROUND WIRE FIRST. i HAVE 9 BATTERIES IF THEY ARE DEAD USUALLY OVERNITE IS LONG ENOUGH.
ALSO DO NOT TURN YOUR CHARGER ON TOO HIGH... THE VOLTAGE IS NOT THE PROBLEM ITS AMPERAGE. DO NOT PUT IT ON HIGH KEEP IT LOW LIKE 2 AMPS OR SOMETHING OTHERWISE YOU WILL COOK YOUR BATTERIES.
Old 08-01-2006, 10:18 PM   #10
why not do them all in series? and get a charger that can handle it...why undo all the wires just to charge them just to hook them up again...i know when i used to fix my buddy hydro cars i used to drive them after i fixed them and i would go thru the batteries in one night....
Old 08-02-2006, 03:08 AM   #11
Got Juce
FoxPak's Avatar
FoxPak
Yeah Orange has the right idea, I got a battery charger from Pro Hopper that will charge up to 96 volts. Made charging my batteries easy as making a pie, or cake. Which ever you prefer. lol
Old 08-02-2006, 08:42 AM   #12
http://batterystuff.com/battery-chargers/48-volt/all/
the second one in on the top is what i had. charge them over night and i would be good for up to 3 weeks
Old 08-02-2006, 09:52 AM   #13
idragbodys10's Avatar
idragbodys10 is on a distinguished road
i charged them one by one...with a small battery charger...each one was hooked about a night...
i would get a street charger....joe has one in is escort....there sweet!
Old 08-02-2006, 02:32 PM   #14
I cant drop $400 on that right now... Itd be nice, but I need to get accums next lol
Old 08-05-2006, 03:38 AM   #15
Banned
scrapin103 is on a distinguished road
you can buy a street charger that chargers ur battries while ur driving... its well worth the $300.00
Old 08-09-2006, 12:53 PM   #16
street chargers are for lazy people. why drop $300 when you can buy a $150 charger, charge all your batteries over night and be good for a month. besides, the streets charger does not charge the batteries all the way. and will cause premature battery failure. you still have to have a battery charger to give them a full charge.
Old 08-09-2006, 01:06 PM   #17
**** $150.... I paid $50 for a one hour charger and it works like a charm. All 4 batteries charged in 4 hours? Ill take it.
Old 08-09-2006, 01:45 PM   #18
Excessive Amp is on a distinguished road
You could get a high output alternator that would charge them while you cruise around. If you have the 4.3L you can get a 300 amp that will bolt on with no mods.
Old 08-11-2006, 10:44 PM   #19
that would only work it you are running a 12v juice setup and most people run higher volts
Old 08-12-2006, 04:18 PM   #20
PLus... I have a civic...
Old 08-12-2006, 10:34 PM   #21
a one hour charger is ok but it does more harm to your batteries than good. the best way to charge a battery is a trickle charge. charge them for a a couple hours. a one hour charger is too harsh on batteries....thats why it only cost you 50 bucks
Old 08-12-2006, 10:38 PM   #22
The other ones (3-4 hour charge per battery) were cheaper...
Old 08-18-2006, 01:54 PM   #23
**** you
i Dont see the big deal in having to move a couple wires around once every 2 weeks or so.. It only takes like 20 seconds to do it.. Depending on where your batteries are, i guess. But Yeah, the slower you charge it, the better. When you charge a battery too fast, it will eventually decrease the life of the battery.
i use 2 $25 chargers from walmart.. there 6amp chargers. with selectable 2 or 4 amp settings as well. Just plug em in overnight. 2 batteries per charger, And they are done in the morning.. My batteries are commercial grade batterys from a tractor trailer, there like 1300CA's and it onyl takes like 8 hours or so to charge 2... So with 2 chargers, i charge all 4 batterys in like 8 hours. And they last for like 2-3 weeks.
Problem with street chargers, or multi battery chargers, Is there just expensive.. Those chargers that do up to like 8 batteries in serise are like $400. And a street charger is between $400-500.. So for me its just easier, to spent $60 on chargers... It would be pointless to spend $400 for something i only have to worry about once every 2 or 3 weeks. And like i said, it takes like 5 minutes to fully rewire the batteries to parallel, and hook up the chargers.
Old 08-21-2006, 12:48 PM   #24
Depending on how many batteries you have and how much you play with your switches will all come in to play when you talk about how long the batteries last. if you only have like three batteries for your front end or something and intend on hitting switches like a mad man then yeah your batteries will be dead in a night. In our crew we all do it the same way.. the charger i have cost me $ 150 Canadian. Its a 12 volt charger and I have 9 batteries i charge them once a week for about 6 hours. They last quite a while and its a lot cheaper than buying alot of chargers.
I find this way only takes me about 5 minutes to get them wired in parallel and then i leave them overnight.
Old 09-13-2006, 03:19 PM   #25
Ryma's Avatar
Ryma is on a distinguished road
how about one of them battery tenders I see on tv.
Old 09-14-2006, 12:38 PM   #26
DOORED HARD
getto's Avatar
getto is on a distinguished road
Talking Re: How do I charge my batteries?
i agree with ass draggin sdime if you hook them up paralell on low amp charge{2amp} overnite it is sufficient,and cheap also check out a golf cart service facility, i got a 36 volt charger from a place like this in phoenix when i lived there fore 150 bucks and i made a plug from my batteries so the charger just plugs in, but just like someone posted in this thread ealier disconnect your ground. my 1st 3 trucks were on juice so in got a little practice over time, used to use 3 cheap chargers but it all worked out about the same for the 36 volt golf cart charger. ps if any body knows peeps looking to trade some juice for bags hit me up on the pm, i want juice back.
Page generated in 0.24380 seconds with 12 queries
