help anyone
Go Back   S-10 Forum > Suspension Tech > Juicin' It
Old 09-14-2007, 06:47 PM   #1
itzmeto's Avatar
itzmeto is on a distinguished road
help anyone
i no its in the stickey faq but the motor spins but truck doesnt go up??? got lots of fluid nothing is leaking im really confused the solinoids click but will not go up...if i use a jack i can get the front up..then down with the switch but will not go up....cann anyone help me??....
Old 09-15-2007, 01:29 AM   #2
drag that shit
oops2low's Avatar
oops2low is on a distinguished road
Re: help anyone
ok i will see what i can do for ya. there are so many different things it could be. i would check your check valve, it might be stuck open. or a dump might be stuck open. are you running a 2 or 4 pump setup? i would check there. it is the cheapest option. if ya have anymore questions hit me up i will help ya if i can.
Old 09-15-2007, 03:06 AM   #3
itzmeto's Avatar
Re: help anyone
how do i check dump and check valve?? when i try to hit it up motor spins then it stops then the solinoid clciks like crazy...im runny two pump but just got the front hooked up....so one pump 2 batt. 24 volts....2 solinoids...
see if any one can see whut ive done wrong...
[IMG]http://i32.photobucket.com/albums/d4/itzmeto/****edupshit.jpg[/IMG]
Old 09-16-2007, 09:11 PM   #4
Addict's Avatar
Addict
Re: help anyone
If the solenoids are clicking like that, it's probably low on voltage. Make sure your batts are charged. Make sure all your connections are good too.
I can't tell from your diagram how your solenoids are wired, there might be a problem there.
Old 09-18-2007, 12:16 AM   #5
itzmeto's Avatar
Re: help anyone
got it all figured out but my batts are dieing fast as hell...
Old 10-30-2007, 07:20 PM   #6
87fleet's Avatar
87fleet is on a distinguished road
Re: help anyone
what was the problem ?
Page generated in 0.09089 seconds with 12 queries
