got a set up.. not sure what to do
ok guys... i need some help... i got a 91 dime and wanted to bag it..untill now...a friend of mine who is into hydros came across a set up for me... "2 pump, 4 dump, 2 8" cylinders, 2 10" cylinders, and 4 bats,and all the lines..." not sure what it is, or were its from. Alls i know is its out of a 64 impala.... what will i need, and what do i need to do to get it on my dime..... and what dose it take to lay out.. thanks!!
oh ya by the way the truck is a daily driver... will it still be after the hydro set up or should i keep savin and go with air ride... ??? thanks agin Last edited by imlayinlower : 05-28-2004 at 09:09 PM. |
Re: got a set up.. not sure what to do
come on guys i need soem help here..... someone post back...i cant stand not layin frame!!
NO H-body, New Dime
hydros are gonna ride really rough, but if you can get a good deal then go for it. If it is your daily driver I would save for bags, but you could just as easily get some shag carpet, fuzzy dice, and wire wheels and pimp the dros. Ur call, I would do bags, not cause I am really a fan of either, but because it is your daily driver.
yuh def not goin to make it a "lowrider" type thing... and yuh im pretty sure im goin to do bags now.. thanks for the coment..
Dude juice does NOT always ride rough.
Depends on what brand, and all that, but you may need front coils, or you can run accumulators... Either way you can set it up to ride like a dream. Get me some more info on the setup, and I'll see what I can do to help you out. |
Welds TOO much aluminum
my hydros on my 89 ride pretty good. I used softer springs, and put shocks in on all 4.
I love hydros
i have hydros on my truck its a daily driver too lot of miles. i did the same thing came across a setup cause it was cheaper then bags..and i just wanted to be adjustable so i got it. its not the best looking right now cause i have to drive it everyday and im savin up my money again once i get my 3 link i should be pretty close to laying out too. but its up to to you whatever you like better
thanks for the help guys.... i got the kit form the kid last night "realy good price..." either way not sure what im goin to do.. i baught all teh steel to make the notches and a bridge today so im goin to start that this week.. teh dro setup has no names on it.. at all nothin, its an all crome set up thats all i can tell you.. the kid i got it from is goin to talk to a couple guys that knew the kid that had the setup and find out what it is.. so ill let you guys know thanks agin
im not going to get on the debate of what rides better or not ETC. Im just going to answer the question. What will you need?
a notch, bridge in the back, either power balls or heim joints to mount the cyls to the axle in the back. a Link setup for the rear (if u wanted one) you can run a mono leaf, but i would run a link, ull need springs for the front and back, possibly accumulators, shocks, see if the setup comes with cups and donuts, does it have a switch box? may want to find out what kinda pumps, just in case something happens then u will know where to get parts, Bulk head fittings to clean up the front hoses, ull need a pump / battery rack. I think that is about it. |
You could always let me have them. Id love to do another low low .. LOL
i need to how to do my back brackets on my 94 s-10 for hydros can somebody give a hand
drill a hole in the bottom of the cylinder.straight through it. Get 2 pieces of 1 1/2 x 1 1/2 x 1/4 wall tubing cut 1 1/2 long. Then cut 1 side off so it looks like a channel. Drill a hole in about the center ( check for clearance so the cylinder dont bind ) I used 7/16 holes grade 8 bolts on 2 rides no probs. Weld the brackets on the rear axle so the cylinders can tip side to side.take 2 donuts weld a piece of pipe in the center of the donuts that fits tight inside the spring. weld another pipe inside your bridge to keep the spring in place on top. if you using a bridge, Thats a cheap eazy way. Or go buy some powerballs. and reverse cups
bring it up here to cleveland and i will put them on.
SK WUT?!?!?
Save for air bags
WiLd-N-oUt
Location: Outside of Gainesville Fl. User is: OffLine ![]() |
Go with the dros!!
Dro's RULE!!!
