Broken Handed Superman
droz messy?
I have heard rumors that droz are messy.. why is this so? i dont know how droz work or anything about them but why this rumore? or truth?
-Mike |
Re: droz messy?
They can be very messy if installed wrong....I have juice on my 99 and have not had any real messes......after a while the seals in the cylinders become weak and fluid can leak from that, but you can buy new seal kits......I have heard horror stories of those who blow a hydro line and fluid goes everywhere.....just take care of and maintain your system and you should not have to worry about it.
Re: droz messy?
what type of fluid goes into the cyclinders?
Re: droz messy?
I used SAE30 non detergent.
///Relaxed Atmosphere
Re: droz messy?
same here. |
dont be a pussy
Re: droz messy?
Re: droz messy?
Oh yea and back to the messyness factor, i have a few friends that had messy juice setups, but will a little maintanince and quality parts it dosent have to be messy. I just got my whole hydraulic system plumed the other day and shot some fluid threw the lines, at first yes i did have a few leaks, all i had to do was tighten the fittings ware the leaks were, and magically they dissappear. Now i have left it lifted for a day and a half now why i am workin on it, and not a drop has come out, i even have paper lineing my garage floor so that i can tell if i have even the slightest leak, it seems to be all set, but im sure i will have some small things to take care of after i put a few miles in the setup. peace taylor |
Resident Pain in the Back
Re: droz messy?
I have a clean setup, seals still good, using 5w30 detergent free motor oil. Let me just put it like this when a line blows it goes everywhere, want an idea? Take a quart of motor oil and just dump it in your bed
Upside is you perform regular maintenance and you shouldn't have to worry about it, check your seals, fittings, lines, etc on a regular basis for cracks and wear, etc and it shouldn't be an issue. |
dont be a pussy
Re: droz messy?
[quote=nKrypteD1]Let me just put it like this when a line blows it goes everywhere, want an idea? Take a quart of motor oil and just dump it in your bed
QUOTE]lol ya I had the happen once, just had the trunk of my car all done up, new panels and materials made, then a line gave out on the right rear cylinder, popped the truck, oil every were! but if you teflon tape all fittings (besides your hose fittings) have em nice and tight, you shouldnt have to worry about leaks |
Re: droz messy?
How often do you have to rebuild the seal's? and what type of maintenance is required?
dont be a pussy
Re: droz messy?
Charge Batteries Check oil levels about once a month from time to time check for leaky fittings and lines not required, but I always suggest replacing solenoids once a year to prevent them from going to hell, because they always go out. |
dont be a pussy
Re: droz messy?
Sittin on Chrome
Location: Calgary, Alberta, Canada User is: OffLine ![]() |
Re: droz messy?
A little quality goes a long way. Besides bustin a fitting once, I have never had a major leak. It is all in the install. Do it right the first time. |
not a such a fatso anymor
Re: droz messy?
Yes chad that is how I always explain it to people hopping = Breaking Sh*t
Mad man from michigan
Location: grand rapids michigan User is: OffLine ![]() |
Re: droz messy?
Re: droz messy?
Re: droz messy?
dont mean to whore but i can use hydrolic fluid right or should i use moter oil??? thx
Re: droz messy?
u can use either, but stick to the same thing. Dont mix both.
