does anyone know about hydros at all
if so i was wondering what all do you got to do to put in the front of a 89 blaze
www.coloradotruckz.com
talk to eyepoppin'...he knows about the droz!
dont be a pussy
Re: does anyone know about hydros at all
easy, pull your front shock, get a 1& 7/8 hole saw, stick the guide bit in the old shock hole, drill out your hole, take your cylinder, slide a donut over the top, take a coil, weld it to the cup, bolt that to the bottome of the cylinder, slide the cylinder set-up threw the underside of the frame, hook up your lines and your golden
thanks i got it all together and by the way when did i post this . i dont know but i have done the hydos my self along time ago. but thanks anyway
Psycho
your getting old if you cant rember
dont be a pussy
lol, its an old post, but it was in the "juicen it" section like it was a new post!?
o ok but a can you help me real quick i got 1 pump right now with one dump . im about to put in 2 more pumps next week with 4 more dumps how many switches can i get off of that more then ten i hope. and if so what moves are they
1 7/8" is a little big, but to each his own. I usually use a 1 5/8"... but this is just splitting hairs... And there is no need to weld the cup to the spring. Use a deep cup, and it won't come apart. The weld will break, and heating the spring will cause it to get brittle. On your truck, I use 1/2 ton full size springs, and cut them down to about 3 1/2 rounds. They ride pretty good, and fit in fine. When you cut them, use a cut off wheel, and not a torch, for obvious reasons... |
Sittin on Chrome
Location: Calgary, Alberta, Canada User is: OffLine ![]() |
So you will be runnin 3 pumps and 6 dumps??? Thats on odd setup. All you need is 4 dumps, then you can do it all. FBSS and standing 3 if you use 2 pumps for the back. I run 10 switches but mostly use 4. |
u can run 10 sw with that setup. |
