http://www.mys10.com/imag
coil over front susp.
I am changing my front susp. from coil under to coil over. Dose anyone have any idea's about using power balls or hyme joints. Also I have a v6 5 speed, any one know about tranny cossmembers being below the frame.
Thanks Last edited by low_life_miniz : 03-24-2004 at 01:49 AM. |
Sittin on Chrome
Location: Calgary, Alberta, Canada User is: OffLine ![]() |
Re: coil over front susp.
I dont have any ideas for you, but I do want to know why you want to go from Coil under to Coil over??
uiced to be juiced
yeah, there's absolutely no advantage to it in an S-10. leave it alone.
The reason why I want to change it is because it bounces too much when driving.
So put shocks on it. Get a kit from Suicide doors, relocate a shock to the outside of the control arm, just like a bagged guy would, and you're golden. Coilover isn't going to help you unless you've got issues with your cylinder hitting your booster.
uiced to be juiced
put some 1 tons in the front, or some springs from a fullsize, then add some accumulators if you want. don't use shocks. you'll blow them before you know it.
accumulators will help, a coil over will not.
you can add shocks but they will have to be good quality and extended travel, since i am sure you are getting atleast 8" front lift. i had some shocks on my juiced truck and had some cheap shocks and only lasted a month. i would also look into ways to running the tallest spring you can. i can lay frame on a full stack of coils. i have the 3" lowered lower control and raised upper spring pocket. more spring = better ride. |
How is putting shocks in the front of a juiced ride any different than on a bagged ride? End result, you're getting lock to lock on the suspension, and with the new valves people are running, it moves just as fast, there's no reason why a good set of shocks wouldn't work if properly installed.
uiced to be juiced
in that case, there's no way for any shock, cheap or expensive, to last on a fast air setup, either. i stand behind my statement.
Coilover will not help the bounce... All it will do is make more work when you have to change out your o-rings... Try a set of softer springs or accums...
not a such a fatso anymor
In my experience I like the the extreme coils for the front of s10's they seem to ride really nice.
Coil over will not help in this sit, as stated above. Shocks will help, but will probably end up getting all blew out.
///Relaxed Atmosphere
i run a half stack of 1ton coils up front with 6" cylinders up front, coil over style, and mine rides wonderfull. Im soo suprised how much better my ride is now that its juiced as compaired to when it was bagged, its a night and day difference.
I have auctually installed and ridden in a dime wiht a coilover front setup with 1ton minis in it, and the ride didnt change much, it seememd to be better than before, but it was hardly noticeable. Peace. Taylor |
