check valve ?
Go Back   S-10 Forum > Suspension Tech > Juicin' It
Old 05-16-2006, 02:14 AM   #1
Got Juice?'s Avatar
Got Juice? is on a distinguished road
Question check valve ?
I’m going to be redoing my setup sometime soon I hope. I’m running 2 pump 4 dump. My question is do I need a check valve on each dump or can I run a line from the pump to the check valve to a T and then to my dumps? I have check valves on the dumps now but I’m trying to go for a cleaner look with hard lines and chrome. I think I can do it but just wasn’t sure if the pressure on the line and the dump when I turn will flow into the other line without a check there. Thanks.
Old 05-16-2006, 08:44 PM   #2
simply
Re: check valve ?
Yes you need a check for each pump... But thats not saying that you cant hide them
Old 05-16-2006, 08:51 PM   #3
Got Juice?'s Avatar
Re: check valve ?
but do i need a check valve for eatch dump or can i just use one on the line?
Old 05-16-2006, 09:04 PM   #4
simply
Re: check valve ?
By the looks of that pic hes running a check on the pressure side of the pump to answer your question i would say no that you need 2 checks if you are running 2 dumps...
Page generated in 0.08187 seconds with 12 queries
