Senior Member
Best Juice Setups
I gettin ready to juice the front of my Sonoma, and I was wondering what companies you guys would recommend going with? I have checked on Red's, CCE, and Prohopper. Any help would be appreciated. Id love to see some pics of your guys front juice setups, also do you guys run shocks on the front setups? Thanks!
Location: Mississippi State University User is: OffLine |
Re: Best Juice Setups
Since you live in Kentucky, I'd say go CCE. Shipping will be way cheaper. You can run shocks, but juice ain't fun with them. Get some 1 ton springs and accumulators instead.
Sittin on Chrome
I agree, Also spend the extra little bit on a pro or comp parts. they are less likely to fail than "street" equipment.
As for pics, ther really is only one way to do the front of an S truck In a nut shell, remove the stock coil & shock get a hole saw and make the upper shock hole as big as the ram cut coil to desired lowness. install ram and cup assy into new hole install coil put the rest back together. Now you need tp plumb the front and go cruising.! Good luck |
Senior Member
If I used shocks would you mount them bout like you would on air bag setup? I appreciate all the input guys!
Yeah, they would mount exactly the same.
Sittin on Chrome
Beyond Basic.
Location: Winnipeg, Manitoba, Canada User is: OffLine |
Have a system where you can easily lock up the car, and disconnect the shocks for show purposes or a cruise night you know your gonna show off a lot. ![]() |
Nasty Habitz c.c.
Yah thats what i do. I have shocks all the way around. Its illegal everywhere not to have them. when i go to the show i can take them out but its nice to have a good ride.I really dont care it still jumps around with them. just not as bouncy
but for ride comfort get some accumulators...niiice and smooth. |
not a such a fatso anymor
Don't bother with accumulators for the front just use 2 to 3 turns of your stcok springs and leave your sway bar you should be good to go. I am working on a setup right now that I will post pics of when done. I haven't seen anyone else do this type of setup yet so I think it is turning out very well. Oh it is on a 96 s-10 standard cab.
