battery HELP
Go Back   S-10 Forum > Suspension Tech > Juicin' It
Old 09-22-2007, 05:39 PM   #1
itzmeto's Avatar
itzmeto is on a distinguished road
battery HELP
how come my batteries are dying so fast?...they are a year or two old...maybe they have seen their life?....sometimes they dont charge to 100% either...i hit like 8 switches they are already starting to die? shouldn't i be able to hop with 24 volts...also was woundering why solinoids are ran in series not parrellel?...batteries have 600 cold cranking amps, 750 marine cranking amps?....HELP
Old 09-22-2007, 09:21 PM   #2
Cheez-It eater
Lee337's Avatar
Lee337 is on a distinguished road
Re: battery HELP
There's no way you're going to hop on 24v...unless maybe it's a Ford Festiva without an engine.
What setting is your charger on when you charge the batteries? You should charge them overnight @ 2 amps for a nice full charge.
as for the solenoids....In series, if two of them open and one sticks closed, the two that are open will kill power to the motor. In parallel, you would lose the safety feature of having multiple solenoids able to open the circuit to the motor in the event of a solenoid sticking.
Old 09-22-2007, 11:08 PM   #3
itzmeto's Avatar
Re: battery HELP
wull im not looking to hop but it should still come up fast enough to almost lift tires.....its slow as hell going up like a 1/4" bag setup...and should last longer than 20 minutes..
Old 09-22-2007, 11:09 PM   #4
itzmeto's Avatar
Re: battery HELP
i put my charger on % charged...
Old 09-22-2007, 11:09 PM   #5
itzmeto's Avatar
Re: battery HELP
at 2 or 30 amp....
Old 09-25-2007, 08:47 PM   #6
dont be a faggit..drag it
dshznit91's Avatar
dshznit91 is on a distinguished road
Re: battery HELP
you should charge your batteries at 2 amps. unhook the battery cables on your batteries and charge them 1 at a time for a maximum charge.as for the lift, the more volts you have the faster its going to be.i ran 6 batteries @72 amps on my s-10 and 1 hit of the switch my truck was off the ground.it also depends on the # pumphead you are using in your hydraulic set up. i had #9 in my hi-low set up
Old 09-25-2007, 10:20 PM   #7
blue blazer ed's Avatar
blue blazer ed is on a distinguished road
Re: battery HELP
I see a few things wrong. The noids should be mounted on the rack or have some way to know that there is a good ground to there. The spot I see them on doesnt work too good. The pumps looks to be mounted on a painted surface , even the mounting bolts could not have good ground cause the paint. The batteries you have take longer to charge than group 31 's. Too your batteries maybe just old. You say your running the system on 24v? But in the pic you have 4. So you just using 2? Your gear also has something to do with it , if its too large of a gear it need more voltage to move because of the amount of oil it trying to move. Another thing your oil has to be as thin as possable, if its too cold out and you have heavy oil , it will be to thick to move too.
Old 09-26-2007, 06:06 AM   #8
dshznit91's Avatar
Re: battery HELP
what type of oil are you running. I had ND-30 and it ran pretty good.
Old 09-26-2007, 03:56 PM   #9
itzmeto's Avatar
Re: battery HELP
im running 30 weight....yes just using 2 batt..if they wasnt a good ground wouldnt it not work???....and bad ground can kill batteries faster??
Old 09-26-2007, 06:44 PM   #10
CHANGE YOUR EMAIL ADDRESS
Independent
Re: battery HELP
That setup looks a bit hokie. I would definitely clean it up some, make sure there is rubber underneath the batteries, also make sure that the solenoids are mounted on bare metal for a good ground. The pumps are also self grounding, so they will need to be mounted on an unpainted surface. Once you do that, spend some bread on a street charger. Then you will no longer need to charge your batteries, and they should last a lot longer.
Old 09-26-2007, 08:40 PM   #11
itzmeto's Avatar
Re: battery HELP
im not into tha street charges heard alot of bad things about them such as they dont charge batteries to the fullliest and will kill batt. even faster....then they are expensive as hell....id rather just thro them on a charger over night.....whut do u mean by "HOOKIE?".....i plan to relocate everything under the bed for corrosion purposes....
Old 09-27-2007, 06:52 AM   #12
Re: battery HELP
Why dont you use all 4 batts? The settup will work with 2 but 3or 4 is best at the least. Again what gear size you have? For low volts you should use A small gear like a street or china gear.
Old 09-27-2007, 08:29 AM   #13
Independent
Re: battery HELP
Hokie, as in solenoids mounted to the front of the bed, two random batteries not hooked up, rusted piece of box tubing holding the batteries-just generally not clean setup. As far as the street charger goes-not true
Old 09-27-2007, 12:38 PM   #14
itzmeto's Avatar
Re: battery HELP
one of them doesnt hold a charge what so ever and once i charge the ones i have they dont stay ****in charged...and the little battery on the right starts the truck.
Old 09-27-2007, 11:26 PM   #15
Re: battery HELP
I would get new ones, and run it on 3 and 1 to the truck like you have now.
Old 09-28-2007, 02:50 AM   #16
itzmeto's Avatar
Re: battery HELP
thanks for the input!
Old 10-02-2007, 11:52 AM   #17
Beyond Basic.
Basic's Avatar
Basic is on a distinguished road
Re: battery HELP
1) 2 amp charge, 3-5 hours a battery should fully charge them.
2) Yeah, get 4 new batts if these ones are toast.
3) Lately its been a lil cooler at nights, your system is going to be quite a bit slower than it would be if it was +20 out. YOu can still run your hydro's during the winter if you really wanted to, I did. Just make sure your batteries are always fully charged.
4) Is that daves old setup?
Old 10-03-2007, 05:27 PM   #18
itzmeto's Avatar
Re: battery HELP
yah it is daves old setup....wont i end up blowing seals and shit if i run thru winter?
Old 10-04-2007, 02:52 PM   #19
Beyond Basic.
Basic's Avatar
Re: battery HELP
Well, I didn't say it was a good idea, just said you could. LOL
If you leave your truck at a good height, use a good oil, you should be able to do it. Dont hit your switches to much, they WILL be as slow as hell. As for seals, they're really easy to change on the cylinders, never taken apart a pump enough to change one, but I couldn't imagine them being to hard to either.
Either way, i'm sure you'll encounter a leak or 4, it comes with the territory.
IMO I wouldn't drive it in the winter, coming out to a BD'd truck on the ground isn't worth it, especially when you can throw in some springs without the cylinders in there and drive on those.
Old 10-04-2007, 06:48 PM   #20
itzmeto's Avatar
Re: battery HELP
not like i intend to drive it thro winter hellz no but im might have to drive it till the end of october....but well see.....
Old 10-30-2007, 04:08 PM   #21
87fleet's Avatar
87fleet is on a distinguished road
Re: battery HELP
you need group 31 batteries with 1000cca and some fresh ground's all around just my 2cent's
Page generated in 0.18199 seconds with 12 queries
