anyone know the best way to fix a frame problem?
I just put my setup on, no reinforcing and when I lifted the truck the frame above the axle (an obvious weak point) got pulled down.Like the leafs pulled the frame down in the back. I could tell when it looked like my bed was being tweaked down and the gap between the cab and bed was larger at the top than the bottom. there is a bow on the outside of the frame and a small bend inward on the bottom of the frame rail, I could see, with the rear bumper off, the passenger side frame was about an inch lower than the driver side the bed looked a little off too nothing major yet but I ripped it all apart and want to fix it now. Will welding 1/4 inch steel along the outside of the frame along that weak spot fix the problem, can I box it in some places, I don't know if I can get too the inside that easy.
help!!!!!!!!!!!!!!!! |
bellcranks no more
Re: anyone know the best way to fix a frame problem?
first off. leafs?
yes dropped leafs, I know that helped cause the frame to bend, the leafs pulling down on the ass, but I don't see a 4 link any time soon
drag that shit
x3 you have to lose the leafs.the stress the cylinders put on them makes the frame bow in weak spots. an after time it will crack or even worse snap completely
is the SD link kit the cheapest? kinda pricey
I need some ideas and maybe anyone with pics of link kits with hydros. |
you need to take your truck to a bodyshop so they can pull it back to factory specs, only solution, other than the SD backhalf
87extcab longbed w/ juice
i was running monoleafs but i just got a 3link from silver star customs, for $300 its pretty badass, they can even do some custom work to your 3link for another $50. i believe they're in mississippi if ya call em ask for clyde he's the man out there.
V.C. WOOT
i always thought i was going break my drop leafs... i hopefully will be able to afford a link set up when i do mine again
DOORED HARD
