Accumies
Go Back   S-10 Forum > Suspension Tech > Juicin' It
Old 10-29-2007, 12:04 AM   #1
juiced dimebag's Avatar
juiced dimebag is on a distinguished road
Accumies
alright i got a 2000 chevy s10 4.3 extended cab and i am running accumies up front and 2 ton coils as well just lay and play i have like only 3 turns.... but i am wonering what psi i should be running for that smooth cadillac ride
Old 10-29-2007, 11:37 PM   #2
blue blazer ed's Avatar
blue blazer ed is on a distinguished road
Re: Accumies
How does it ride now? Have you ever rode without them?
Old 10-30-2007, 12:55 AM   #3
Re: Accumies
haha ya i drove it for a day before i had them ptu on and unless i hit a big bump it rode like i was just running straight cylinders no accumies or nothin with the combo i have now it rides pretty good but i know it could be better
Old 10-30-2007, 01:10 AM   #4
5.74x4's Avatar
5.74x4
Re: Accumies
i think 2 tons are a little stiff, try swapping to 1 tons and see how it rides. i have 1/2 ton coils on my truck cut down to 4 coils with no accumulators and i like the way it rides. i have accums on the rear with the SD 3 link and it rides great
Old 10-30-2007, 11:37 AM   #5
Re: Accumies
How many turns of coil do you have? What size motor you got under the hood?
Also what h kind of accums do you have , are they new or used? If used , the old owner might have let the pressure out.
Old 10-30-2007, 03:57 PM   #6
87fleet's Avatar
87fleet is on a distinguished road
Re: Accumies
i run 400psi to the rear and one tons on the front and i have a nice ride
Old 10-30-2007, 06:06 PM   #7
Re: Accumies
the motor is a 4.3 i have about three turns its a coil over and they r new accumies from coolcars im talkin about the front end not the rear
Old 10-30-2007, 11:56 PM   #8
Re: Accumies
pics , lets see what your working with.
Old 10-30-2007, 11:59 PM   #9
Re: Accumies
its a coil over because when i built the front end on this truck i set it up for running just straight accumies so i built tubular a arms and then put a hiem joint at the bottom of the cylinder so their is no lower spring cup and i went threw one set of accumies already so i just put the spring in their to help out the accumies so they dont wear out so fast remember this isnt a hopper its a lay and play on 20s and no its not a 4x4
Old 10-31-2007, 12:00 AM   #10
Re: Accumies
i will try to get pics up soon but i have to barrow my buddies camera
Old 10-31-2007, 12:04 AM   #11
Re: Accumies
here was the old setup before i got rearended i am running bags and hydraulics
Old 10-31-2007, 12:09 AM   #12
Re: Accumies
one more of the rear if u look closely u can see the bags under the cylinders basically actin as a coil also the 2 pumps on the outside are for the front as u can see the accumies on them and the middle pump for the rear
Old 10-31-2007, 12:51 AM   #13
Re: Accumies
so why is it coil over in front?
Old 10-31-2007, 01:01 AM   #14
Re: Accumies
have u read anything i have posted!!!
Old 10-31-2007, 01:03 AM   #15
Re: Accumies
never mind i guess ill just get a nitrogen bottle and play around with them a bit
Old 10-31-2007, 01:06 AM   #16
Re: Accumies
the reason its a coil over is because i have no lower spring cup so instead of going threw the trouble of makin one it was easier just to make it a coil over to tell u the truth the coil really isnt doing nothin except give me more lock out
Page generated in 0.15131 seconds with 12 queries
