I <3 Primer
What's the longest sawzall blade available?
I need to cut a piece of 1/2" tubing on a piece of equipment but the blade needs to pass through a narrow opening and reach the tubing that is about 14" away from the opening. Is there a sawzall blade that is longer than 12"?
Tech Mod
![]() Age: 25
Re: What's the longest sawzall blade available?
I'd like to say "no" but honestly that is just a guess. any blade that long wouldn't be sturdy enough to cut anything i would think.
how narrow is the opening? if anything you could always get a piece of round bar steel, grind one end down to fit into the sawzall, then weld the blade to the other end? kinda sounds ghetto i know, it would be a one time thing but it would work... any pics of the equipment and the piece you are trying to cut? maybe someone else can get an idea IF there is not long enough sawzall blade. who knows, could be other ways to cut it so just throwing ideas out that come across my head this late
Heavy Metal Body Man
Mathius |
I <3 Primer
4x4 v6 blazer
Good luck. I've tried this before and the welding screws with the blades temper and they always break easily.
The guys over at shopfloortalk might have an idea. They might even know how to re-temper the blade once you've welded it together. <shrug> Depends on how much effort you want to put into research.
Mathius |
My mirror hates my sub
make your own.. get a piece of bandsaw blade, cut to length, cut the end so it fits in the sawzall.. problem solved
Have to be a pretty heavy bandsaw blade. Most of them are pretty thin unless you find a big unit and I think they'd just be too flimsy for the rpm's a sawzaw puts out. I could be wrong. Mathius Last edited by Mathius; 11-11-2010 at 09:10 PM. |
| Sponsored Links | |
Advertisement | |
