"pipe" bending?
ok so i got a peice of pipe today od 1.66 and a .140 wall, i got it real cheap compared to some DOM tubing, my question is am i going to have trouble bending this pipe into 45 and 90 degree angles? the guy told me to buy dom tubing if im going to bend it but i didnt listen... o and im going to be useing this for my frame kind of like some web stuff over the notch
is a fungineer
Re: "pipe" bending?
Uh, yeah, you'll want tubing and not pipe.
<3's EDM
Re: "pipe" bending?
agreed
Re: "pipe" bending?
so that means it cant be bent then ok thanks
Re: "pipe" bending?
Thought I'd just expand on the responses you got... which I agree with. |
Re: "pipe" bending?
Re: "pipe" bending?
Custom User Title
Re: "pipe" bending?
is a fungineer
Re: "pipe" bending?
If you have regular welded seam tubing, the strongest way to bend it is so the seam is on the inside of the bend radius, that way it has to stretch the least. That being said, I bet you don't need DOM. For our circle track cages, we use regular welded seam tubing and it holds up just fine. It takes a lot of force to split the tubing on the seam, and (in our cars at least) if the seam splits that's the least of our worries, stuff is majorly F'd up. Last edited by ka_jd7and1 : 06-01-2009 at 12:30 AM. |
2legit2quit
Re: "pipe" bending?
ERW tube is generrally fine if you want to save a few bucks compared to DOM. Pipe should not even be an option unless you are putting in a new shitter.
