hack is wack
lincoln power 180C welder
hey was thining about getting this machine but im a bit confused about the this: It's a portable wire welder designed for use with industrial 230 volt input power, so you can weld on thicker material - up to 3/16" with MIG welding and 1/2" with gas-less flux-cored welding.
I know that it means i can get more power out of it which is what i need cuz i cant afford a 220 MIG, but i dont understand how it achieves so much power? I also dont understand if it is the small plug type or do i have to have a 220 plug in? Anybody know whats up with these things looks like a good deal to me if i was just more knowledgeable about the features it would help. |
hack is wack
Re: lincoln power 180C welder
oh heres the number: #K2473-1
I know how to weld and everything just dont have a lot of time setting machines up and fixing them when they break. |
It is Most likely the 50AMP Large Edison connector (220V single phase)
![]() May or may not have the bottom Neutral Pin |
Also it is an inverter style welder, much more efficient then the older 'magnetic' or transformer based welders you may be used too.
hack is wack
ok damn i thought 180 meant is 180v lol so this would be safe to weld 14inch and 3/16 in a single pass. . i need to be able to do frame work and ive also been lookin at the miller 140 everyone says they cant weld 1/4inch and 3/16 but it says it can on the ads
4x4 v6 blazer
Good welder, I have an older 180 out in the shop that I use.
