The Family Dragger - Page 19 - S-10 Forum
The Family Dragger
Old 07-29-2015, 08:52 PM   #901
Deadlines are Overrated
wirrrey21's Avatar
Re: The Family Dragger
Quote: Originally Posted by flawlessfab
Could you take a few measurements for me on the front clip
I'm looking for distance between both upper shock mount holes
The distance between rear and front upper control arm mounting studs
The distance between rear lower control arm mounts (bolt center line is fine)
And maybe a cross measurement on upper control arm mounts
I think my front clip is tweaked and I need to straighten it before I proceed with stfbd
Thanks in advance if you can get these measurements
it's dark out now, i'll try to get them measured before work tomorrow.
Old 07-29-2015, 08:53 PM   #902
wirrrey21's Avatar
alittle progress from today though
Old 07-29-2015, 09:43 PM   #903
i greatly appreciate it!
Old 07-30-2015, 08:19 AM   #904
No Money Noma
Laydout'noma's Avatar
You sure did make building a frame look easy! It turned out nice man.
Old 07-31-2015, 07:22 PM   #905
wirrrey21's Avatar
rear upper control arm stud.....22 3/4
front upper control arm stud....25 5/8
distance between studs on the same side(center to center).....7"
lower rear control arms(with bolts through the front and measured from the tranny side).....22 3/8
upper shock holes(center to center)....29 1/2
Old 07-31-2015, 07:25 PM   #906
wirrrey21's Avatar
thanks bro!! i just kept it simple.
Old 07-31-2015, 08:39 PM   #907
Thank you so much!
Did you measure the control arm studs from tip to tip ?
Old 08-01-2015, 08:54 AM   #908
wirrrey21's Avatar
Thank you so much!
yes. the center of the tip to the center of the tip
Old 08-01-2015, 11:54 PM   #909
AaronK's Avatar
So pretty! I like the blazer tank idea. Never thought of that.
Old 08-03-2015, 04:18 PM   #910
18incrawler's Avatar
Looks killer and just a reminder, make sure the tank has enough clearance to the ground that when you got the front end locked up and the ass draggin your tank aint draggin with it! Its got me a few times I forgot about how much difference there is with the ends up and down.
Old 08-03-2015, 07:05 PM   #911
I have the disease
blazerlow's Avatar
Looking awesome.
On my blazer that tank sat too low so I raised the mounts about 2 inches to keep the tank off the ground.
Old 08-03-2015, 08:44 PM   #912
wirrrey21's Avatar
thanks guys for the reminder.
i spaced the tank 2 1/4" off the ground using the 6ft level. but i forgot to factor in the straps i'm making. so after those pics above, i spaced it up another 1 3/4". unfortunately, that's where it has to stay cause that leaves me with 1 1/2" between the top of the tank and the underside of the bed.
i dont plan on draggin this thing nose in the air. if anything it'll drag door.
Old 08-10-2015, 11:37 AM   #913
wirrrey21's Avatar
need alittle assistance guys. i'm trying to figure out an easy, but clean way to mount the tank. i want it to be able to unbolt from the bottom so if i have to service the pump....i don't have to take off the bed. i could always just buy the stock brackets, but i'd like to avoid that. i've had a few ideas, but mounting becomes the issue. i was thinking of welding chain for the top and bottom straps. it'd be cool and different, but alot of my friends explained to me that the welds on each link would be taking the brunt of the weight and eventually fail. it would also be ALOT of work for something getting covered by a bed floor. i guess i could always just use 1x2 laid flat and mitre cut to follow the contour of the tank, cap the ends and run a bolt from underneath into the xmembers on each side of the tank. then run a strap over the top.
Old 08-10-2015, 06:57 PM   #914
No Money Noma
I would think it would be pretty easy to make a cradle, a lot like mine; however, instead of welding it, make some hefty tabs that would bolt it to the frame. That way all you would have to do is get it up and put a jack under it and zip the bolts out and then let it down. As far as what you could do to the top to hold it in place, some kind of strap like you said would work I'm sure.
Old 08-11-2015, 02:32 PM   #915
welded top strap and lower craddle that bolt up to it.
How did you hear about us?
Enter a URL or Site name of who refered you to this site. (required. Only admins can see this)
State
Please enter your two letter state name to help other users and clubs find local users to them.(required)
Insurance
Please select your insurance company (Optional)
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
