The Family Dragger - Page 18 - S-10 Forum
The Family Dragger
Old 05-28-2015, 11:52 AM   #851
Deadlines are Overrated
wirrrey21's Avatar
Re: The Family Dragger
so how do you guys get those really cool mitre cuts to line up perfectly? everytime i've tried one, i always get a gap at the top.
Old 05-28-2015, 12:24 PM   #852
Layed Out Fabrication
bdydrp18's Avatar
chop saw and a little grinder work plus beveling the edges to get a better weld
Old 05-28-2015, 02:45 PM   #853
wirrrey21's Avatar
i'm talking about the way an angled piece would come into a horizontal piece. there's always a gap at the top where the two pieces meet. or am i supposed to angle cut the horizontal piece to make the cuts line up better?
Old 05-28-2015, 03:34 PM   #854
wirrrey21's Avatar
nevermind....i figured it out...you split the angle between the two pieces.
Old 05-31-2015, 10:08 AM   #855
wirrrey21's Avatar
welded the axle in place. should be cutting the frame out today.
Old 06-01-2015, 07:42 AM   #856
wirrrey21's Avatar
didn't get as far as i wanted, but i was trying to be careful around the body mounts.
my next day off is thursday, so i'll cut the rest of then.
Old 06-01-2015, 07:46 AM   #857
nfamus10's Avatar
Get it son.
Old 06-04-2015, 07:20 PM   #858
wirrrey21's Avatar
i was playing around with the angles and just seeing how things were gonna lay out.
Old 06-04-2015, 07:58 PM   #859
nfamus10's Avatar
Hope you don't have to modify your cab. Starting over is refreshing after f'ing with some crap you don't like for so long.
Old 06-08-2015, 12:50 PM   #860
wirrrey21's Avatar
progress from this weekend
Old 06-08-2015, 12:55 PM   #861
wirrrey21's Avatar
Old 06-08-2015, 01:05 PM   #862
wirrrey21's Avatar
Old 06-08-2015, 06:02 PM   #863
I can't seem on angle gauge when I zoom in
What angle you running your transition at ?
Old 06-09-2015, 07:03 AM   #864
wirrrey21's Avatar
Quote: Originally Posted by flawlessfab
i can't seem on angle gauge when i zoom in
what angle you running your transition at ?
30*
Old 06-10-2015, 05:42 PM   #865
That will clear lower portion or firewall floor
I can't remember if yours is stock or not
Old 06-11-2015, 09:09 AM   #866
wirrrey21's Avatar
yeah, it will clear. the floor i built was 3/4" above the transition before. i measured off the body mount on the cab where the floor contours are so i knew where i had to be to clear. also i gained 1/4-1/2" when the skid plate swung down and now lays flat with the rest of the frame.
Old 06-11-2015, 05:42 PM   #867
Thanks for the info
Old 06-11-2015, 06:01 PM   #868
wirrrey21's Avatar
Thanks for the info
but look at how far i cut into the stock frame to make the 30* work. that also gave me more room.
When i put the cab back on and i see there's a conciderable amount of space between the frame and the floor, i may consider redoing those floor sections to give me back alittle pedal and foot room.
Old 06-11-2015, 08:02 PM   #869
FAT GUY IN A LITTLE TRUCK
DOORDRAGGER's Avatar
Looks like good start & great plan. Wish I woulda built a 4 door now.
Old 06-12-2015, 05:13 PM   #870
Ya I plan on cutting mine right behind control arm mount also
And plan on building a smooth firewall and cab floor
But wanna retain as much foot space as possible
Plus I'm moving can back 3/4 for centered wheel and smaller tubs
Old 06-12-2015, 05:41 PM   #871
wirrrey21's Avatar
well moving the cab back is gonna help you more than you think. you'll have more room than me.
Old 06-14-2015, 08:57 AM   #872
wirrrey21's Avatar
alittle progress from this weekend. had planned on getting all the cuts perfect and bevelled but things came up and had to stop working before it got the horizontal rails where i wanted them.
quick little 15* cut and it'll line right up.
I forgot to cut this back 1/2" before i did the 15* cut so i'll cut it back and this side will line up too.
Old 06-14-2015, 09:56 PM   #873
Looking good
Old 06-16-2015, 06:15 PM   #874
wirrrey21's Avatar
got the angles fitting alittle better. and just as i was about to start figuring out the angle up towards the axle.......it starts to pour. GD!!!!!
i have the wood between the rails so i know they're spaced evenly apart and going straight back.
Whats a good angle i should go up to the axle at? Or should i bolt a lower link bar on and see where it would be?
Old 06-16-2015, 06:50 PM   #875
No Money Noma
Laydout'noma's Avatar
You got those angles to come together very nicely! Good job. I know how time consuming that can be sometimes
Old 06-18-2015, 08:45 AM   #876
wirrrey21's Avatar
alittle more progress
Old 06-18-2015, 06:02 PM   #877
Looking good
Moving right along
Old 06-24-2015, 11:05 AM   #878
wirrrey21's Avatar
Had a quick 2 hours to get some work done. So i got the cut leading into the notch done. Nailed it on the first cut on both pieces. I'm trying to figure out what angle i should come down at behind the axle and leave me enough room for the stock s10 tank.
Old 06-26-2015, 10:39 PM   #879
i don't like people
Retro Ten's Avatar
wow didnt sign on for a bit but you sure changed things for the better. don't do stock tank go with the 2 door blazer tank, it will be so much easier. you can mod your pump to fit it also. good looks mikey!
Old 06-27-2015, 09:54 AM   #880
wirrrey21's Avatar
yeah, buddy!!! been super motivated. there were so many things off with this frame the more i cut into it. the 2x3 that was under the cab wasn't 3/16 wall like i thought......it was 1/8" and the backhalf was 1/16 wall. he also got wind that i cut the frame off and we had words over text. he basically knew the skid plate didn't lay out. he set the frame up with the wheels still on it and said we never talked about him doing the extra work to lay the front out....my reply was...."just unbolt the rims....the skid plate would have layed out then. it's common sense". i was so freaking mad. but needless to say, i'm building it better and MUCH stronger.
here's work from yesterday.....
dualing frame rails!!!!!(insert banjo sound)
Old 06-27-2015, 10:27 AM   #881
Independent
sonomaguy's Avatar
I really don't understand why some people get so upset when you buy something from them and them modify it? It's yours, you could burn it to the ground if you want. If they claimed one thing when you bought it knowing they were lying they are just better off to keep there mouth shut and hide. Good for you for fixing the weaknesses in it.
Old 06-28-2015, 09:17 PM   #882
No Money Noma
Holy shit 1/16th" wall! That's what I made my latter rack out of and I would never ever consider that for a frame....ever!
Old 06-29-2015, 06:18 PM   #883
wirrrey21's Avatar
so all the pieces of the frame are tacked together and right where i want them. my next day off i'll tack the new rails to the table and move the axle into a "ride height" position. What do you guys figure is a good place to be at ride height? 5" below the notch? 6? right now it's 1/5" below the notch at what would be laid out. Or can i just swing the bars up and keep moving with the axle in this position?
Old 06-30-2015, 01:21 PM   #884
22RET Powwwa inside
stockfloordime's Avatar
I set my ride height to 4" when I set all my stuff up
Wow 1/8" wall and 1/16 wall tubing unbelieveable
How did you hear about us?
Enter a URL or Site name of who refered you to this site. (required. Only admins can see this)
State
Please enter your two letter state name to help other users and clubs find local users to them.(required)
Insurance
Please select your insurance company (Optional)
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
