The Family Dragger - Page 16 - S-10 Forum
The Family Dragger
Old 03-09-2015, 08:32 AM   #751
Deadlines are Overrated
wirrrey21's Avatar
Re: The Family Dragger
Had some good progress, and some bad progress on the truck this weekend.
Saturday i tried buttoning up the motor by getting the rocker arms tightened down. found out that my lifters are frozen from sitting for 3 years. Ordered some new lifters. they should be here weds.
Sunday, A couple of club guys came over to give me some help. they started welding on the floor while i cleaned and primed some pulleys, brackets, and the oil pan. I'm going to try and get a coat of paint on them first thing tomorrow morning.
Old 03-09-2015, 06:23 PM   #752
22RET Powwwa inside
stockfloordime's Avatar
Can't wait till this is done it's so awesome
Old 03-10-2015, 04:37 PM   #753
wirrrey21's Avatar
got a coat of paint on a couple pieces this morning before work
thats only 1 coat. after they dried, the blue dulled....alot. i'm gonna put another coat on them and hope they shine up. otherwise i'll buy a can of clear.
Old 03-10-2015, 07:22 PM   #754
22RET Powwwa inside
I like the color looks nice
Old 03-12-2015, 09:36 AM   #755
Nice!
Old 03-12-2015, 05:34 PM   #756
wirrrey21's Avatar
alittle progress from today.
Not sure if i should paint the bolts silver, or blue so they blend in.
Old 03-12-2015, 07:37 PM   #757
dnyce's Avatar
i vote silver
Old 03-12-2015, 11:24 PM   #758
22RET Powwwa inside
Quote: Originally Posted by dnyce
i vote silver
x2.
Old 03-13-2015, 12:48 AM   #759
Silver. Absolutely
Old 03-13-2015, 08:49 AM   #760
I was looking and just realized that I stole the idea of laying doors off of you lol. I was wondering how you were knowing all the answers to my questions.
Old 03-13-2015, 11:22 AM   #761
No Money Noma
Laydout'noma's Avatar
The engine is looking great! I wish I could get all the stuff in for mine so I can start putting it together. Also whenever you move to the Carolina's you'll have to hit some shows around here so I can see this truck in person.
Old 03-13-2015, 10:46 PM   #762
mhilt13's Avatar
Go with stainless hardware or paint them the same color as what they bolt to so they blend in. Opposite color bolts look "ricer" but this is just my opinion
Old 03-13-2015, 11:44 PM   #763
22RET Powwwa inside
I'm in for stainless also!!! That's what I used.
Old 03-18-2015, 03:37 PM   #764
Jason@Gauge's Avatar
Stainless.... I like the look of them "another" color, but I agree with Mhilt.. Looks a little "ricerish."
Old 03-18-2015, 08:41 PM   #765
wirrrey21's Avatar
my thoughts also. if i don't go stainless, i'll paint them to match each piece.
but on to cooler things.....
I've been trying to update the order of things that need to get accomplished so i am only removing the cab once, or only pulling the motor once, Stuff like that. So i don't want to do this after the motor's in, i decided to move the hole the steering shaft goes through. Once this is done, i can pull the cab off, weld everything, and raptor line the bottom.
You can't tell in either pic, but the steering shaft is actually connected to the column. I may have to cut off the top right hole because i have a feeling it will interfere with the hydroboost's lower left hole. But we'll see when i get to that.
Old 03-19-2015, 05:04 PM   #766
wirrrey21's Avatar
updates!!!!!
I'm gonna replace the rag joint with a flaming river universal and their shaft. Can i get one of their shafts to fit inside the stock upper section?
Old 03-19-2015, 11:02 PM   #767
mhilt13's Avatar
I think the stock upper section will fit a 3/4" DD shaft. Don't hold me to that though better off measuring.
Old 03-20-2015, 04:31 AM   #768
wirrrey21's Avatar
Ok thanks. What am I measuring though? Flat side to flat side? Or curved to curved?
Old 03-20-2015, 07:05 AM   #769
22RET Powwwa inside
I believe it's flat to flat. Should be 3/4"
Also could look into a jeep shaft (same concept as flaming river but not shinny)
Old 03-20-2015, 08:14 AM   #770
wirrrey21's Avatar
I conpletely forgot about the jeep shaft actually. But since i already made the filler piece and the rubber seal fit with the stock shaft i'll just stick with the upper section and swap over the lower.
Can anyone tell me what the spline count is on the steering box? I'd like to order it this morning while i'm at work and i forgot to count yesterday.
Old 03-20-2015, 07:36 PM   #771
22RET Powwwa inside
Don't quote me but I think you can still use the boot ect with the jeep shaft (mine don't have this that's why Im not sure)
Old 03-20-2015, 08:58 PM   #772
always something new
S10dude's Avatar
spline count is 30 per the flaming river u-joint I used on mine .http://www.summitracing.com/parts/fla-fr1746dd
Old 03-21-2015, 11:41 PM   #773
mhilt13's Avatar
Measure from round to round. I checked my 3/4"DD shaft just to be sure. From flat to flat it measures around .56
Old 03-22-2015, 08:49 AM   #774
wirrrey21's Avatar
future frame table!!!!!
once all fabrication and welding is done on the cab, i'm going to pull the cab off to raptor line the underside of the floor and the firewall. But while the cab is off, i'm fixing everything i dont like about the frame. briefly, it flexes at the transition, the skid plate is atleast 1/2" off the ground when laid out, and the backhalf still flexes. So with the cab off and the sick deal i got on the steel, it's a no brainer.
Also, the aluminum air tank came in the mail.
Old 03-22-2015, 09:21 AM   #775
Independent
sonomaguy's Avatar
That's a different shape of steel, what is that from? Also, on a side note, I really like your concrete curbing.
Old 03-22-2015, 10:21 AM   #776
mhilt13's Avatar
Looks like the horizontal tubing form a pallet rack.
Old 03-22-2015, 08:38 PM   #777
22RET Powwwa inside
Yea looks like a shelf of some sort
Old 03-23-2015, 05:25 AM   #778
wirrrey21's Avatar
You are correct sir!!!
Pallet racks from home crapo. 8'8" long, 5" tall, 1/8" wall. Should be plenty strong to hold the frame once the cabs off. It's gonna be a very basic table. 2 sticks welded together for the front to back. And 6 sticks cut down to 6" lengths going side to side. The side to side pieces, I'm just going to lay on top of the front to back pieces. I'm not looking for elaborate, I'm looking for function.
In other news, I finally stripped the origional std cab of everything I may need. I would like to swap the guts from the old dash into the new one, so I hope the way things are routed are somewhat close.
Old 03-24-2015, 10:49 AM   #779
wirrrey21's Avatar
todays task......welding, welding, and more welding. I have 3 hours to put a huge dent in welding up the floor.
Old 03-25-2015, 01:48 AM   #780
Sounds like a great way to spend the day
Old 03-25-2015, 08:50 AM   #781
nfamus10's Avatar
I am at that point too. Tacking it all or stitching it?
Old 03-25-2015, 09:32 AM   #782
wirrrey21's Avatar
it wasn't bad. alittle chilly, but got the whole driver section of the floor welded in 2 hrs.....and then i ran out of wire. smh.
so for the last hour, i cleaned all the welds and and double checked for any pin holes.
NFAMOUS, i'm not sure what you mean. I'm fully welding every piece......one tack at a time.
I'll seam seal the underside, then raptor line over top when it's all finished.
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
