The Family Dragger - Page 12 - S-10 Forum
The Family Dragger
Old 09-05-2014, 10:33 AM   #551
Deadlines are Overrated
wirrrey21's Avatar
Re: The Family Dragger
Got alittle more done yesterday. I could probably start on the template now. I can't really figure out how I want to go around the back of the tranny though.
Old 09-05-2014, 09:55 PM   #552
mhilt13's Avatar
Keep it nice and tight to the trans in the tailshaft area. I messed up and when i slide my seat back all the way it hit but a little hammering fixed it but sucks having a beat up spot in a nice straight floor.
Old 09-06-2014, 01:20 PM   #553
wirrrey21's Avatar
It's kind of a crude drawing, but this is what I came up with. I can't properly display the angles of the bars but you get the idea.
Old 09-06-2014, 03:45 PM   #554
mhilt13's Avatar
That will look nice.
Old 09-09-2014, 05:39 AM   #555
wirrrey21's Avatar
I dont know if it's the sleep depervation talking, but i feel like this floor is taking longer than it needs to be. Should i be getting this intricate with the round bar?
Old 09-09-2014, 12:26 PM   #556
wirrrey21's Avatar
So I started on the driver side and decided not to try and make 1 piece with soo many bends that it slows everything down because I have to get both angles and the lengths dead on perfect. So I did a few straight pieces and got them level and square, then added the angled bars. I Got way more done this way in only 2 hours.
Old 09-12-2014, 04:29 PM   #557
nfamus10's Avatar
Good job. Work smarter not harder.
Old 09-15-2014, 10:35 AM   #558
wirrrey21's Avatar
got a few more pieces in. this sides alittle trickier. i dind't quite give myself as much room around the frame as i did on the passenger side. So the gap between the floor and the frame will be alittle tighter.
Old 09-16-2014, 01:03 AM   #559
wirrrey21's Avatar
So while i'm trying to figure out all the angles of this floor skeleton, i've been thinking about the wiring. And something popped into my head. I'm going to be running a '94 motor and harness. The cab and wiring is from '03. What are the odds that the body harness and the engine harness will plug together and everything will work?
Old 09-16-2014, 01:03 PM   #560
wirrrey21's Avatar
Got a solid couple hours on it this morning. and the driver side floor is basically done. i started on the skeleton for the tranny too. definitely liking how it's taking shape. it actually looks like something now.
I probably shouldn't have made this level. because the stock floor has some pitch to it, but oh well. noone's gonna be able to tell under insulation and a carpet.
And for shits and giggles, i wanted to see how screwed i was with the gas pedal and i was pleasantly surprised.
i'll still have to modify it signifigantly, but i was figuring it would sit below the floor through its entire range of motion. It only "bottoms out" and goes below the floor about halway through it's range.......i think.
Old 09-16-2014, 09:32 PM   #561
mhilt13's Avatar
Floor is looking good.
With the 94 motor and 98+ interior harnesses I dont think they will plug together. Might be easier to get the 94 interior harness and cpu. Might be a little tricky to get the gauge cluster to work too. Could always go with a pre 98 dash to be different. Dont see any crew cabs with them
Old 09-17-2014, 12:41 AM   #562
wirrrey21's Avatar
thank god i was smart enough (and my wife is understanding enough, haha)that i still have the origional '94 cab that went with this motor sitting in my driveway. So i could just swap all the interior over if i have to and probably just splice in the wires for the windows since the '94 had manual windows.
Old 09-17-2014, 08:07 AM   #563
nfamus10's Avatar
I have my windows wired and can send you some pics. I went from manual to power and it was not too bad. It always seemed to me like the 94 dashes are less bulky too, so you may gain a little leg room.
Old 09-18-2014, 01:04 AM   #564
wirrrey21's Avatar
Came across a deal I couldn't pass up!!! You'll see when everything comes in the mail in 2 weeks.
Old 09-18-2014, 01:46 PM   #565
nfamus10's Avatar
Woooooooot!!!!!! I like some deals.
Old 09-20-2014, 08:09 PM   #566
i don't like people
Retro Ten's Avatar
floors looking so nice! it's fun working with the small stuff isn't it? as for all the level stuff you"'ll at least will have some thing "level" to go off of no matter what. sooooooo....... what's the deal????
If you do not want to register, fill this field only and the name will be used as user name for your post.
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
