The Family Dragger - Page 11 - S-10 Forum
The Family Dragger
Old 07-13-2014, 01:45 PM   #501
Deadlines are Overrated
wirrrey21's Avatar
Re: The Family Dragger
thanks guys!!!! I'm lucky that Larry gave me all the flooring that he cut out when he was dropping the cab on the frame. so it'll just be a matter of laying the old pieces in and figuring out what is useless and what i can just trim.
NFAMOUS: i've been hanging with Dagreenmonster for as long as i can remember. But the other guys are layslow, robace, 98layingdime, vivalahammer, djdaudio, and i forget my buddy Bobby's name on here.
jdrink: Thanks bro, love that the beds back on your truck. it looks great!!
Old 07-18-2014, 07:04 PM   #502
wirrrey21's Avatar
I only had about an hour to work on it so i figured i could slide this piece in and tack it in real fast. I'll come back next time and staighten the cuts out for the angled step pieces. I'm not sure if i should cut the floor further inward, or cut the cab part outward.
Old 07-19-2014, 08:25 PM   #503
i don't like people
Retro Ten's Avatar
cab outward, make sure your sill plates will still work to hold the carpet down.
Old 07-20-2014, 02:59 PM   #504
wirrrey21's Avatar
Ok. Thanks. I'll lay the sill plates in and draw a line so I know the farthest I can trim.
Old 07-21-2014, 01:01 AM   #505
GETTING V8'ED
dagreenmonster's Avatar
yup you want to retain the stock sill plates if possible. Will make your life much easier when putting carpet in
Old 07-22-2014, 02:18 AM   #506
wirrrey21's Avatar
I had an hour to kill while my little guy was at camp so I drew out some lines to cut for the angled filler plates.
Old 07-23-2014, 03:43 PM   #507
wirrrey21's Avatar
Got a solid coupld hours work in on the truck. I got the sill plates cut and ready for the angled fillers and i made a box to tie in the floor over the middle body mount. it came out ok i guess, the welds look like crap across the top.
Theoretically i can make the filler pieces tomorrow and move onto the passenger side maybe sunday.
Old 07-23-2014, 08:38 PM   #508
i don't like people
Retro Ten's Avatar
i may be out on a limb here but is the underside of your floor rusty? if it is that is prolly why your welds are looking like that, that's thin metal to begin with. try just a brush or 2 with the wire brush under the weld and around your ground. reason i mainly know is cuz an old timer pro welder i know always makes sure both sides of his metal are just as clean.
Old 07-23-2014, 10:09 PM   #509
V8 with bags
V8Blaze's Avatar
im not an old timer, but ive spent a lot of time behind a welder. Clean both sides, stuff that thin is going to pull contaminates from the bottom side as it pretty much burns through on each tac weld. You really should clean both sides a good bit way from the weld area on both sides on anything you weld.
If you do not want to register, fill this field only and the name will be used as user name for your post.
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
