Stock Flooring (Openly Discuss)
Old 07-28-2008, 08:25 PM   #101
Hoods are overrated
sadexcuse4s10's Avatar
sadexcuse4s10 will become famous soon enough
Re: Stock Flooring (Openly Discuss)
i meant since the mounts are sitll bolted to the cab you can then cut them off and tack them back on lower after the cab drops down flat.
Old 07-28-2008, 09:17 PM   #102
Deadlines are Overrated
wirrrey21's Avatar
wirrrey21 is on a distinguished road
that's kind of the idea i had, but the only thing trippin me up is how do you make sure the cab falls straight down. if you cut 3 of 4 mounts(std. cab) isn't the cab gonna start to fall or lean to one corner?
i guess you could also put jacks under the cab to support the cab then lower it down evenly.
Old 07-28-2008, 10:16 PM   #103
Hoods are overrated
not if you slap some small blocks of wood under the rockers to keep it from sagging. then when they're all cut just get some friends and pick the cab up by the roof and remove the blocks to drop it
Old 07-29-2008, 03:43 AM   #104
Livin Life Low!
lowridinrebel's Avatar
lowridinrebel is on a distinguished road
WOW, this is an amazing thread....Lots of helpful Info...I'm not planning on BD this truck I currently have but I do want to do another oneeventually with a sfbdI wanna learn more....Keep the great info coming!!!!
Thanks alot to the guys who contribute and are serious about it!
Old 07-29-2008, 09:28 AM   #105
I Like Fire....HaHaHa
NickZigaitis's Avatar
NickZigaitis is on a distinguished road
Sadexcuse, thats making sense to me. Thanks for the input.
Old 07-29-2008, 10:07 PM   #106
ridinsolowx15's Avatar
ridinsolowx15
I didn't take many pics when i did mine so i don't have any pics of it but ill try to make a model or drawing of what i mean.
Old 08-02-2008, 06:05 PM   #107
Hoods are overrated
no prob bro. if you do it though, don't forget to cut the bottom edges of the stock mounts so they've got 3" of clearance under them so you're not fighting them when they drop.
you'll see. the stock mounts are very high and have metal coming down towards the frame under them like an upside down U shape. you have to trim a shitload off the bottom so the bottom of the mounts is flat and they'll sit pretty much on the ground when you drop them
i know you've seen the stock mounts so you know what i'm talking about. but here's a couple pics
stock mount, tons of metal underneath the bushing
trimmed and dropped mount
and here's how the rear bed/body mounts will look after you drop them and gusset everything
Old 08-02-2008, 11:13 PM   #108
Afterhours Admin
AVTekk's Avatar
if you have bottle jacks around, you can set them up at each corner and lower it down a bit at a time. i dont bother with all that tho, i take the cab off, build my mounts, then just put it back on with the floor cut out so i can fix the footboards.
Old 08-03-2008, 01:37 AM   #109
Hoods are overrated
yeah, it's faster IMO to just unhook the steering/wiring/brake lines and lift the cab off
Page generated in 0.12634 seconds with 13 queries
