sfbd keeping heat and ac??? i swear i saw a post - S-10 Forum
Old 11-26-2008, 10:13 PM   #1
I know I know search lol I've been searching for the past hour or 2 probably and my a** is getting numb lol. I finally got me a mini(1991 s10) I'm going to start collecting parts soon to bag and sfbd it. I would like to tuck 20"s but 18"s will work too and I want to keep heat and ac. I KNOW I SAW A COUPLE OF POSTS that were just this showing pics and everything people explaining how to and now when i want to save the pics and links i can't find a damn one lol. please help me out. I'm just trying to get most research out of the way while i can. I know some things you can't just learn from reading which is why me and my friend(the best welder I know) are doing it ourselves. hopefully within the next year we will have 2 first gen dimes bagged/sfbd all custom no bolt on and both daily draggers. Thanks for the help guys, btw you'll probably be reading alot more from me and any south nj locals will probably be seeing me around(new to mini's i currently daily drive a 6spd 02 trans am ws6).
Old 11-27-2008, 01:35 AM   #2
*2nd nature fabrication*
93blazer4dr's Avatar
Re: sfbd keeping heat and ac??? i swear i saw a post
im no help but saw that post on here prolly 6 months ago or longer there was a guy who had it all hooked up but didnt have it working
Old 11-27-2008, 01:39 AM   #3
NO REGRETS
purplepassion's Avatar
like vintage air? or stock stuff?
if you wanna keep stock stuff, you'll have to run a baby wheel/tire. or you can get the vintage air, and put it under your dash
Old 11-27-2008, 01:44 AM   #4
im talking about the stock stuff the guy had a 2nd gen s10 and moved it all back into the cab and i think he was running 20s
Old 11-27-2008, 06:58 AM   #5
for the removal of a headach and to keep a clean fire wall go with a vintage air ( a breeze to install) the kits are around 600 i have found them for as cheap as like 440 but if you just want to keep the factory stuff good luck with that. im doing my body drop now so i been looking up alot of theads if i see something I will pop it on here.
Old 11-27-2008, 11:46 AM   #6
i could have swore the one i saw had atleast one guy that did it using his stock stuff but custom made the blower housing and was dragging with 20s.
what do you conisder a baby tire? and i guess i'll start doing some research on the vintage air
Old 11-30-2008, 06:29 PM   #7
no one else has any idea of what i'm talking about?
Old 11-30-2008, 06:55 PM   #8
yep
cbennett's Avatar
I remember seing a guy that used a setup out of another car that has it all under the dash and made it work. I know my eclipse has everything under the dash with some work you couldd probly make something like that work.
Old 11-30-2008, 10:06 PM   #9
i'm not really looking to do that kind of work, i was thinking about making a custom blower housing like i saw on here at one point but i don't feel like relocating everything under the dash. whats the biggest rim/tire i can run bagged/bodydropped with heat and ac? i've been trying to search and haven't found anything yet.
Old 12-01-2008, 10:44 AM   #10
!! TALK NOW !!
drps10's Avatar
this I'm not sure of.. but worth a thought!!
i was told by someone once that we can fit a trailblazer heater system in the truck.. which is they don't have a big blower box sticking out into the engine bay.. which means you can run heat and air... maybe worth some research
Old 12-01-2008, 11:17 AM   #11
that sounds like a good idea, i'm deffinately going to have to look into it.
Old 12-01-2008, 11:21 AM   #12
has anyone actually seen or heard of someone else doing the trailblazer heater system?
Old 12-01-2008, 11:55 AM   #13
!! TALK NOW !!
drps10's Avatar
i have heard of someone doing it.. just can't remember.. i did a quick search and didn't come up with anything
Old 12-01-2008, 12:23 PM   #14
i did a quick search too thats why i asked if it has been done or if it was just an idea some people were passing around. I also googled but i didn't find anything. i'm going to keep trying though.
Old 12-01-2008, 05:45 PM   #15
!! TALK NOW !!
drps10's Avatar
same here... try lookin for a picture of the trailblazer firewall or heater core..
Old 12-02-2008, 04:29 PM   #16
jeffery_843's Avatar
fullsize chevy's have all the stuff under the dash also
Old 12-02-2008, 05:34 PM   #17
Layd the **** out
laydoutjimmy's Avatar
Im sure with enough time and patience if you slide the cab back around a inch or so you would be off to a good start and have more room to work with.
Old 12-02-2008, 06:46 PM   #18
!! TALK NOW !!
drps10's Avatar
what about the blower motor tho... how far does that stick out into the firewall.. or is it just a slit in the firewall with the motor under the dash?
Old 12-02-2008, 08:18 PM   #19
with out moving the cab back what would be the biggest rim/tire i can run i can't seem to find that answer either. thanks for all of the other posts.
Old 12-02-2008, 08:45 PM   #20
KZELIMINATOR
kzeliminator's Avatar
well you usually move the cab back 3/4 inch to center out the wheels, wouldnt be much more room, def not for a bigger tire size, either way you'll have to tub
Old 12-03-2008, 11:53 AM   #21
i planned on tubbing
Old 12-03-2008, 10:18 PM   #22
Redd's Avatar
if you put all the wiring under the dash, a unit from a trailblazer might not fit...
Old 12-03-2008, 10:23 PM   #23
i doubt im going to try and tuck a trailblazer climate control system under the dash on the first bag/body drop i ever do so how big of rims/tire can i run and keep the blower where its at? i may remove the ac but only if i have to(its ugly anyway)
Old 12-03-2008, 10:27 PM   #24
Redd's Avatar
if all your look for is heat, then you can run any size you want and do something along the lines of what im doing.
Take the heater core out of the vent box. built a sheet metal box for it, holes on one side, E-fan on the other. If you get a good enough fan you could even run it up to the defrost and so on.
Old 12-03-2008, 10:31 PM   #25
everything is under the dash, nothing under the hood. at least thats how it is on my buddy's early 90's fullsize and on my 96 tahoe
Old 12-04-2008, 07:33 AM   #26
I'd probably only run defrost and maybe floor because all i really care about is cleaning the windows but sometimes my toes are cold lol. do you have any pics of how your doing this or of someone else that already did it or what would i search for to look this idea up?
Old 12-04-2008, 08:11 AM   #27
Redd's Avatar
I've been to lazy to build it actualy. I'll start on it next week tho
Old 12-04-2008, 09:29 AM   #28
lol but where did you get the idea to do this? did you see it somewhere?
Old 12-04-2008, 05:38 PM   #29
Redd's Avatar
thought of it myself....
well when I had my Ford lightning I took a ranger heater core and made a box for it to add inline to the water intercooler system for the supercharger. The box was for when i went to the track i could leave the electric pump going to keep the fluid moving and fill the box up with ice to help keep things cool between runs...
Only other thing youd need is a manual valve from an older truck to regulate the flow through the heater core. Ill get pics later when im not on my phone
Old 12-04-2008, 09:20 PM   #30
thanks that sounds like it wouldnt be too hard. why would you need a valve to regulate flow through the heater core? i've never seen any valves for the stock heater core.
Old 12-04-2008, 09:40 PM   #31
Redd's Avatar
the valve is to regulate how much coolant goes through the heater core. Old vehicles it was cable operated. So the more the valve is open the more heat you would get. Close it and less heat or close it completely for no heat.
I'm at my gfs new apt so I can't post a pic yet but I'll have one later tonight of the valve
Old 12-05-2008, 06:18 PM   #32
Redd's Avatar
Heres a valve im talking about. They have manual ones with just a pull cord or electric like the one pictured hear. Same kind of valves used on vintage air, etc.
Im getting something similar to this, co-workers wife works for a company cald OLD AIR PRODUCTS. Im going to do this till i get tired of no a/c and will buy a system from them.
Old 12-05-2008, 07:48 PM   #33
Layd the **** out
The best way to figure it out is to just get into it and make it work bro i doubt ayone is gonna have one single answer for ya
Old 12-05-2008, 11:37 PM   #34
i know but i'm trying to get my ideas up so i have time to research what i need.
Old 12-06-2008, 11:00 AM   #35
Hoods are overrated
sadexcuse4s10's Avatar
damn i want one of those valves! manual pull cord style though!
if you can get a price on one PM me please
Old 12-06-2008, 01:57 PM   #36
Sprint Car Addict.
FCKNLOW's Avatar
this is what you were lookin for...
http://www.s10forum.com/forum/f143/j...loored-375779/
Old 12-06-2008, 09:20 PM   #37
its not the post i was looking for but pretty close, i did save that page lol thanks.
Old 12-10-2008, 02:10 AM   #38
i no the one your looking for and it was a extended cab 2nd s10 i think it was orange
Old 12-10-2008, 07:22 AM   #39
idk but i pretty much have a general idea of what i'm doing. i'm sure when i actually start doing it all i'll run into a problem and ill be right back here lol. mine wont be done for a few months because i need to buy everything and pay off some credit card debt lol. but i'll be sure to post a build up on my buddies truck(88?maybe short cab short bed) he'll be laying rocker on 20's keeping heat for a daily dragger. he ripped the bed off sometime last week and than the truck sat a few days, than monday i went to his house we ripped off the front end and last night we tore the cab off by hand lol. i think tonight we're gonna start tearing into the suspension and maybe do the notch. this kid is one hell of a welder so we're pretty much doing the whole truck custom.
Old 12-10-2008, 07:22 AM   #40
thanks for the help guys.
Old 12-10-2008, 08:50 AM   #41
i know im kinda late but just thought i would throw these pics up
everything has been moved up and over.
Old 12-10-2008, 12:01 PM   #42
bichen60 is do you lay that truck on rocker? what size tires are you runnin? that looks like a real nice set up, is that a custom firewall or is it just modified where you needed to modify it? i like the way your engine bay looks.
Old 12-10-2008, 01:28 PM   #43
thats the factory fire wall that has just been shaved then the hole for the blower box was moved, truck is only on 18s right now but i think with a little more work you could do it on 20s would just have to plan out the blower box different.
Old 12-10-2008, 01:46 PM   #44
do you have any pics of the truck laid out? i was thinking about just doing 18s because it would be easier to lay out and still look good.
Old 12-11-2008, 09:49 PM   #45
Redd's Avatar
i dont see how youd get it to fit on 20s... theres no damn room on my fire wall with my 20s
Old 09-25-2009, 03:23 AM   #46
Mr. Token Black
chvys10's Avatar
Sorry to whore......
Who has the truck w/ the non-A/C blower box??
